* aclocal/bsp-linkcmds.m4: New.
* aclocal/bsp-alias.m4: New.
* configure.ac: Apply RTEMS_BSP_ALIAS for RTEMS_BSP_FAMILY.
* aclocal/env-rtemsbsp.m4: Remove AM_CONDITIONAL MULTILIB.
* configure.ac: Pick up make/custom/*.
* aclocal/check-custom-bsp.m4: Adapt to changes to configure.ac.
* aclocal/canonical-target-name.m4: Remove RTEMS_HOST (unused).
* aclocal/check-custom-bsp.m4: Let _RTEMS_CHECK_CUSTOM_BSP look for
*.cfg into c/src/lib/libbsp/<cpu>/<bsp_family>/make/custom.
* aclocal/bsp-configure.m4: Add RTEMS_BSP_BOOTCARD_OPTIONS.
* aclocal/check-networking.m4: Disable TCP/IP on targets without enough
physical address to support BSD TCP/IP stack.
* aclocal/bsp-bootcard-options.m4: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
now use the same macros.
* aclocal/bsp-bspcleanup-options.m4: New file.
* aclocal/bspopts.m4: Quoting cosmetics.
* aclocal/rtems-cpu-subdirs.m4: Add Lattice Mico32 support.
* src/aclocal/rtems-cpu-subdirs.m4: Add new M32R port. It is just a
beginning but the BSP is functional enough to initialize and shutdown
RTEMS.
* aclocal/rtems-cpu-subdirs.m4: Add new M32C port.
* aclocal/bsp-bootcard-options.m4: Generalize and correct comment.
* aclocal/bsp-bootcard-options.m4: Fix quoting.
* aclocal/bsp-bootcard-options.m4: New file.
* aclocal/bsp-bootcards-handles-ram-allocation.m4: Removed.
* aclocal/version.m4: Bump RTEMS_API to 4.10.
Bump _RTEMS_VERSION to 4.9.99.0.
* aclocal/prog-cc.m4: Add -Wnested-externs.
* aclocal/prog-cc.m4: Add -Wimplicit-function-declaration
-Wstrict-prototypes to RTEMS_CFLAGS.
* aclocal/bsp-bootcards-handles-ram-allocation.m4: New file.
* aclocal/version.m4: Bump RTEMS_API to 4.9.
Bump RTEMS_VERSION to 4.8.99.0.
* configure.ac, wrapup/Makefile.am: Remove RDBG.
* aclocal/check-rdbg.m4, aclocal/enable-rdbg.m4, librdbg/.cvsignore,
librdbg/Makefile.am, librdbg/preinstall.am,
librdbg/include/rdbg/rdbg.h, librdbg/include/rdbg/servrpc.h,
librdbg/include/rdbg/i386/rdbg_f.h, librdbg/include/rdbg/i386/reg.h,
librdbg/include/rdbg/m68k/rdbg_f.h, librdbg/include/rdbg/m68k/reg.h,
librdbg/include/rdbg/powerpc/rdbg_f.h,
librdbg/include/rdbg/powerpc/reg.h, librdbg/src/_servtgt.c,
librdbg/src/awk.svc, librdbg/src/excep.c, librdbg/src/ptrace.c,
librdbg/src/rdbg.c, librdbg/src/remdeb.x, librdbg/src/servbkpt.c,
librdbg/src/servcon.c, librdbg/src/servrpc.c, librdbg/src/servtgt.c,
librdbg/src/servtsp.c, librdbg/src/servutil.c,
librdbg/src/i386/excep_f.c, librdbg/src/i386/rdbg_cpu_asm.S,
librdbg/src/i386/rdbg_f.c, librdbg/src/i386/any/remdeb.h,
librdbg/src/i386/any/remdeb_f.x, librdbg/src/i386/any/remdeb_svc.c,
librdbg/src/i386/any/remdeb_xdr.c, librdbg/src/m68k/excep_f.c,
librdbg/src/m68k/rdbg_cpu_asm.S, librdbg/src/m68k/rdbg_f.c,
librdbg/src/m68k/any/remdeb.h, librdbg/src/m68k/any/remdeb_f.x,
librdbg/src/m68k/any/remdeb_svc.c, librdbg/src/m68k/any/remdeb_xdr.c,
librdbg/src/powerpc/excep_f.c, librdbg/src/powerpc/rdbg_cpu_asm.S,
librdbg/src/powerpc/rdbg_f.c,
librdbg/src/powerpc/new_exception_processing/remdeb.h,
librdbg/src/powerpc/new_exception_processing/remdeb_f.x,
librdbg/src/powerpc/new_exception_processing/remdeb_svc.c,
librdbg/src/powerpc/new_exception_processing/remdeb_xdr.c: Removed.
* aclocal/target.m4: Strip CFLAGS (Hack to prevent bsp-cflags from
being used to compile "tools").
Remove checks for AMPOLISH3.
* aclocal/target.m4: Remove RTEMS_OUTPUT_BUILD_SUBDIRS.
* aclocal/prog-cc.m4: Remove CFLAGS.
* configure.ac: Don't explictly pass CFLAGS_OPTIMIZE_V, CPU_CFLAGS.
Compose CFLAGS. Append CFLAGS to ac_configure_args.
* aclocal/rtems-cpu-subdirs.m4: Add bfin.
* aclocal/rtems-top.m4: Remove RTEMS_API.
* aclocal/version.m4: Add RTEMS_API. Bump RTEMS_API to 4.8.
* aclocal/prog-ccas.m4: Adaptations to automake-1.10.
* aclocal/prog-cxx.m4: Add AC_PROG_CXXCPP.
* aclocal/version.m4: Bump version to 4.7.99.0.
* aclocal/rtems-cpu-subdirs.m4: New port to Altera NIOS II.
