path: root/c/src/ada-tests/mptests/mp04/node1/Makefile.am (follow)
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+2
* Remove CVS-Ids.Ralf Corsépius2012-05-041-2/+0
* 2009-12-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-12-141-4/+5
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * mptests/mp01/node1/Makefile.am, mptests/mp01/node2/Makefile.am, mptests/mp02/node1/Makefile.am, mptests/mp02/node2/Makefile.am, mptests/mp03/node1/Makefile.am, mptests/mp03/node2/Makefile.am, mptests/mp04/node1/Makefile.am, mptests/mp04/node2/Makefile.am, mptests/mp05/node1/Makefile.am, mptests/mp05/node2/Makefile.am, mptests/mp06/node1/Makefile.am, mptests/mp06/node2/Makefile.am, mptests/mp07/node1/Makefile.am, mptests/mp07/node2/Makefile.am, mptests/mp08/node1/Makefile.am, mptests/mp08/node2/Makefile.am, mptests/mp09/node1/Makefile.am, mptests/mp09/node2/Makefile.am, mptests/mp10/node1/Makefile.am, mptests/mp10/node2/Makefile.am, mptests/mp11/node1/Makefile.am, mptests/mp11/node2/Makefile.am, mptests/mp12/node1/Makefile.am, mptests/mp12/node2/Makefile.am, mptests/mp13/node1/Makefile.am, mptests/mp13/node2/Makefile.am, mptests/mp14/node1/Makefile.am, mptests/mp14/node2/Makefile.am, samples/base_mp/Makefile.am, samples/base_mp/node1/Makefile.am, samples/base_mp/node2/Makefile.am, samples/base_sp/Makefile.am, samples/hello/Makefile.am, samples/nsecs/Makefile.am, samples/ticker/Makefile.am, sptests/sp01/Makefile.am, sptests/sp02/Makefile.am, sptests/sp03/Makefile.am, sptests/sp04/Makefile.am, sptests/sp05/Makefile.am, sptests/sp06/Makefile.am, sptests/sp07/Makefile.am, sptests/sp08/Makefile.am, sptests/sp09/Makefile.am, sptests/sp11/Makefile.am, sptests/sp12/Makefile.am, sptests/sp13/Makefile.am, sptests/sp14/Makefile.am, sptests/sp15/Makefile.am, sptests/sp16/Makefile.am, sptests/sp17/Makefile.am, sptests/sp19/Makefile.am, sptests/sp20/Makefile.am, sptests/sp22/Makefile.am, sptests/sp23/Makefile.am, sptests/sp24/Makefile.am, sptests/sp25/Makefile.am, sptests/spname01/Makefile.am, tmtests/tm01/Makefile.am, tmtests/tm02/Makefile.am, tmtests/tm03/Makefile.am, tmtests/tm04/Makefile.am, tmtests/tm05/Makefile.am, tmtests/tm06/Makefile.am, tmtests/tm07/Makefile.am, tmtests/tm08/Makefile.am, tmtests/tm09/Makefile.am, tmtests/tm10/Makefile.am, tmtests/tm11/Makefile.am, tmtests/tm12/Makefile.am, tmtests/tm13/Makefile.am, tmtests/tm14/Makefile.am, tmtests/tm15/Makefile.am, tmtests/tm16/Makefile.am, tmtests/tm17/Makefile.am, tmtests/tm18/Makefile.am, tmtests/tm19/Makefile.am, tmtests/tm20/Makefile.am, tmtests/tm21/Makefile.am, tmtests/tm22/Makefile.am, tmtests/tm23/Makefile.am, tmtests/tm24/Makefile.am, tmtests/tm25/Makefile.am, tmtests/tm28/Makefile.am, tmtests/tm29/Makefile.am, tmtests/tmck/Makefile.am, tmtests/tmoverhd/Makefile.am: Update so all tests build.
