* | 2008-09-10 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-10 | 1 | -2/+0 |
| | | | | * aclocal/prog-cc.m4: Remove pre-production testing CFLAGS. | ||||
* | 2008-08-18 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-08-18 | 1 | -1/+1 |
| | | | | * aclocal/prog-cc.m4: Add -Wnested-externs. | ||||
* | 2008-08-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-08-16 | 1 | -2/+4 |
| | | | | | * aclocal/prog-cc.m4: Add -Wimplicit-function-declaration -Wstrict-prototypes to RTEMS_CFLAGS. | ||||
* | 2006-11-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-11-15 | 1 | -2/+0 |
| | | | | | | * aclocal/prog-cc.m4: Remove CFLAGS. * configure.ac: Don't explictly pass CFLAGS_OPTIMIZE_V, CPU_CFLAGS. Compose CFLAGS. Append CFLAGS to ac_configure_args. | ||||
* | Remove RTEMS_USE_GCC. Add RTEMS_RELLDFLAGS. | Ralf Corsepius | 2005-11-20 | 1 | -2/+5 |
* | Add GCCSPECS | Ralf Corsepius | 2005-11-08 | 1 | -1/+6 |
* | 2005-02-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-08 | 1 | -1/+1 |
| | | | | | * aclocal/prog-cc.m4: Quote CFLAGS's RHS to accomodate Solaris broken sh. | ||||
* | 2005-01-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-05 | 1 | -2/+2 |
| | | | | | | | | | | | | | * configure.ac: Pass CFLAGS to cpukit configure. * aclocal/rtems-flags.m4: Remove (Unused). * aclocal/prog-ccas.m4: Remove $(GCCSPECS). * aclocal/env-rtemsbsp.m4: Comment out CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CPU_CFLAGS. * aclocal/prog-cc.m4: Don't invoke _RTEMS_FLAGS to set up RTEMS_CFLAGS. * automake/compile.am: AM_CFLAGS = RTEMS_CFLAGS. Add AM_CXXFLAGS. Remove CPPFLAGS, CFLAGS, CPU_CFLAGS, CFLAGS_OPTIMIZE, ASFLAGS. Cleanup comments. | ||||
* | 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-26 | 1 | -2/+2 |
| | | | | | | | | | | | | | | | | | | | * aclocal/bsp-arg-enable.m4, aclocal/canonical-target-name.m4, aclocal/canonicalize-tools.m4, aclocal/check-custom-bsp.m4, aclocal/check-posix.m4, aclocal/check-rdbg.m4, aclocal/check-tool.m4, aclocal/config-subdirs.m4, aclocal/enable-bare.m4, aclocal/enable-cxx.m4, aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4, aclocal/enable-posix.m4, aclocal/enable-rdbg.m4, aclocal/enable-rtemsbsp.m4, aclocal/env-rtemsbsp.m4, aclocal/gcc-isystem.m4, aclocal/gcc-pipe.m4, aclocal/gcc-specs.m4, aclocal/i386-gas-code16.m4, aclocal/multilib.m4, aclocal/path-ksh.m4, aclocal/prog-cc.m4, aclocal/prog-cxx.m4, aclocal/project-root.m4, aclocal/rtems-top.m4, aclocal/target.m4, aclocal/tool-paths.m4: Fix underquoting to silence automake-1.8. | ||||
* | 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-18 | 1 | -0/+48 |
* aclocal/bsp-alias.m4: New (Copied from ../../aclocal). * aclocal/bsp-arg-enable.m4: New (Copied from ../../aclocal). * aclocal/bsp-configure.m4: New (Copied from ../../aclocal). * aclocal/bspopts.m4: New (Copied from ../../aclocal). * aclocal/canonical-host.m4: New (Copied from ../../aclocal). * aclocal/canonicalize-tools.m4: New (Copied from ../../aclocal). * aclocal/canonical-target-name.m4: New (Copied from ../../aclocal). * aclocal/check-cpu.m4: New (Copied from ../../aclocal). * aclocal/check-custom-bsp.m4: New (Copied from ../../aclocal). * aclocal/check-cxx.m4: New (Copied from ../../aclocal). * aclocal/check-itron.m4: New (Copied from ../../aclocal). * aclocal/check-multiprocessing.m4: New (Copied from ../../aclocal). * aclocal/check-networking.m4: New (Copied from ../../aclocal). * aclocal/check-posix.m4: New (Copied from ../../aclocal). * aclocal/check-rdbg.m4: New (Copied from ../../aclocal). * aclocal/check-tool.m4: New (Copied from ../../aclocal). * aclocal/config-subdirs.m4: New (Copied from ../../aclocal). * aclocal/enable-bare.m4: New (Copied from ../../aclocal). * aclocal/enable-cxx.m4: New (Copied from ../../aclocal). * aclocal/enable-inlines.m4: New (Copied from ../../aclocal). * aclocal/enable-itron.m4: New (Copied from ../../aclocal). * aclocal/enable-multiprocessing.m4: New (Copied from ../../aclocal). * aclocal/enable-networking.m4: New (Copied from ../../aclocal). * aclocal/enable-posix.m4: New (Copied from ../../aclocal). * aclocal/enable-rdbg.m4: New (Copied from ../../aclocal). * aclocal/enable-rtemsbsp.m4: New (Copied from ../../aclocal). * aclocal/env-rtemsbsp.m4: New (Copied from ../../aclocal). * aclocal/gcc-isystem.m4: New (Copied from ../../aclocal). * aclocal/gcc-pipe.m4: New (Copied from ../../aclocal). * aclocal/gcc-specs.m4: New (Copied from ../../aclocal). * aclocal/i386-gas-code16.m4: New (Copied from ../../aclocal). * aclocal/multilib.m4: New (Copied from ../../aclocal). * aclocal/path-ksh.m4: New (Copied from ../../aclocal). * aclocal/path-perl.m4: New (Copied from ../../aclocal). * aclocal/ppc.m4: New (Copied from ../../aclocal). * aclocal/prog-ccas.m4: New (Copied from ../../aclocal). * aclocal/prog-cc.m4: New (Copied from ../../aclocal). * aclocal/prog-cxx.m4: New (Copied from ../../aclocal). * aclocal/project-root.m4: New (Copied from ../../aclocal). * aclocal/quoting.m4: New (Copied from ../../aclocal). * aclocal/rtems-cpu-subdirs.m4: New (Copied from ../../aclocal). * aclocal/rtems-flags.m4: New (Copied from ../../aclocal). * aclocal/rtems-top.m4: New (Copied from ../../aclocal). * aclocal/target.m4: New (Copied from ../../aclocal). * aclocal/tool-paths.m4: New (Copied from ../../aclocal). * aclocal/version.m4: New (Copied from ../../aclocal). |
