* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -2/+0 |
* | Cleanup. | Ralf Corsepius | 2005-11-20 | 1 | -2/+0 |
* | 2004-03-25 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-25 | 1 | -2/+2 |
| | | | | | | | | * configure.ac: Add 2nd arg to RTEMS_TOP. Unconditionally configure MP-directories. * Makefile.am: Don't include @RTEMS_BSP@.cfg. Add DIST_SUBDIRS comprising MP-subdirs. * samples/Makefile.am: Add DIST_SUBDIRS comprising MP-subdirs. | ||||
* | 2003-11-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-11 | 1 | -4/+4 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Makefile.am: Reflect having moved tests/. * mptests/Makefile.am: Reflect having moved tests/. * mptests/mp01/Makefile.am: Reflect having moved tests/. * mptests/mp01/node1/Makefile.am: Reflect having moved tests/. * mptests/mp01/node2/Makefile.am: Reflect having moved tests/. * samples/Makefile.am: Reflect having moved tests/. * samples/base_mp/Makefile.am: Reflect having moved tests/. * samples/base_mp/node1/Makefile.am: Reflect having moved tests/. * samples/base_mp/node2/Makefile.am: Reflect having moved tests/. * samples/base_sp/Makefile.am: Reflect having moved tests/. * samples/hello/Makefile.am: Reflect having moved tests/. * samples/ticker/Makefile.am: Reflect having moved tests/. * sptests/Makefile.am: Reflect having moved tests/. * sptests/sp01/Makefile.am: Reflect having moved tests/. * sptests/sp02/Makefile.am: Reflect having moved tests/. * sptests/sp03/Makefile.am: Reflect having moved tests/. * sptests/sp04/Makefile.am: Reflect having moved tests/. * sptests/sp05/Makefile.am: Reflect having moved tests/. * sptests/sp06/Makefile.am: Reflect having moved tests/. * sptests/sp07/Makefile.am: Reflect having moved tests/. * sptests/sp08/Makefile.am: Reflect having moved tests/. * sptests/sp09/Makefile.am: Reflect having moved tests/. * sptests/sp11/Makefile.am: Reflect having moved tests/. * sptests/sp12/Makefile.am: Reflect having moved tests/. * sptests/sp13/Makefile.am: Reflect having moved tests/. * sptests/sp14/Makefile.am: Reflect having moved tests/. * sptests/sp15/Makefile.am: Reflect having moved tests/. * sptests/sp16/Makefile.am: Reflect having moved tests/. * sptests/sp17/Makefile.am: Reflect having moved tests/. * sptests/sp19/Makefile.am: Reflect having moved tests/. * sptests/sp20/Makefile.am: Reflect having moved tests/. * sptests/sp21/Makefile.am: Reflect having moved tests/. * sptests/sp22/Makefile.am: Reflect having moved tests/. * sptests/sp23/Makefile.am: Reflect having moved tests/. * sptests/sp24/Makefile.am: Reflect having moved tests/. * sptests/sp25/Makefile.am: Reflect having moved tests/. * sptests/spsize/Makefile.am: Reflect having moved tests/. * support/Makefile.am: Reflect having moved tests/. * tmtests/Makefile.am: Reflect having moved tests/. * tmtests/tm01/Makefile.am: Reflect having moved tests/. * tmtests/tm02/Makefile.am: Reflect having moved tests/. * tmtests/tm03/Makefile.am: Reflect having moved tests/. * tmtests/tm04/Makefile.am: Reflect having moved tests/. * tmtests/tm05/Makefile.am: Reflect having moved tests/. * tmtests/tm06/Makefile.am: Reflect having moved tests/. * tmtests/tm07/Makefile.am: Reflect having moved tests/. * tmtests/tm08/Makefile.am: Reflect having moved tests/. * tmtests/tm09/Makefile.am: Reflect having moved tests/. * tmtests/tm10/Makefile.am: Reflect having moved tests/. * tmtests/tm11/Makefile.am: Reflect having moved tests/. * tmtests/tm12/Makefile.am: Reflect having moved tests/. * tmtests/tm13/Makefile.am: Reflect having moved tests/. * tmtests/tm14/Makefile.am: Reflect having moved tests/. * tmtests/tm15/Makefile.am: Reflect having moved tests/. * tmtests/tm16/Makefile.am: Reflect having moved tests/. * tmtests/tm17/Makefile.am: Reflect having moved tests/. * tmtests/tm18/Makefile.am: Reflect having moved tests/. * tmtests/tm19/Makefile.am: Reflect having moved tests/. * tmtests/tm20/Makefile.am: Reflect having moved tests/. * tmtests/tm21/Makefile.am: Reflect having moved tests/. * tmtests/tm22/Makefile.am: Reflect having moved tests/. * tmtests/tm23/Makefile.am: Reflect having moved tests/. * tmtests/tm24/Makefile.am: Reflect having moved tests/. * tmtests/tm25/Makefile.am: Reflect having moved tests/. * tmtests/tm28/Makefile.am: Reflect having moved tests/. * tmtests/tm29/Makefile.am: Reflect having moved tests/. * tmtests/tmck/Makefile.am: Reflect having moved tests/. * tmtests/tmoverhd/Makefile.am: Reflect having moved tests/. | ||||
