path: root/c/src/aclocal/bsp-configure.m4 (follow)
* 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-181-0/+35
* aclocal/bsp-alias.m4: New (Copied from ../../aclocal). * aclocal/bsp-arg-enable.m4: New (Copied from ../../aclocal). * aclocal/bsp-configure.m4: New (Copied from ../../aclocal). * aclocal/bspopts.m4: New (Copied from ../../aclocal). * aclocal/canonical-host.m4: New (Copied from ../../aclocal). * aclocal/canonicalize-tools.m4: New (Copied from ../../aclocal). * aclocal/canonical-target-name.m4: New (Copied from ../../aclocal). * aclocal/check-cpu.m4: New (Copied from ../../aclocal). * aclocal/check-custom-bsp.m4: New (Copied from ../../aclocal). * aclocal/check-cxx.m4: New (Copied from ../../aclocal). * aclocal/check-itron.m4: New (Copied from ../../aclocal). * aclocal/check-multiprocessing.m4: New (Copied from ../../aclocal). * aclocal/check-networking.m4: New (Copied from ../../aclocal). * aclocal/check-posix.m4: New (Copied from ../../aclocal). * aclocal/check-rdbg.m4: New (Copied from ../../aclocal). * aclocal/check-tool.m4: New (Copied from ../../aclocal). * aclocal/config-subdirs.m4: New (Copied from ../../aclocal). * aclocal/enable-bare.m4: New (Copied from ../../aclocal). * aclocal/enable-cxx.m4: New (Copied from ../../aclocal). * aclocal/enable-inlines.m4: New (Copied from ../../aclocal). * aclocal/enable-itron.m4: New (Copied from ../../aclocal). * aclocal/enable-multiprocessing.m4: New (Copied from ../../aclocal). * aclocal/enable-networking.m4: New (Copied from ../../aclocal). * aclocal/enable-posix.m4: New (Copied from ../../aclocal). * aclocal/enable-rdbg.m4: New (Copied from ../../aclocal). * aclocal/enable-rtemsbsp.m4: New (Copied from ../../aclocal). * aclocal/env-rtemsbsp.m4: New (Copied from ../../aclocal). * aclocal/gcc-isystem.m4: New (Copied from ../../aclocal). * aclocal/gcc-pipe.m4: New (Copied from ../../aclocal). * aclocal/gcc-specs.m4: New (Copied from ../../aclocal). * aclocal/i386-gas-code16.m4: New (Copied from ../../aclocal). * aclocal/multilib.m4: New (Copied from ../../aclocal). * aclocal/path-ksh.m4: New (Copied from ../../aclocal). * aclocal/path-perl.m4: New (Copied from ../../aclocal). * aclocal/ppc.m4: New (Copied from ../../aclocal). * aclocal/prog-ccas.m4: New (Copied from ../../aclocal). * aclocal/prog-cc.m4: New (Copied from ../../aclocal). * aclocal/prog-cxx.m4: New (Copied from ../../aclocal). * aclocal/project-root.m4: New (Copied from ../../aclocal). * aclocal/quoting.m4: New (Copied from ../../aclocal). * aclocal/rtems-cpu-subdirs.m4: New (Copied from ../../aclocal). * aclocal/rtems-flags.m4: New (Copied from ../../aclocal). * aclocal/rtems-top.m4: New (Copied from ../../aclocal). * aclocal/target.m4: New (Copied from ../../aclocal). * aclocal/tool-paths.m4: New (Copied from ../../aclocal). * aclocal/version.m4: New (Copied from ../../aclocal).