* 2008-02-01 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-02-011-5/+5
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * mptests/mp01/node1/Makefile.am, mptests/mp01/node2/Makefile.am, mptests/mp02/node1/Makefile.am, mptests/mp02/node2/Makefile.am, mptests/mp03/node1/Makefile.am, mptests/mp03/node2/Makefile.am, mptests/mp04/node1/Makefile.am, mptests/mp04/node2/Makefile.am, mptests/mp05/node1/Makefile.am, mptests/mp05/node2/Makefile.am, mptests/mp06/node1/Makefile.am, mptests/mp06/node2/Makefile.am, mptests/mp07/node1/Makefile.am, mptests/mp07/node2/Makefile.am, mptests/mp08/node1/Makefile.am, mptests/mp08/node2/Makefile.am, mptests/mp09/node1/Makefile.am, mptests/mp09/node2/Makefile.am, mptests/mp10/node1/Makefile.am, mptests/mp10/node2/Makefile.am, mptests/mp11/node1/Makefile.am, mptests/mp11/node2/Makefile.am, mptests/mp12/node1/Makefile.am, mptests/mp12/node2/Makefile.am, mptests/mp13/node1/Makefile.am, mptests/mp13/node2/Makefile.am, mptests/mp14/node1/Makefile.am, mptests/mp14/node2/Makefile.am, samples/base_mp/node1/Makefile.am, samples/base_mp/node2/Makefile.am, samples/base_sp/Makefile.am, samples/hello/Makefile.am, samples/nsecs/Makefile.am, samples/ticker/Makefile.am, sptests/sp01/Makefile.am, sptests/sp02/Makefile.am, sptests/sp03/Makefile.am, sptests/sp04/Makefile.am, sptests/sp05/Makefile.am, sptests/sp06/Makefile.am, sptests/sp07/Makefile.am, sptests/sp08/Makefile.am, sptests/sp09/Makefile.am, sptests/sp11/Makefile.am, sptests/sp12/Makefile.am, sptests/sp13/Makefile.am, sptests/sp14/Makefile.am, sptests/sp15/Makefile.am, sptests/sp16/Makefile.am, sptests/sp17/Makefile.am, sptests/sp19/Makefile.am, sptests/sp20/Makefile.am, sptests/sp22/Makefile.am, sptests/sp23/Makefile.am, sptests/sp24/Makefile.am, sptests/sp25/Makefile.am, tmtests/tm01/Makefile.am, tmtests/tm02/Makefile.am, tmtests/tm03/Makefile.am, tmtests/tm04/Makefile.am, tmtests/tm05/Makefile.am, tmtests/tm06/Makefile.am, tmtests/tm07/Makefile.am, tmtests/tm08/Makefile.am, tmtests/tm09/Makefile.am, tmtests/tm10/Makefile.am, tmtests/tm11/Makefile.am, tmtests/tm12/Makefile.am, tmtests/tm13/Makefile.am, tmtests/tm14/Makefile.am, tmtests/tm15/Makefile.am, tmtests/tm16/Makefile.am, tmtests/tm17/Makefile.am, tmtests/tm18/Makefile.am, tmtests/tm19/Makefile.am, tmtests/tm20/Makefile.am, tmtests/tm21/Makefile.am, tmtests/tm22/Makefile.am, tmtests/tm23/Makefile.am, tmtests/tm24/Makefile.am, tmtests/tm25/Makefile.am, tmtests/tm28/Makefile.am, tmtests/tm29/Makefile.am, tmtests/tmck/Makefile.am, tmtests/tmoverhd/Makefile.am: Make all test names unique. All needed ada_ as prefix to distinguish them from the C tests. MP tests should produce an executable with test name and node number in it. Screens renamed to