* | 2003-08-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-20 | 1 | -3/+3 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Makefile.am, mptests/Makefile.am, mptests/mp01/Makefile.am, mptests/mp01/node1/Makefile.am, mptests/mp01/node2/Makefile.am, samples/Makefile.am, samples/base_mp/Makefile.am, samples/base_mp/node1/Makefile.am, samples/base_mp/node2/Makefile.am, samples/base_sp/Makefile.am, samples/hello/Makefile.am, samples/ticker/Makefile.am, sptests/Makefile.am, sptests/sp01/Makefile.am, sptests/sp02/Makefile.am, sptests/sp03/Makefile.am, sptests/sp04/Makefile.am, sptests/sp05/Makefile.am, sptests/sp06/Makefile.am, sptests/sp07/Makefile.am, sptests/sp08/Makefile.am, sptests/sp09/Makefile.am, sptests/sp11/Makefile.am, sptests/sp12/Makefile.am, sptests/sp13/Makefile.am, sptests/sp14/Makefile.am, sptests/sp15/Makefile.am, sptests/sp16/Makefile.am, sptests/sp17/Makefile.am, sptests/sp19/Makefile.am, sptests/sp20/Makefile.am, sptests/sp21/Makefile.am, sptests/sp22/Makefile.am, sptests/sp23/Makefile.am, sptests/sp24/Makefile.am, sptests/sp25/Makefile.am, sptests/spsize/Makefile.am, support/Makefile.am, tmtests/Makefile.am, tmtests/tm01/Makefile.am, tmtests/tm02/Makefile.am, tmtests/tm03/Makefile.am, tmtests/tm04/Makefile.am, tmtests/tm05/Makefile.am, tmtests/tm06/Makefile.am, tmtests/tm07/Makefile.am, tmtests/tm08/Makefile.am, tmtests/tm09/Makefile.am, tmtests/tm10/Makefile.am, tmtests/tm11/Makefile.am, tmtests/tm12/Makefile.am, tmtests/tm13/Makefile.am, tmtests/tm14/Makefile.am, tmtests/tm15/Makefile.am, tmtests/tm16/Makefile.am, tmtests/tm17/Makefile.am, tmtests/tm18/Makefile.am, tmtests/tm19/Makefile.am, tmtests/tm20/Makefile.am, tmtests/tm21/Makefile.am, tmtests/tm22/Makefile.am, tmtests/tm23/Makefile.am, tmtests/tm24/Makefile.am, tmtests/tm25/Makefile.am, tmtests/tm28/Makefile.am, tmtests/tm29/Makefile.am, tmtests/tmck/Makefile.am, tmtests/tmoverhd/Makefile.am: Pick up am-fragments from ../tests/automake. | ||||
* | 2003-08-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-20 | 1 | -2/+1 |
| | | | | | | * aclocal/prog-gnat.m4: New (copied from ../../../aclocal). * Makefile.am: ACLOCAL_AMFLAGS = -I aclocal -I ../tests/aclocal. Don't include */automake/lib.am (Unused). | ||||
* | 2003-01-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-03 | 1 | -1/+4 |
| | | | | | * Makefile.am, configure.ac, samples/Makefile.am: Do not configure them unless multiprocessing is enabled. | ||||
* | 2002-08-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-08-26 | 1 | -2/+2 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Makefile.am: Activate tmtests. * configure.ac: Activate tmtests. * samples/base_mp/Makefile.am: Add nodeX subdirs. * sptests/sp01/Makefile.am: Add *.scn. * sptests/sp02/Makefile.am: Add *.scn. * sptests/sp03/Makefile.am: Add *.scn. * sptests/sp04/Makefile.am: Add *.scn. * sptests/sp05/Makefile.am: Add *.scn. * sptests/sp06/Makefile.am: Add *.scn. * sptests/sp07/Makefile.am: Add *.scn. * sptests/sp08/Makefile.am: Add *.scn. * sptests/sp09/Makefile.am: Add *.scn. * sptests/sp11/Makefile.am: Add *.scn. * sptests/sp12/Makefile.am: Add *.scn. * sptests/sp13/Makefile.am: Add *.scn. * sptests/sp14/Makefile.am: Add *.scn. * sptests/sp15/Makefile.am: Add *.scn. * sptests/sp16/Makefile.am: Add *.scn. * sptests/sp17/Makefile.am: Add *.scn. * sptests/sp19/Makefile.am: Add *.scn. * sptests/sp20/Makefile.am: Add *.scn. * sptests/sp21/Makefile.am: Add *.scn. * sptests/sp22/Makefile.am: Add *.scn. * sptests/sp23/Makefile.am: Add *.scn. * sptests/sp24/Makefile.am: Add *.scn. * sptests/sp25/Makefile.am: Add *.scn. | ||||
* | 2002-08-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-08-26 | 1 | -0/+15 |
* Makefile.am: New. * configure.ac: New. * ada.am: New. * support/Makefile.am: New. * samples/Makefile.am: New. * samples/base_mp/Makefile.am: New. * samples/base_sp/Makefile.am: New. * samples/hello/Makefile.am: New. * samples/ticker/Makefile.am: New. |
