* aclocal/check-multiprocessing.m4: Remove AC_SUBST(HAS_MP).
Add AM_CONDITIONAL(HAS_MP).
* wrapup/Makefile.am: Fix path to ../libchip/shmdr.rel.
* configure.ac: Remove AM_CONDITIONAL(HAS_MP).
* aclocal/enable-cxx.m4, aclocal/enable-itron.m4,
aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4,
aclocal/enable-posix.m4, aclocal/enable-rdbg.m4,
aclocal/multilib.m4: Use AS_HELP_STRING instead of AC_HELP_STRING
(Deprecated by autoconf 2.59).
* aclocal/bsp-arg-enable.m4, aclocal/canonical-target-name.m4,
aclocal/canonicalize-tools.m4, aclocal/check-custom-bsp.m4,
aclocal/check-posix.m4, aclocal/check-rdbg.m4,
aclocal/check-tool.m4, aclocal/config-subdirs.m4,
aclocal/enable-bare.m4, aclocal/enable-cxx.m4,
aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4,
aclocal/enable-networking.m4, aclocal/enable-posix.m4,
aclocal/enable-rdbg.m4, aclocal/enable-rtemsbsp.m4,
aclocal/env-rtemsbsp.m4, aclocal/gcc-isystem.m4,
aclocal/gcc-pipe.m4, aclocal/gcc-specs.m4,
aclocal/i386-gas-code16.m4, aclocal/multilib.m4,
aclocal/path-ksh.m4, aclocal/prog-cc.m4,
aclocal/prog-cxx.m4, aclocal/project-root.m4,
aclocal/rtems-top.m4, aclocal/target.m4,
aclocal/tool-paths.m4:
Fix underquoting to silence automake-1.8.
* aclocal/bsp-alias.m4: New (Copied from ../../aclocal).
* aclocal/bsp-arg-enable.m4: New (Copied from ../../aclocal).
* aclocal/bsp-configure.m4: New (Copied from ../../aclocal).
* aclocal/bspopts.m4: New (Copied from ../../aclocal).
* aclocal/canonical-host.m4: New (Copied from ../../aclocal).
* aclocal/canonicalize-tools.m4: New (Copied from ../../aclocal).
* aclocal/canonical-target-name.m4: New (Copied from ../../aclocal).
* aclocal/check-cpu.m4: New (Copied from ../../aclocal).
* aclocal/check-custom-bsp.m4: New (Copied from ../../aclocal).
* aclocal/check-cxx.m4: New (Copied from ../../aclocal).
* aclocal/check-itron.m4: New (Copied from ../../aclocal).
* aclocal/check-multiprocessing.m4: New (Copied from ../../aclocal).
* aclocal/check-networking.m4: New (Copied from ../../aclocal).
* aclocal/check-posix.m4: New (Copied from ../../aclocal).
* aclocal/check-rdbg.m4: New (Copied from ../../aclocal).
* aclocal/check-tool.m4: New (Copied from ../../aclocal).
* aclocal/config-subdirs.m4: New (Copied from ../../aclocal).
* aclocal/enable-bare.m4: New (Copied from ../../aclocal).
* aclocal/enable-cxx.m4: New (Copied from ../../aclocal).
* aclocal/enable-inlines.m4: New (Copied from ../../aclocal).
* aclocal/enable-itron.m4: New (Copied from ../../aclocal).
* aclocal/enable-multiprocessing.m4: New (Copied from ../../aclocal).
* aclocal/enable-networking.m4: New (Copied from ../../aclocal).
* aclocal/enable-posix.m4: New (Copied from ../../aclocal).
* aclocal/enable-rdbg.m4: New (Copied from ../../aclocal).
* aclocal/enable-rtemsbsp.m4: New (Copied from ../../aclocal).
* aclocal/env-rtemsbsp.m4: New (Copied from ../../aclocal).
* aclocal/gcc-isystem.m4: New (Copied from ../../aclocal).
* aclocal/gcc-pipe.m4: New (Copied from ../../aclocal).
* aclocal/gcc-specs.m4: New (Copied from ../../aclocal).
* aclocal/i386-gas-code16.m4: New (Copied from ../../aclocal).
