* aclocal/lead-dot.m4: Remove (Provided by automake-1.8).
* automake/compile.am: Use mkdir_p instead of mkinstalldirs.
* automake/lib.am: Use mkdir_p instead of mkdir.
Remove $(PROJECT_RELEASE)/lib/$(dirstamp) handling.
* aclocal/env-rtemsbsp.m4: Remove bsplibdir.
Cleanups.
* aclocal/env-rtemsbsp.m4: AC_SUBST(project_libdir).
* automake/lib.am: Remove project_libdir.
* wrapup/Makefile.am: Reworked.
* aclocal/lead-dot.m4: New (from automake-1.7f).
* aclocal/rtems-top.m4: Require AM_SET_LEADING_DOT.
Add AC_SUBST(dirstamp).
* aclocal/bsp-arg-enable.m4, aclocal/canonical-target-name.m4,
aclocal/canonicalize-tools.m4, aclocal/check-custom-bsp.m4,
aclocal/check-posix.m4, aclocal/check-rdbg.m4,
aclocal/check-tool.m4, aclocal/config-subdirs.m4,
aclocal/enable-bare.m4, aclocal/enable-cxx.m4,
aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4,
aclocal/enable-networking.m4, aclocal/enable-posix.m4,
aclocal/enable-rdbg.m4, aclocal/enable-rtemsbsp.m4,
aclocal/env-rtemsbsp.m4, aclocal/gcc-isystem.m4,
aclocal/gcc-pipe.m4, aclocal/gcc-specs.m4,
aclocal/i386-gas-code16.m4, aclocal/multilib.m4,
aclocal/path-ksh.m4, aclocal/prog-cc.m4,
aclocal/prog-cxx.m4, aclocal/project-root.m4,
aclocal/rtems-top.m4, aclocal/target.m4,
aclocal/tool-paths.m4:
Fix underquoting to silence automake-1.8.
* aclocal/bsp-configure.m4: AC_PREREQ(2.57).
Remove RTEMS_CANONICAL_HOST.
* aclocal/canonical-host.m4: Remove.
* aclocal/canonical-target-name.m4: Merge-in aclocal/canonical-host.m4.
* aclocal/check-cpu.m4: Remove.
* configure.ac: Merge-in former aclocal/check-cpu.m4.
* aclocal/canonical-target-name.m4: Add m4-quotes.
* aclocal/check-cxx.m4: Add m4-quotes.
Don't require RTEMS_CHECK_CPU.
* aclocal/check-multiprocessing.m4: Add m4-quotes.
Require RTEMS_CANONICAL_TARGET_CPU instead of RTEMS_CHECK_CPU.
* aclocal/check-networking.m4: Add m4-quotes.
* aclocal/check-posix.m4: Add m4-quotes.
* aclocal/check-rdbg.m4: Add m4-quotes.
* aclocal/check-multiprocessing.m4: Remove RTEMS_BSP_ALIAS.
* aclocal/bsp-alias.m4: Remove.
* aclocal/path-perl.m4: Remove (Unused).
* aclocal/rtems-top.m4: Add RTEMS_API.
AC_DEFAULT_PREFIX([/opt/rtems-][RTEMS_API]).
* aclocal/check-itron.m4: Remove.
* aclocal/enable-inlines.m4: Remove.
* aclocal/bsp-alias.m4: New (Copied from ../../aclocal).
* aclocal/bsp-arg-enable.m4: New (Copied from ../../aclocal).
* aclocal/bsp-configure.m4: New (Copied from ../../aclocal).
* aclocal/bspopts.m4: New (Copied from ../../aclocal).
* aclocal/canonical-host.m4: New (Copied from ../../aclocal).
* aclocal/canonicalize-tools.m4: New (Copied from ../../aclocal).
* aclocal/canonical-target-name.m4: New (Copied from ../../aclocal).
* aclocal/check-cpu.m4: New (Copied from ../../aclocal).
* aclocal/check-custom-bsp.m4: New (Copied from ../../aclocal).
* aclocal/check-cxx.m4: New (Copied from ../../aclocal).
* aclocal/check-itron.m4: New (Copied from ../../aclocal).
* aclocal/check-multiprocessing.m4: New (Copied from ../../aclocal).
* aclocal/check-networking.m4: New (Copied from ../../aclocal).
* aclocal/check-posix.m4: New (Copied from ../../aclocal).
* aclocal/check-rdbg.m4: New (Copied from ../../aclocal).
* aclocal/check-tool.m4: New (Copied from ../../aclocal).
* aclocal/config-subdirs.m4: New (Copied from ../../aclocal).
* aclocal/enable-bare.m4: New (Copied from ../../aclocal).
* aclocal/enable-cxx.m4: New (Copied from ../../aclocal).
* aclocal/enable-inlines.m4: New (Copied from ../../aclocal).
* aclocal/enable-itron.m4: New (Copied from ../../aclocal).
* aclocal/enable-multiprocessing.m4: New (Copied from ../../aclocal).
* aclocal/enable-networking.m4: New (Copied from ../../aclocal).
* aclocal/enable-posix.m4: New (Copied from ../../aclocal).
* aclocal/enable-rdbg.m4: New (Copied from ../../aclocal).
* aclocal/enable-rtemsbsp.m4: New (Copied from ../../aclocal).
* aclocal/env-rtemsbsp.m4: New (Copied from ../../aclocal).
* aclocal/gcc-isystem.m4: New (Copied from ../../aclocal).
* aclocal/gcc-pipe.m4: New (Copied from ../../aclocal).
* aclocal/gcc-specs.m4: New (Copied from ../../aclocal).
* aclocal/i386-gas-code16.m4: New (Copied from ../../aclocal).
* aclocal/multilib.m4: New (Copied from ../../aclocal).
* aclocal/path-ksh.m4: New (Copied from ../../aclocal).
* aclocal/path-perl.m4: New (Copied from ../../aclocal).
* aclocal/ppc.m4: New (Copied from ../../aclocal).
* aclocal/prog-ccas.m4: New (Copied from ../../aclocal).
* aclocal/prog-cc.m4: New (Copied from ../../aclocal).
* aclocal/prog-cxx.m4: New (Copied from ../../aclocal).
* aclocal/project-root.m4: New (Copied from ../../aclocal).
* aclocal/quoting.m4: New (Copied from ../../aclocal).
* aclocal/rtems-cpu-subdirs.m4: New (Copied from ../../aclocal).
* aclocal/rtems-flags.m4: New (Copied from ../../aclocal).
* aclocal/rtems-top.m4: New (Copied from ../../aclocal).
* aclocal/target.m4: New (Copied from ../../aclocal).
* aclocal/tool-paths.m4: New (Copied from ../../aclocal).
* aclocal/version.m4: New (Copied from ../../aclocal).
