path: root/c/src/aclocal (follow)
* build: Remove ampolish3Sebastian Huber2018-12-142-12/+0
| | | | Update #3254.
* m32c: Remove this targetSebastian Huber2018-11-122-2/+1
| | | | Update #3599.
* check-networking.m4: Disable legacy stack for x86_64 and epiphanyJoel Sherrill2018-10-181-1/+5
| | | | | x86_64 is 64-bits and too new for the legacy stack to support. epiphany is a small target and cannot compile the legacy (or new) stack.
* clang: Keep -qrtems and -B for compilers without -specs supportJacob Hansen2018-09-201-2/+4
| | | | | | | | | This is needed for building rtems correctly with Clang. Note that this change does not mean rtems can build correctly with mainline clang. However the change allows building rtems with a Clang toolchain that has a rtems frontend similar that of GCC's builtin rtems specs.
* bsp/x86_64: Minimal bootable BSPAmaan Cheval2018-07-111-0/+1
| | | | | | | | | | | | | | | | Current state: - Basic context initialization and switching code. - Stubbed console (empty functions). - Mostly functional linker script (may need tweaks if we ever want to move away from the large code model (see: CPU_CFLAGS). - Fully functional boot, by using FreeBSD's bootloader to load RTEMS's ELF for UEFI-awareness. In short, the current state with this commit lets us boot, go through the system initialization functions, and then call user application's Init task too. Updates #2898.
* build: Enable RISC-V SMP buildSebastian Huber2018-06-281-1/+1
| | | | Update #3433.
* bsps: Move make/custom/* files to bspsSebastian Huber2018-04-232-8/+10
| | | | | | | | | Adjust various build files. Remove automatic generation of the c/src/lib/libbsp/*/acinclude.m4 files from bootstrap script. This patch is a part of the BSP source reorganization. Update #3285.
* bsps: Move MPCI support to bspsSebastian Huber2018-04-201-1/+1
* bsps: Move startup files to bspsSebastian Huber2018-04-202-4/+5
| | | | | | | | Adjust build support files to new directory layout. This patch is a part of the BSP source reorganization. Update #3285.
* Generate an error if a BSP in the --enable-rtemsbsp list is not validChris Johns2018-04-111-13/+0
| | | | | | | Also generate an error if the architecure does not match the --target architecture given to configure's command line. Close #2641.
* bsps: Move config macros to RTEMS_BSP_CONFIGURESebastian Huber2018-04-041-0/+9
| | | | | | | | Provide HAS_NETWORKING and HAS_SMP Automake conditionals for all BSPs. This patch is a part of the BSP source reorganization. Update #3285.
* bsps: Add RTEMS_BSP to bspopts.hSebastian Huber2018-04-041-0/+3
* Remove make preinstallChris Johns2018-01-258-9/+64
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | A speciality of the RTEMS build system was the make preinstall step. It copied header files from arbitrary locations into the build tree. The header files were included via the -Bsome/build/tree/path GCC command line option. This has at least seven problems: * The make preinstall step itself needs time and disk space. * Errors in header files show up in the build tree copy. This makes it hard for editors to open the right file to fix the error. * There is no clear relationship between source and build tree header files. This makes an audit of the build process difficult. * The visibility of all header files in the build tree makes it difficult to enforce API barriers. For example it is discouraged to use BSP-specifics in the cpukit. * An introduction of a new build system is difficult. * Include paths specified by the -B option are system headers. This may suppress warnings. * The parallel build had sporadic failures on some hosts. This patch removes the make preinstall step. All installed header files are moved to dedicated include directories in the source tree. Let @RTEMS_CPU@ be the target architecture, e.g. arm, powerpc, sparc, etc. Let @RTEMS_BSP_FAMILIY@ be a BSP family base directory, e.g. erc32, imx, qoriq, etc. The new cpukit include directories are: * cpukit/include * cpukit/score/cpu/@RTEMS_CPU@/include * cpukit/libnetworking The new BSP include directories are: * bsps/include * bsps/@RTEMS_CPU@/include * bsps/@RTEMS_CPU@/@RTEMS_BSP_FAMILIY@/include There are build tree include directories for generated files. The include directory order favours the most general header file, e.g. it is not possible to override general header files via the include path order. The "bootstrap -p" option was removed. The new "bootstrap -H" option should be used to regenerate the "headers.am" files. Update #3254.