follow. * ada_mvscn, mptests/mp01/node1/ada_mp01-node1.scn, mptests/mp01/node2/ada_mp01-node2.scn, mptests/mp02/node1/ada_mp02-node1.scn, mptests/mp02/node2/ada_mp02-node2.scn, mptests/mp03/node1/ada_mp03-node1.scn, mptests/mp03/node2/ada_mp03-node2.scn, mptests/mp04/node1/ada_mp04-node1.scn, mptests/mp04/node2/ada_mp04-node2.scn, mptests/mp05/node1/ada_mp05-node1.scn, mptests/mp05/node2/ada_mp05-node2.scn, mptests/mp06/node1/ada_mp06-node1.scn, mptests/mp06/node2/ada_mp06-node2.scn, mptests/mp07/node1/ada_mp07-node1.scn, mptests/mp07/node2/ada_mp07-node2.scn, mptests/mp08/node1/ada_mp08-node1.scn, mptests/mp08/node2/ada_mp08-node2.scn, mptests/mp09/node1/ada_mp09-node1.scn, mptests/mp09/node2/ada_mp09-node2.scn, mptests/mp10/node1/ada_mp10-node1.scn, mptests/mp10/node2/ada_mp10-node2.scn, mptests/mp11/node1/ada_mp11-node1.scn, mptests/mp11/node2/ada_mp11-node2.scn, mptests/mp12/node1/ada_mp12-node1.scn, mptests/mp12/node2/ada_mp12-node2.scn, mptests/mp13/node1/ada_mp13-node1.scn, mptests/mp13/node2/ada_mp13-node2.scn, mptests/mp14/node1/ada_mp14-node1.scn, mptests/mp14/node2/ada_mp14-node2.scn, samples/base_mp/node1/ada_base_mp-node1.scn, samples/base_mp/node2/ada_base_mp-node2.scn, samples/base_sp/ada_base_sp.scn, samples/hello/ada_hello.scn, samples/nsecs/ada_nsecs.scn, samples/ticker/ada_ticker.scn, sptests/sp01/ada_sp01.scn, sptests/sp02/ada_sp02.scn, sptests/sp03/ada_sp03.scn, sptests/sp04/ada_sp04.scn, sptests/sp05/ada_sp05.scn, sptests/sp06/ada_sp06.scn, sptests/sp07/ada_sp07.scn, sptests/sp08/ada_sp08.scn, sptests/sp09/ada_sp09.scn, sptests/sp11/ada_sp11.scn, sptests/sp12/ada_sp12.scn, sptests/sp13/ada_sp13.scn, sptests/sp14/ada_sp14.scn, sptests/sp15/ada_sp15.scn, sptests/sp16/ada_sp16.scn, sptests/sp17/ada_sp17.scn, sptests/sp19/ada_sp19.scn, sptests/sp20/ada_sp20.scn, sptests/sp22/ada_sp22.scn, sptests/sp23/ada_sp23.scn, sptests/sp24/ada_sp24.scn, sptests/sp25/ada_sp25.scn: New files. * mptests/mp01/node1/mp01-node1.scn, mptests/mp01/node2/mp01-node2.scn, mptests/mp02/node1/mp02-node1.scn, mptests/mp02/node2/mp02-node2.scn, mptests/mp03/node1/mp03-node1.scn, mptests/mp03/node2/mp03-node2.scn, mptests/mp04/node1/mp04-node1.scn, mptests/mp04/node2/mp04-node2.scn, mptests/mp05/node1/mp05-node1.scn, mptests/mp05/node2/mp05-node2.scn, mptests/mp06/node1/mp06-node1.scn, mptests/mp06/node2/mp06-node2.scn, mptests/mp07/node1/mp07-node1.scn, mptests/mp07/node2/mp07-node2.scn, mptests/mp08/node1/mp08-node1.scn, mptests/mp08/node2/mp08-node2.scn, mptests/mp09/node1/mp09-node1.scn, mptests/mp09/node2/mp09-node2.scn, mptests/mp10/node1/mp10-node1.scn, mptests/mp10/node2/mp10-node2.scn, mptests/mp11/node1/mp11-node1.scn, mptests/mp11/node2/mp11-node2.scn, mptests/mp12/node1/mp12-node1.scn, mptests/mp12/node2/mp12-node2.scn, mptests/mp13/node1/mp13-node1.scn, mptests/mp13/node2/mp13-node2.scn, mptests/mp14/node1/mp14-node1.scn, mptests/mp14/node2/mp14-node2.scn, samples/base_mp/node1/base_mp-node1.scn, samples/base_mp/node2/base_mp-node2.scn, samples/base_sp/base_sp.scn, samples/hello/hello.scn, samples/nsecs/nsecs.scn, samples/ticker/ticker.scn, sptests/sp01/sp01.scn, sptests/sp02/sp02.scn, sptests/sp03/sp03.scn, sptests/sp04/sp04.scn, sptests/sp05/sp05.scn, sptests/sp06/sp06.scn, sptests/sp07/sp07.scn, sptests/sp08/sp08.scn, sptests/sp09/sp09.scn, sptests/sp11/sp11.scn, sptests/sp12/sp12.scn, sptests/sp13/sp13.scn, sptests/sp14/sp14.scn, sptests/sp15/sp15.scn, sptests/sp16/sp16.scn, sptests/sp17/sp17.scn, sptests/sp19/sp19.scn, sptests/sp20/sp20.scn, sptests/sp22/sp22.scn, sptests/sp23/sp23.scn, sptests/sp24/sp24.scn, sptests/sp25/sp25.scn: Removed.
