path: root/c/src/ada-tests/mptests/mp05/config_base.h (follow)
* 2007-10-03 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-10-031-0/+32
* mptests/mp01/node1/Makefile.am, mptests/mp01/node2/Makefile.am, mptests/mp02/node1/Makefile.am, mptests/mp02/node2/Makefile.am, mptests/mp03/node1/Makefile.am, mptests/mp03/node2/Makefile.am, mptests/mp04/node1/Makefile.am, mptests/mp04/node2/Makefile.am, mptests/mp05/node1/Makefile.am, mptests/mp05/node2/Makefile.am, mptests/mp06/node1/Makefile.am, mptests/mp06/node2/Makefile.am, mptests/mp07/node1/Makefile.am, mptests/mp07/node2/Makefile.am, mptests/mp08/node1/Makefile.am, mptests/mp08/node2/Makefile.am, mptests/mp09/node1/Makefile.am, mptests/mp09/node2/Makefile.am, mptests/mp10/node1/Makefile.am, mptests/mp10/node2/Makefile.am, mptests/mp11/node1/Makefile.am, mptests/mp11/node2/Makefile.am, mptests/mp12/node1/Makefile.am, mptests/mp12/node2/Makefile.am, mptests/mp13/node1/Makefile.am, mptests/mp13/node2/Makefile.am, mptests/mp14/node1/Makefile.am, mptests/mp14/node2/Makefile.am: Basic build structure should now be correct. The remaining issues should be test specific. * mptests/mp01/config_base.h, mptests/mp01/node1/config.h, mptests/mp01/node1/mp01_node1.adb, mptests/mp01/node2/config.h, mptests/mp01/node2/mp01_node2.adb, mptests/mp02/config_base.h, mptests/mp02/node1/config.h, mptests/mp02/node1/mp02_node1.adb, mptests/mp02/node2/config.h, mptests/mp02/node2/mp02_node2.adb, mptests/mp03/config_base.h, mptests/mp03/node1/config.h, mptests/mp03/node1/mp03_node1.adb, mptests/mp03/node2/config.h, mptests/mp03/node2/mp03_node2.adb, mptests/mp04/config_base.h, mptests/mp04/node1/config.h, mptests/mp04/node1/mp04_node1.adb, mptests/mp04/node2/config.h, mptests/mp04/node2/mp04_node2.adb, mptests/mp05/config_base.h, mptests/mp05/node1/config.h, mptests/mp05/node1/mp05_node1.adb, mptests/mp05/node2/config.h, mptests/mp05/node2/mp05_node2.adb, mptests/mp06/config_base.h, mptests/mp06/node1/config.h, mptests/mp06/node1/mp06_node1.adb, mptests/mp06/node2/config.h, mptests/mp06/node2/mp06_node2.adb, mptests/mp07/config_base.h, mptests/mp07/node1/config.h, mptests/mp07/node1/mp07_node1.adb, mptests/mp07/node2/config.h, mptests/mp07/node2/mp07_node2.adb, mptests/mp08/config_base.h, mptests/mp08/node1/config.h, mptests/mp08/node1/mp08_node1.adb, mptests/mp08/node2/config.h, mptests/mp08/node2/mp08_node2.adb, mptests/mp09/config_base.h, mptests/mp09/node1/config.h, mptests/mp09/node1/mp09_node1.adb, mptests/mp09/node2/config.h, mptests/mp09/node2/mp09_node2.adb, mptests/mp10/config_base.h, mptests/mp10/node1/config.h, mptests/mp10/node1/mp10_node1.adb, mptests/mp10/node2/config.h, mptests/mp10/node2/mp10_node2.adb, mptests/mp11/config_base.h, mptests/mp11/node1/config.h, mptests/mp11/node1/mp11_node1.adb, mptests/mp11/node2/config.h, mptests/mp11/node2/mp11_node2.adb, mptests/mp12/config_base.h, mptests/mp12/node1/config.h, mptests/mp12/node1/mp12_node1.adb, mptests/mp12/node2/config.h, mptests/mp12/node2/mp12_node2.adb, mptests/mp13/config_base.h, mptests/mp13/node1/config.h, mptests/mp13/node1/mp13_node1.adb, mptests/mp13/node2/config.h, mptests/mp13/node2/mp13_node2.adb, mptests/mp14/config_base.h, mptests/mp14/node1/config.h, mptests/mp14/node1/mp14_node1.adb, mptests/mp14/node2/config.h, mptests/mp14/node2/mp14_node2.adb: New files. GNATMAKE is easier to operate if the filename of the main package matches the executable name. In this case, we needed one for each node's executable. * mptests/mp01/config.h: Removed.