* bsps: Add BSP_VERBOSE_FATAL_EXTENSIONSebastian Huber2017-11-221-1/+6
| | | | | | | | Add BSP_VERBOSE_FATAL_EXTENSION to RTEMS_BSP_CLEANUP_OPTIONS to optionally print the RTEMS version, the fatal source and the fatal code in the shared bsp_fatal_extension(). Close #3248.
* bsps: Simplify RTEMS_BSP_CLEANUP_OPTIONSSebastian Huber2017-11-221-19/+12
| | | | | | | | | Remove BSP-specific defaults for RTEMS_BSP_CLEANUP_OPTIONS to simplify the BSP configuration and documentation. Change defaults to: BSP_PRESS_KEY_FOR_RESET=0 BSP_RESET_BOARD_AT_EXIT=1 BSP_PRINT_EXCEPTION_CONTEXT=1
* Change RTEMS_API from 5.0 to 5Sebastian Huber2017-11-131-1/+1
| | | | | | | This fixes the legacy Makefile based build system which expects RTEMS_API to be identical to the tool chain version. Update #3220.
* Upgrade to 5.0.0Sebastian Huber2017-11-091-2/+2
| | | | | | | Tool name will be "rtems5", e.g. arm-rtems5-gcc. Next release will 5.1.0. Branch version after release will be 5.1.1. Next master will be 6.0.0.
* bsp: Make riscv_generic work for both riscv32 and riscv64 - v2Hesham Almatary2017-11-011-0/+2
| | | | Update #3109
* cpukit: RISC-V - make riscv32 code work for riscv64 - v2Hesham Almatary2017-11-011-1/+1
| | | | | | | | | * Use #ifdefs for 32/64 bit code * Use unsigned long which is 32-bit on riscv32 and 64-bit on riscv64 (register size) * Move the code to a new shared riscv folder to be shared between riscv32 and riscv64 * Rename RTEMS_CPU extracted from command line to shared riscv target s/riscv*/riscv Update #3109
* Add riscv32 to autotools files v3Hesham Almatary2017-10-281-0/+1
* Fix warnings for using C/ObjC specific GCC flags with C++Joel Sherrill2017-10-111-0/+6
| | | | Closes #3181.
* build-system: Always enable C++ if the compiler is present.Chris Johns2016-08-112-18/+24
| | | | | | | | | | | We always build a C++ compiler and building with C++ does not effect RTEMS or the runtime. This patch always enabled the support. There is no need to manually enable it any more. You can disable C++ with '--disable-cxx'. If an architecture does not have a C++ compiler support is automatically disabled.
* bsps: Resurrect ARM portSebastian Huber2016-01-201-1/+1
| | | | | | | Remove AVR port instead. Bug introduced by 15068f4c9afd2d5ca6a77d510059d6306c9a3be6. Update #2443.
* Remove AVR portJoel Sherrill2016-01-192-2/+1
| | | | closes #2443.
* Remove H8300 portJoel Sherrill2016-01-042-2/+1
| | | | updates #2452.
* Remove M32R architectureJoel Sherrill2016-01-041-1/+0
| | | | updates #2446.
* Upgrade to 4.11.99.0Sebastian Huber2015-09-111-2/+2
* Epiphany: Add the first epiphany_sim BSP v4Hesham ALMatary2015-05-211-0/+1
| | | | | | This BSP in intended to run on the simulator that should be built from RSB. When building RTEMS for Epiphany --disable-networking must be provided part of the configure command.
* DRVMGR: added driver manager to cpukit/libdrvmgrDaniel Hellstrom2015-04-171-0/+12
* Always disable networking for h8300Joel Sherrill2015-03-061-1/+2
* Add -std=gnu++11 to CXXFLAGS if SMP is enabledSebastian Huber2014-09-081-2/+9
| | | | | This is necessary to use the <atomic> header file used for the atomic operations.