* 2007-10-25 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-10-251-4/+4
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * mptests/mp01/node1/Makefile.am, mptests/mp01/node2/Makefile.am, mptests/mp02/node1/Makefile.am, mptests/mp02/node2/Makefile.am, mptests/mp03/node1/Makefile.am, mptests/mp03/node2/Makefile.am, mptests/mp04/node1/Makefile.am, mptests/mp04/node2/Makefile.am, mptests/mp05/node1/Makefile.am, mptests/mp05/node2/Makefile.am, mptests/mp06/node1/Makefile.am, mptests/mp06/node2/Makefile.am, mptests/mp07/node1/Makefile.am, mptests/mp07/node2/Makefile.am, mptests/mp08/node1/Makefile.am, mptests/mp08/node2/Makefile.am, mptests/mp09/node1/Makefile.am, mptests/mp09/node2/Makefile.am, mptests/mp10/node1/Makefile.am, mptests/mp10/node2/Makefile.am, mptests/mp11/node1/Makefile.am, mptests/mp11/node2/Makefile.am, mptests/mp12/node1/Makefile.am, mptests/mp12/node2/Makefile.am, mptests/mp13/node1/Makefile.am, mptests/mp13/node2/Makefile.am, mptests/mp14/node1/Makefile.am, mptests/mp14/node2/Makefile.am, samples/base_mp/Makefile.am, samples/base_mp/node1/Makefile.am, samples/base_mp/node2/Makefile.am, samples/base_sp/Makefile.am, samples/hello/Makefile.am, samples/nsecs/Makefile.am, samples/ticker/Makefile.am, sptests/sp01/Makefile.am, sptests/sp02/Makefile.am, sptests/sp03/Makefile.am, sptests/sp04/Makefile.am, sptests/sp05/Makefile.am, sptests/sp06/Makefile.am, sptests/sp07/Makefile.am, sptests/sp08/Makefile.am, sptests/sp09/Makefile.am, sptests/sp11/Makefile.am, sptests/sp12/Makefile.am, sptests/sp13/Makefile.am, sptests/sp14/Makefile.am, sptests/sp15/Makefile.am, sptests/sp16/Makefile.am, sptests/sp17/Makefile.am, sptests/sp19/Makefile.am, sptests/sp20/Makefile.am, sptests/sp22/Makefile.am, sptests/sp23/Makefile.am, sptests/sp24/Makefile.am, sptests/sp25/Makefile.am, tmtests/tm01/Makefile.am, tmtests/tm02/Makefile.am, tmtests/tm03/Makefile.am, tmtests/tm04/Makefile.am, tmtests/tm05/Makefile.am, tmtests/tm06/Makefile.am, tmtests/tm07/Makefile.am, tmtests/tm08/Makefile.am, tmtests/tm09/Makefile.am, tmtests/tm10/Makefile.am, tmtests/tm11/Makefile.am, tmtests/tm12/Makefile.am, tmtests/tm13/Makefile.am, tmtests/tm14/Makefile.am, tmtests/tm15/Makefile.am, tmtests/tm16/Makefile.am, tmtests/tm17/Makefile.am, tmtests/tm18/Makefile.am, tmtests/tm19/Makefile.am, tmtests/tm20/Makefile.am, tmtests/tm21/Makefile.am, tmtests/tm22/Makefile.am, tmtests/tm23/Makefile.am, tmtests/tm24/Makefile.am, tmtests/tm25/Makefile.am, tmtests/tm28/Makefile.am, tmtests/tm29/Makefile.am, tmtests/tmck/Makefile.am, tmtests/tmoverhd/Makefile.am: Executables should end in .exe just like their C counterparts.
