* aclocal/bsp-arg-enable.m4, aclocal/canonical-target-name.m4,
aclocal/canonicalize-tools.m4, aclocal/check-custom-bsp.m4,
aclocal/check-posix.m4, aclocal/check-rdbg.m4,
aclocal/check-tool.m4, aclocal/config-subdirs.m4,
aclocal/enable-bare.m4, aclocal/enable-cxx.m4,
aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4,
aclocal/enable-networking.m4, aclocal/enable-posix.m4,
aclocal/enable-rdbg.m4, aclocal/enable-rtemsbsp.m4,
aclocal/env-rtemsbsp.m4, aclocal/gcc-isystem.m4,
aclocal/gcc-pipe.m4, aclocal/gcc-specs.m4,
aclocal/i386-gas-code16.m4, aclocal/multilib.m4,
aclocal/path-ksh.m4, aclocal/prog-cc.m4,
aclocal/prog-cxx.m4, aclocal/project-root.m4,
aclocal/rtems-top.m4, aclocal/target.m4,
aclocal/tool-paths.m4:
Fix underquoting to silence automake-1.8.
* aclocal/canonical-target-name.m4: Add m4-quotes.
* aclocal/check-cxx.m4: Add m4-quotes.
Don't require RTEMS_CHECK_CPU.
* aclocal/check-multiprocessing.m4: Add m4-quotes.
Require RTEMS_CANONICAL_TARGET_CPU instead of RTEMS_CHECK_CPU.
* aclocal/check-networking.m4: Add m4-quotes.
* aclocal/check-posix.m4: Add m4-quotes.
* aclocal/check-rdbg.m4: Add m4-quotes.
* aclocal/bsp-alias.m4: New (Copied from ../../aclocal).
* aclocal/bsp-arg-enable.m4: New (Copied from ../../aclocal).
* aclocal/bsp-configure.m4: New (Copied from ../../aclocal).
* aclocal/bspopts.m4: New (Copied from ../../aclocal).
* aclocal/canonical-host.m4: New (Copied from ../../aclocal).
* aclocal/canonicalize-tools.m4: New (Copied from ../../aclocal).
* aclocal/canonical-target-name.m4: New (Copied from ../../aclocal).
* aclocal/check-cpu.m4: New (Copied from ../../aclocal).
* aclocal/check-custom-bsp.m4: New (Copied from ../../aclocal).
* aclocal/check-cxx.m4: New (Copied from ../../aclocal).
* aclocal/check-itron.m4: New (Copied from ../../aclocal).
* aclocal/check-multiprocessing.m4: New (Copied from ../../aclocal).
* aclocal/check-networking.m4: New (Copied from ../../aclocal).
* aclocal/check-posix.m4: New (Copied from ../../aclocal).
* aclocal/check-rdbg.m4: New (Copied from ../../aclocal).
* aclocal/check-tool.m4: New (Copied from ../../aclocal).
* aclocal/config-subdirs.m4: New (Copied from ../../aclocal).
* aclocal/enable-bare.m4: New (Copied from ../../aclocal).
* aclocal/enable-cxx.m4: New (Copied from ../../aclocal).
* aclocal/enable-inlines.m4: New (Copied from ../../aclocal).
* aclocal/enable-itron.m4: New (Copied from ../../aclocal).
* aclocal/enable-multiprocessing.m4: New (Copied from ../../aclocal).
* aclocal/enable-networking.m4: New (Copied from ../../aclocal).
* aclocal/enable-posix.m4: New (Copied from ../../aclocal).
* aclocal/enable-rdbg.m4: New (Copied from ../../aclocal).
* aclocal/enable-rtemsbsp.m4: New (Copied from ../../aclocal).
* aclocal/env-rtemsbsp.m4: New (Copied from ../../aclocal).
* aclocal/gcc-isystem.m4: New (Copied from ../../aclocal).
* aclocal/gcc-pipe.m4: New (Copied from ../../aclocal).
* aclocal/gcc-specs.m4: New (Copied from ../../aclocal).
* aclocal/i386-gas-code16.m4: New (Copied from ../../aclocal).
* aclocal/multilib.m4: New (Copied from ../../aclocal).
* aclocal/path-ksh.m4: New (Copied from ../../aclocal).
* aclocal/path-perl.m4: New (Copied from ../../aclocal).
* aclocal/ppc.m4: New (Copied from ../../aclocal).
* aclocal/prog-ccas.m4: New (Copied from ../../aclocal).
* aclocal/prog-cc.m4: New (Copied from ../../aclocal).
* aclocal/prog-cxx.m4: New (Copied from ../../aclocal).
* aclocal/project-root.m4: New (Copied from ../../aclocal).
* aclocal/quoting.m4: New (Copied from ../../aclocal).
* aclocal/rtems-cpu-subdirs.m4: New (Copied from ../../aclocal).
* aclocal/rtems-flags.m4: New (Copied from ../../aclocal).
* aclocal/rtems-top.m4: New (Copied from ../../aclocal).
* aclocal/target.m4: New (Copied from ../../aclocal).
* aclocal/tool-paths.m4: New (Copied from ../../aclocal).
* aclocal/version.m4: New (Copied from ../../aclocal).
* configure.ac: Reworked for multilibs, reflect changes to aclocal/*.m4.
* aclocal/subdirs.m4: New file.
* aclocal/multi.m4: New file, adopted from autoconf-2.52 w/
modifications.
* aclocal/check-posix.m4: Apply AS_IF.
* aclocal/config-subdirs.m4: Reflect changes to other m4-macros.
* aclocal/env-rtemsbsp.m4: Add PROJECT_INCLUDE, PROJECT_RELEASE.
Add AM_CONDITIONAL(MULTILIB). Adapt GCC_SPECS to multilibs.
* aclocal/env-rtemscpu.m4: Remove RTEMS_BSP. Add support for
MULTIBUILDTOP, MULTISUBDIR. Adapt GCC_SPECS to multilibs.
Add PROJECT_INCLUDE, PROJECT_RELEASE, includedir, libdir.
* aclocal/multilib.m4: Fix m4-quoting, adopt automake-1.5's
OUTPUT_COMMANDS.
* aclocal/project-root.m4: Remove PROJECT_INCLUDE, PROJECT_RELEASE.
* aclocal/rtems-debug.m4: Minor cleanups.
* aclocal/rtems-top.m4: Minor cleanups.
* automake/compile.am: Further steps towards automake's rules.
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
that is a somewhat experimental, multilib-related patch:
* Use RTEMS_ENV_RTEMSCPU instead of RTEMS_ENV_RTEMSBSP in
configure.ins below exec/.
At the moment, RTEMS_ENV_RTEMSCPU is more or less an optical change
to emphasize that these subdirectories shall not depend on RTEMS_BSP
than a real behavioral change.
* Add AC_DEFINE_* to several aclocal/*.m4 macros to prepare
autoheader/autoconf generated targopts.h and similiar configuration
headers.
* c/src/configure.in: remove exec from cfg_subdirs if multilibs are
enabled (c/src is build per bsp, exec shall be build per cpu in c/
or from the toplevel in future, when multilibs are enabled.)
* This patch should not have any impact on the current building scheme.
* --enable-multilib still does not work.
* running bootstrap from the toplevel directory is required.
CVS:
CVS: Committing in .
CVS:
CVS: Modified Files:
<corsepiu@faw.uni-ulm.de> that addresses a couple of
minor configuration issues which popped up when
experimenting with multilibs.
Note: The multigen generated make/custom/bare-*.cfg will still be
non-functional, even after having applied this patch.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