* aclocal/multilib.m4: New (Copied from ../../aclocal).
* aclocal/path-ksh.m4: New (Copied from ../../aclocal).
* aclocal/path-perl.m4: New (Copied from ../../aclocal).
* aclocal/ppc.m4: New (Copied from ../../aclocal).
* aclocal/prog-ccas.m4: New (Copied from ../../aclocal).
* aclocal/prog-cc.m4: New (Copied from ../../aclocal).
* aclocal/prog-cxx.m4: New (Copied from ../../aclocal).
* aclocal/project-root.m4: New (Copied from ../../aclocal).
* aclocal/quoting.m4: New (Copied from ../../aclocal).
* aclocal/rtems-cpu-subdirs.m4: New (Copied from ../../aclocal).
* aclocal/rtems-flags.m4: New (Copied from ../../aclocal).
* aclocal/rtems-top.m4: New (Copied from ../../aclocal).
* aclocal/target.m4: New (Copied from ../../aclocal).
* aclocal/tool-paths.m4: New (Copied from ../../aclocal).
* aclocal/version.m4: New (Copied from ../../aclocal).
* aclocal/rtems-cpu-subdirs.m4: Print out RTEMS_CPU in error message.
* aclocal/enable-cxx.m4: Use $enable_cxx instead of $enableval.
* aclocal/enable-bare.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-cxx.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-inlines.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-itron.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-multiprocessing.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-networking.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-posix.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-rdbg.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-rtemsbsp.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-tests.m4: Improve quoting of AC_HELP_STRING.
(autoconf > 2.54 seems to have problems with the old form of
quoting).
* configure.in: autoupdate to autoconf-2.52.
* bootstrap: Add handling for configure.ac, make autoheader verbose,
fix auto*tool invocation order.
* aclocal/rtems-test-no-pause.m4: Introduce AC_HELP_STRING.
* aclocal/enable-bare.m4: Introduce AC_HELP_STRING.
* aclocal/enable-cxx.m4: Introduce AC_HELP_STRING.
* aclocal/enable-gcc28: Introduce AC_HELP_STRING.
* aclocal/enable-inlines.m4: Introduce AC_HELP_STRING.
* aclocal/enable-itron.m4: Introduce AC_HELP_STRING.
* aclocal/enable-libcdir.m4: Introduce AC_HELP_STRING.
* aclocal/enable-multiprocessing.m4: Introduce AC_HELP_STRING.
* aclocal/enable-networking.m4: Introduce AC_HELP_STRING.
* aclocal/enable-posix.m4: Introduce AC_HELP_STRING.
* aclocal/enable-rdbg.m4: Introduce AC_HELP_STRING.
* aclocal/enable-rtemsbsp.m4: Introduce AC_HELP_STRING.
* aclocal/enable-tests.m4: Introduce AC_HELP_STRING.
* aclocal/env-rtemsbsp.m4: Add AC_ARC_VAR(RTEMS_BSP), apply true in
RTEMS_CONFIG_PER_BSP conditional.
* aclocal/multilib.m4: Introduce AC_HELP_STRING.
* aclocal/rtems-debug.m4: Introduce AC_HELP_STRING.
* aclocal/rtems-top.m4: Add AC_PREFIX_DEFAULT(/opt/rtems).
OK, I 've made up my mind to cut a big chunk of my automake-patches (:-).
Below you can find a drop-in replacement of the aclocal directory. It
contains a lot of new macro files, most of them are directly cut from rtems
top-level configure script, some are new some are identical to former
versions. The motivation behind these files is to reuse parts from rtems
current top-level configure.in script in up-coming subdirectory configure.in
scripts.
I'd like to ask you to untar the archive ontop of the source tree and to
add/commit these files to CVS. Adding these files should not have any
influence on RTEMS momentary configuration (except of you are required to
run aclocal -I aclocal && autoconf afterwards), because most of them
currently are not used at all.
BTW: Please upgrade to autoconf-2.13 and automake-2.4, if you havn't done
this already (egcs/CVS require them, too). My upcoming automake files
require automake-2.4 which requires autoconf-2.13 or later.