* 2007-10-03 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-10-031-7/+5
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * mptests/mp01/node1/Makefile.am, mptests/mp01/node2/Makefile.am, mptests/mp02/node1/Makefile.am, mptests/mp02/node2/Makefile.am, mptests/mp03/node1/Makefile.am, mptests/mp03/node2/Makefile.am, mptests/mp04/node1/Makefile.am, mptests/mp04/node2/Makefile.am, mptests/mp05/node1/Makefile.am, mptests/mp05/node2/Makefile.am, mptests/mp06/node1/Makefile.am, mptests/mp06/node2/Makefile.am, mptests/mp07/node1/Makefile.am, mptests/mp07/node2/Makefile.am, mptests/mp08/node1/Makefile.am, mptests/mp08/node2/Makefile.am, mptests/mp09/node1/Makefile.am, mptests/mp09/node2/Makefile.am, mptests/mp10/node1/Makefile.am, mptests/mp10/node2/Makefile.am, mptests/mp11/node1/Makefile.am, mptests/mp11/node2/Makefile.am, mptests/mp12/node1/Makefile.am, mptests/mp12/node2/Makefile.am, mptests/mp13/node1/Makefile.am, mptests/mp13/node2/Makefile.am, mptests/mp14/node1/Makefile.am, mptests/mp14/node2/Makefile.am: Basic build structure should now be correct. The remaining issues should be test specific. * mptests/mp01/config_base.h, mptests/mp01/node1/config.h, mptests/mp01/node1/mp01_node1.adb, mptests/mp01/node2/config.h, mptests/mp01/node2/mp01_node2.adb, mptests/mp02/config_base.h, mptests/mp02/node1/config.h, mptests/mp02/node1/mp02_node1.adb, mptests/mp02/node2/config.h, mptests/mp02/node2/mp02_node2.adb, mptests/mp03/config_base.h, mptests/mp03/node1/config.h, mptests/mp03/node1/mp03_node1.adb, mptests/mp03/node2/config.h, mptests/mp03/node2/mp03_node2.adb, mptests/mp04/config_base.h, mptests/mp04/node1/config.h, mptests/mp04/node1/mp04_node1.adb, mptests/mp04/node2/config.h, mptests/mp04/node2/mp04_node2.adb, mptests/mp05/config_base.h, mptests/mp05/node1/config.h, mptests/mp05/node1/mp05_node1.adb, mptests/mp05/node2/config.h, mptests/mp05/node2/mp05_node2.adb, mptests/mp06/config_base.h, mptests/mp06/node1/config.h, mptests/mp06/node1/mp06_node1.adb, mptests/mp06/node2/config.h, mptests/mp06/node2/mp06_node2.adb, mptests/mp07/config_base.h, mptests/mp07/node1/config.h, mptests/mp07/node1/mp07_node1.adb, mptests/mp07/node2/config.h, mptests/mp07/node2/mp07_node2.adb, mptests/mp08/config_base.h, mptests/mp08/node1/config.h, mptests/mp08/node1/mp08_node1.adb, mptests/mp08/node2/config.h, mptests/mp08/node2/mp08_node2.adb, mptests/mp09/config_base.h, mptests/mp09/node1/config.h, mptests/mp09/node1/mp09_node1.adb, mptests/mp09/node2/config.h, mptests/mp09/node2/mp09_node2.adb, mptests/mp10/config_base.h, mptests/mp10/node1/config.h, mptests/mp10/node1/mp10_node1.adb, mptests/mp10/node2/config.h, mptests/mp10/node2/mp10_node2.adb, mptests/mp11/config_base.h, mptests/mp11/node1/config.h, mptests/mp11/node1/mp11_node1.adb, mptests/mp11/node2/config.h, mptests/mp11/node2/mp11_node2.adb, mptests/mp12/config_base.h, mptests/mp12/node1/config.h, mptests/mp12/node1/mp12_node1.adb, mptests/mp12/node2/config.h, mptests/mp12/node2/mp12_node2.adb, mptests/mp13/config_base.h, mptests/mp13/node1/config.h, mptests/mp13/node1/mp13_node1.adb, mptests/mp13/node2/config.h, mptests/mp13/node2/mp13_node2.adb, mptests/mp14/config_base.h, mptests/mp14/node1/config.h, mptests/mp14/node1/mp14_node1.adb, mptests/mp14/node2/config.h, mptests/mp14/node2/mp14_node2.adb: New files. GNATMAKE is easier to operate if the filename of the main package matches the executable name. In this case, we needed one for each node's executable. * mptests/mp01/config.h: Removed.
* Add dist_scn_DATA = *.scn.Ralf Corsepius2005-11-211-0/+3
* New.Ralf Corsepius2005-11-201-0/+19
