* | bsps: Move make/custom/* files to bsps | Sebastian Huber | 2018-04-23 | 1 | -3/+3 |
| | | | | | | | | | Adjust various build files. Remove automatic generation of the c/src/lib/libbsp/*/acinclude.m4 files from bootstrap script. This patch is a part of the BSP source reorganization. Update #3285. | ||||
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+2 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -2/+0 |
* | 2009-10-17 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-17 | 1 | -9/+5 |
| | | | | | * configure.ac: Pick up make/custom/*. * aclocal/check-custom-bsp.m4: Adapt to changes to configure.ac. | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 1 | -1/+3 |
| | | | | | * aclocal/check-custom-bsp.m4: Let _RTEMS_CHECK_CUSTOM_BSP look for *.cfg into c/src/lib/libbsp/<cpu>/<bsp_family>/make/custom. | ||||
* | Change *.cfg handling. | Ralf Corsepius | 2009-10-14 | 1 | -3/+3 |
* | 2004-10-22 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-10-22 | 1 | -1/+1 |
| | | | | * alocal/check-custom-bsp.m4: Reflect new location of bspkit*cfg. | ||||
* | 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-12 | 1 | -6/+20 |
| | | | | | | | | * aclocal/bspopts.m4: Use AS_HELP_STRING. * aclocal/bsp-configure.m4: Require autoconf-2.59. Use AC_CONFIG_HEADERS. * aclocal/check-custom-bsp.m4: Add bspkit-support. * aclocal/enable-rtemsbsp.m4: Use AS_HELP_STRING. | ||||
* | 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-26 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | | | * aclocal/bsp-arg-enable.m4, aclocal/canonical-target-name.m4, aclocal/canonicalize-tools.m4, aclocal/check-custom-bsp.m4, aclocal/check-posix.m4, aclocal/check-rdbg.m4, aclocal/check-tool.m4, aclocal/config-subdirs.m4, aclocal/enable-bare.m4, aclocal/enable-cxx.m4, aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4, aclocal/enable-posix.m4, aclocal/enable-rdbg.m4, aclocal/enable-rtemsbsp.m4, aclocal/env-rtemsbsp.m4, aclocal/gcc-isystem.m4, aclocal/gcc-pipe.m4, aclocal/gcc-specs.m4, aclocal/i386-gas-code16.m4, aclocal/multilib.m4, aclocal/path-ksh.m4, aclocal/prog-cc.m4, aclocal/prog-cxx.m4, aclocal/project-root.m4, aclocal/rtems-top.m4, aclocal/target.m4, aclocal/tool-paths.m4: Fix underquoting to silence automake-1.8. | ||||
* | 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-18 | 1 | -0/+10 |
* aclocal/bsp-alias.m4: New (Copied from ../../aclocal). * aclocal/bsp-arg-enable.m4: New (Copied from ../../aclocal). * aclocal/bsp-configure.m4: New (Copied from ../../aclocal). * aclocal/bspopts.m4: New (Copied from ../../aclocal). * aclocal/canonical-host.m4: New (Copied from ../../aclocal). * aclocal/canonicalize-tools.m4: New (Copied from ../../aclocal). * aclocal/canonical-target-name.m4: New (Copied from ../../aclocal). * aclocal/check-cpu.m4: New (Copied from ../../aclocal). * aclocal/check-custom-bsp.m4: New (Copied from ../../aclocal). * aclocal/check-cxx.m4: New (Copied from ../../aclocal). * aclocal/check-itron.m4: New (Copied from ../../aclocal). * aclocal/check-multiprocessing.m4: New (Copied from ../../aclocal). * aclocal/check-networking.m4: New (Copied from ../../aclocal). * aclocal/check-posix.m4: New (Copied from ../../aclocal). * aclocal/check-rdbg.m4: New (Copied from ../../aclocal). * aclocal/check-tool.m4: New (Copied from ../../aclocal). * aclocal/config-subdirs.m4: New (Copied from ../../aclocal). * aclocal/enable-bare.m4: New (Copied from ../../aclocal). * aclocal/enable-cxx.m4: New (Copied from ../../aclocal). * aclocal/enable-inlines.m4: New (Copied from ../../aclocal). * aclocal/enable-itron.m4: New (Copied from ../../aclocal). * aclocal/enable-multiprocessing.m4: New (Copied from ../../aclocal). * aclocal/enable-networking.m4: New (Copied from ../../aclocal). * aclocal/enable-posix.m4: New (Copied from ../../aclocal). * aclocal/enable-rdbg.m4: New (Copied from ../../aclocal). * aclocal/enable-rtemsbsp.m4: New (Copied from ../../aclocal). * aclocal/env-rtemsbsp.m4: New (Copied from ../../aclocal). * aclocal/gcc-isystem.m4: New (Copied from ../../aclocal). * aclocal/gcc-pipe.m4: New (Copied from ../../aclocal). * aclocal/gcc-specs.m4: New (Copied from ../../aclocal). * aclocal/i386-gas-code16.m4: New (Copied from ../../aclocal). * aclocal/multilib.m4: New (Copied from ../../aclocal). * aclocal/path-ksh.m4: New (Copied from ../../aclocal). * aclocal/path-perl.m4: New (Copied from ../../aclocal). * aclocal/ppc.m4: New (Copied from ../../aclocal). * aclocal/prog-ccas.m4: New (Copied from ../../aclocal). * aclocal/prog-cc.m4: New (Copied from ../../aclocal). * aclocal/prog-cxx.m4: New (Copied from ../../aclocal). * aclocal/project-root.m4: New (Copied from ../../aclocal). * aclocal/quoting.m4: New (Copied from ../../aclocal). * aclocal/rtems-cpu-subdirs.m4: New (Copied from ../../aclocal). * aclocal/rtems-flags.m4: New (Copied from ../../aclocal). * aclocal/rtems-top.m4: New (Copied from ../../aclocal). * aclocal/target.m4: New (Copied from ../../aclocal). * aclocal/tool-paths.m4: New (Copied from ../../aclocal). * aclocal/version.m4: New (Copied from ../../aclocal). |
