* mptests/Makefile.am: New.
* mptests/mp01/Makefile.am: New.
* mptests/mp01/node1/Makefile.am: New.
* mptests/mp01/node2/Makefile.am: New.
* samples/base_mp/Makefile.am: Comment out building mptest$(EXEEXT).
* samples/base_mp/node1/Makefile.am: New.
* samples/base_mp/node2/Makefile.am: New.
* configure.ac: Add mptests/mp01. Add samples/base_mp.
* sptests/sp09/sptest.adb: Add Result to SCREEN_13.
Remove Status from TASK_1.
* sptests/sp21/sptest.adb: Add Result to TASK_1.
* tmtests/tm20/tmtest.adb: Remove various RETURN_VALUEs.
* ada.am: Remove ADACOMPILE, ADAC. Add AM_LDFLAGS, LDFLAGS.
* configure.ac: Check for m4. Abort if HAS_GNAT = no.
* tm27 and tm27 are irrelevant as Ada binding tests.
* tmtests/tm26/Makefile.am, tmtests/tm26/README, tmtests/tm26/tm26.adb,
tmtests/tm26/tmtest.adb, tmtests/tm26/tmtest.adp,
tmtests/tm26/tmtest.ads, tmtests/tm27/Makefile.am, tmtests/tm27/README,
tmtests/tm27/tm27.adb, tmtests/tm27/tmtest.adb,
tmtests/tm27/tmtest.ads: Removed.
* configure.ac, tmtests/Makefile.am: Modified to reflect above.
* Makefile.am: Activate tmtests.
* configure.ac: Activate tmtests.
* samples/base_mp/Makefile.am: Add nodeX subdirs.
* sptests/sp01/Makefile.am: Add *.scn.
* sptests/sp02/Makefile.am: Add *.scn.
* sptests/sp03/Makefile.am: Add *.scn.
* sptests/sp04/Makefile.am: Add *.scn.
* sptests/sp05/Makefile.am: Add *.scn.
* sptests/sp06/Makefile.am: Add *.scn.
* sptests/sp07/Makefile.am: Add *.scn.
* sptests/sp08/Makefile.am: Add *.scn.
* sptests/sp09/Makefile.am: Add *.scn.
* sptests/sp11/Makefile.am: Add *.scn.
* sptests/sp12/Makefile.am: Add *.scn.
* sptests/sp13/Makefile.am: Add *.scn.
* sptests/sp14/Makefile.am: Add *.scn.
* sptests/sp15/Makefile.am: Add *.scn.
* sptests/sp16/Makefile.am: Add *.scn.
* sptests/sp17/Makefile.am: Add *.scn.
* sptests/sp19/Makefile.am: Add *.scn.
* sptests/sp20/Makefile.am: Add *.scn.
* sptests/sp21/Makefile.am: Add *.scn.
* sptests/sp22/Makefile.am: Add *.scn.
* sptests/sp23/Makefile.am: Add *.scn.
* sptests/sp24/Makefile.am: Add *.scn.
* sptests/sp25/Makefile.am: Add *.scn.
* Makefile.am: New.
* configure.ac: New.
* ada.am: New.
* support/Makefile.am: New.
* samples/Makefile.am: New.
* samples/base_mp/Makefile.am: New.
* samples/base_sp/Makefile.am: New.
* samples/hello/Makefile.am: New.
* samples/ticker/Makefile.am: New.