* Add new (first) OpenRISC BSP called or1ksim.Hesham ALMatary2014-08-201-0/+1
| | | | | This BSP is intended to run on or1ksim (the main OpenRISC emulator). Fixed version according to Joel comments from the mailing list.
* c/src/aclocal/check-smp.m4: Use HAS_SMP not HAS_POSIX_APIJoel Sherrill2014-05-221-1/+1
* configure: DocumentationSebastian Huber2013-06-122-2/+6
* smp: Add ARM supportSebastian Huber2013-05-311-1/+1
* smp: Add PowerPC supportSebastian Huber2013-05-311-1/+1
* Common file changes in support of Moxie portAnthony Green2013-02-281-0/+1
| | | | Signed-off-by: Anthony Green <green@moxielogic.com>
* score: Add CPU_Exception_frameSebastian Huber2012-11-271-1/+6
| | | | | | | | | | | | | | | | | | | | | Add CPU port type CPU_Exception_frame and function _CPU_Exception_frame_print(). The CPU ports of avr, bfin, h8300, lm32, m32c, m32r, m68k, nios2, sh, sparc64, and v850 use an empty default implementation of _CPU_Exception_frame_print(). Add rtems_exception_frame and rtems_exception_frame_print(). Add RTEMS_FATAL_SOURCE_EXCEPTION for CPU exceptions. Use rtems_fatal() with source RTEMS_FATAL_SOURCE_EXCEPTION in CPU ports of i386, powerpc, and sparc for unexpected exceptions. Add third parameter to RTEMS_BSP_CLEANUP_OPTIONS() which controls the BSP_PRINT_EXCEPTION_CONTEXT define used in the default bsp_fatal_extension(). Add test sptests/spfatal26.
* v850 port: Initial addition with BSP for simulator in GDBJoel Sherrill2012-06-111-0/+1
| | | | | | | | | | | | | | | | | | Port + v850 does not have appear to have any optimized bit scan instructions + v850 does have single instructions for wap u16 and u32 + Code path optimization preferences set + Add BSP variants for each GCC CPU model flag and a README - v850e1 variant does not work (fails during BSP initialization) BSP for GDB v850 Simulator + linkcmds matches defaults in GDB simulator with RTEMS mods + crt1.c added from v850 newlib port for __main() + BSP exits cleanly + printk and console I/O work + uses clock tick from IDLE task + Tests not requiring real clock ISR work Documentation + CPU Supplment chapter for v850 added
* Remove references to configure.in.Ralf Corsépius2012-05-183-3/+3
* Remove obsolete reference to posix bsp.Ralf Corsépius2012-05-181-2/+1
* Remove CVS Id Strings (manual edits after script)Joel Sherrill2012-05-1114-18/+0
| | | | | | These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns.
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-1136-72/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-0737-0/+93
* Remove CVS-Ids.Ralf Corsépius2012-05-0437-93/+0
* 2011-06-07 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-06-071-0/+18
| | | | | | | | * aclocal/bspopts.m4: Added macros for cache options RTEMS_BSPOPTS_SET_DATA_CACHE_ENABLED, RTEMS_BSPOPTS_HELP_DATA_CACHE_ENABLED, RTEMS_BSPOPTS_SET_INSTRUCTION_CACHE_ENABLED, and RTEMS_BSPOPTS_HELP_INSTRUCTION_CACHE_ENABLED.
* 2011-03-16 Jennifer Averett <jennifer.averett@OARcorp.com>Joel Sherrill2011-03-162-0/+37
| | | | | PR 1729/cpukit * aclocal/check-smp.m4, aclocal/enable-smp.m4: New files.
* 2011-03-07 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-03-071-0/+1
| | | | * aclocal/rtems-top.m4: Add pkgdatadir.
* 2011-03-04 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-03-042-2/+2
| | | | | * aclocal/rtems-top.m4, aclocal/version.m4: Rename RTEMS_API into _RTEMS_API.
* 2011-02-25 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-251-8/+10
| | | | | | | * aclocal/canonical-target-name.m4: Stop pretending no_cpu* was buildable. Derive RTEMS_CPU from "$host_cpu". Error out if "$host" doesn't match "*-*-rtems*".
