* | bsp: Make riscv_generic work for both riscv32 and riscv64 - v2 | Hesham Almatary | 2017-11-01 | 1 | -0/+2 |
| | | | | Update #3109 | ||||
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -4/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+4 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -4/+0 |
* | 2011-02-25 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-25 | 1 | -8/+10 |
| | | | | | | | * aclocal/canonical-target-name.m4: Stop pretending no_cpu* was buildable. Derive RTEMS_CPU from "$host_cpu". Error out if "$host" doesn't match "*-*-rtems*". | ||||
* | 2009-10-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 1 | -3/+0 |
| | | | | * aclocal/canonical-target-name.m4: Remove RTEMS_HOST (unused). | ||||
* | Remove posix/unix. | Ralf Corsepius | 2009-10-14 | 1 | -17/+0 |
* | Remove tic4x. | Ralf Corsepius | 2008-12-22 | 1 | -4/+0 |
* | 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-26 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | | | * aclocal/bsp-arg-enable.m4, aclocal/canonical-target-name.m4, aclocal/canonicalize-tools.m4, aclocal/check-custom-bsp.m4, aclocal/check-posix.m4, aclocal/check-rdbg.m4, aclocal/check-tool.m4, aclocal/config-subdirs.m4, aclocal/enable-bare.m4, aclocal/enable-cxx.m4, aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4, aclocal/enable-posix.m4, aclocal/enable-rdbg.m4, aclocal/enable-rtemsbsp.m4, aclocal/env-rtemsbsp.m4, aclocal/gcc-isystem.m4, aclocal/gcc-pipe.m4, aclocal/gcc-specs.m4, aclocal/i386-gas-code16.m4, aclocal/multilib.m4, aclocal/path-ksh.m4, aclocal/prog-cc.m4, aclocal/prog-cxx.m4, aclocal/project-root.m4, aclocal/rtems-top.m4, aclocal/target.m4, aclocal/tool-paths.m4: Fix underquoting to silence automake-1.8. | ||||
* | 2003-10-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-22 | 1 | -4/+12 |
| | | | | | * aclocal/canonical-host.m4: Remove. * aclocal/canonical-target-name.m4: Merge-in aclocal/canonical-host.m4. | ||||
* | 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-21 | 1 | -1/+1 |
| | | | | | | | | | | | | | | * aclocal/canonical-target-name.m4: Add m4-quotes. * aclocal/check-cxx.m4: Add m4-quotes. Don't require RTEMS_CHECK_CPU. * aclocal/check-multiprocessing.m4: Add m4-quotes. Require RTEMS_CANONICAL_TARGET_CPU instead of RTEMS_CHECK_CPU. * aclocal/check-networking.m4: Add m4-quotes. Require RTEMS_CANONICAL_TARGET_CPU instead of RTEMS_CHECK_CPU. * aclocal/check-posix.m4: Add m4-quotes. Require RTEMS_CANONICAL_TARGET_CPU instead of RTEMS_CHECK_CPU. * aclocal/check-rdbg.m4: Add m4-quotes. Require RTEMS_CANONICAL_TARGET_CPU instead of RTEMS_CHECK_CPU. | ||||
* | 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-18 | 1 | -0/+41 |
* aclocal/bsp-alias.m4: New (Copied from ../../aclocal). * aclocal/bsp-arg-enable.m4: New (Copied from ../../aclocal). * aclocal/bsp-configure.m4: New (Copied from ../../aclocal). * aclocal/bspopts.m4: New (Copied from ../../aclocal). * aclocal/canonical-host.m4: New (Copied from ../../aclocal). * aclocal/canonicalize-tools.m4: New (Copied from ../../aclocal). * aclocal/canonical-target-name.m4: New (Copied from ../../aclocal). * aclocal/check-cpu.m4: New (Copied from ../../aclocal). * aclocal/check-custom-bsp.m4: New (Copied from ../../aclocal). * aclocal/check-cxx.m4: New (Copied from ../../aclocal). * aclocal/check-itron.m4: New (Copied from ../../aclocal). * aclocal/check-multiprocessing.m4: New (Copied from ../../aclocal). * aclocal/check-networking.m4: New (Copied from ../../aclocal). * aclocal/check-posix.m4: New (Copied from ../../aclocal). * aclocal/check-rdbg.m4: New (Copied from ../../aclocal). * aclocal/check-tool.m4: New (Copied from ../../aclocal). * aclocal/config-subdirs.m4: New (Copied from ../../aclocal). * aclocal/enable-bare.m4: New (Copied from ../../aclocal). * aclocal/enable-cxx.m4: New (Copied from ../../aclocal). * aclocal/enable-inlines.m4: New (Copied from ../../aclocal). * aclocal/enable-itron.m4: New (Copied from ../../aclocal). * aclocal/enable-multiprocessing.m4: New (Copied from ../../aclocal). * aclocal/enable-networking.m4: New (Copied from ../../aclocal). * aclocal/enable-posix.m4: New (Copied from ../../aclocal). * aclocal/enable-rdbg.m4: New (Copied from ../../aclocal). * aclocal/enable-rtemsbsp.m4: New (Copied from ../../aclocal). * aclocal/env-rtemsbsp.m4: New (Copied from ../../aclocal). * aclocal/gcc-isystem.m4: New (Copied from ../../aclocal). * aclocal/gcc-pipe.m4: New (Copied from ../../aclocal). * aclocal/gcc-specs.m4: New (Copied from ../../aclocal). * aclocal/i386-gas-code16.m4: New (Copied from ../../aclocal). * aclocal/multilib.m4: New (Copied from ../../aclocal). * aclocal/path-ksh.m4: New (Copied from ../../aclocal). * aclocal/path-perl.m4: New (Copied from ../../aclocal). * aclocal/ppc.m4: New (Copied from ../../aclocal). * aclocal/prog-ccas.m4: New (Copied from ../../aclocal). * aclocal/prog-cc.m4: New (Copied from ../../aclocal). * aclocal/prog-cxx.m4: New (Copied from ../../aclocal). * aclocal/project-root.m4: New (Copied from ../../aclocal). * aclocal/quoting.m4: New (Copied from ../../aclocal). * aclocal/rtems-cpu-subdirs.m4: New (Copied from ../../aclocal). * aclocal/rtems-flags.m4: New (Copied from ../../aclocal). * aclocal/rtems-top.m4: New (Copied from ../../aclocal). * aclocal/target.m4: New (Copied from ../../aclocal). * aclocal/tool-paths.m4: New (Copied from ../../aclocal). * aclocal/version.m4: New (Copied from ../../aclocal). |
