for details.
* aclocal/bsp-configure.m4: Add RTEMS_BSP_BOOTCARD_OPTIONS.
Remove checks for AMPOLISH3.
* aclocal/bsp-configure.m4: Add ampolish3.
New header guards.
* aclocal/bspopts.m4: Use AS_HELP_STRING.
* aclocal/bsp-configure.m4: Require autoconf-2.59.
Use AC_CONFIG_HEADERS.
* aclocal/check-custom-bsp.m4: Add bspkit-support.
* aclocal/enable-rtemsbsp.m4: Use AS_HELP_STRING.
* aclocal/bsp-configure.m4: AC_PREREQ(2.57).
Remove RTEMS_CANONICAL_HOST.
* aclocal/bsp-alias.m4: New (Copied from ../../aclocal).
* aclocal/bsp-arg-enable.m4: New (Copied from ../../aclocal).
* aclocal/bsp-configure.m4: New (Copied from ../../aclocal).
* aclocal/bspopts.m4: New (Copied from ../../aclocal).
* aclocal/canonical-host.m4: New (Copied from ../../aclocal).
* aclocal/canonicalize-tools.m4: New (Copied from ../../aclocal).
* aclocal/canonical-target-name.m4: New (Copied from ../../aclocal).
* aclocal/check-cpu.m4: New (Copied from ../../aclocal).
* aclocal/check-custom-bsp.m4: New (Copied from ../../aclocal).
* aclocal/check-cxx.m4: New (Copied from ../../aclocal).
* aclocal/check-itron.m4: New (Copied from ../../aclocal).
* aclocal/check-multiprocessing.m4: New (Copied from ../../aclocal).
* aclocal/check-networking.m4: New (Copied from ../../aclocal).
* aclocal/check-posix.m4: New (Copied from ../../aclocal).
* aclocal/check-rdbg.m4: New (Copied from ../../aclocal).
* aclocal/check-tool.m4: New (Copied from ../../aclocal).
* aclocal/config-subdirs.m4: New (Copied from ../../aclocal).
* aclocal/enable-bare.m4: New (Copied from ../../aclocal).
* aclocal/enable-cxx.m4: New (Copied from ../../aclocal).
* aclocal/enable-inlines.m4: New (Copied from ../../aclocal).
* aclocal/enable-itron.m4: New (Copied from ../../aclocal).
* aclocal/enable-multiprocessing.m4: New (Copied from ../../aclocal).
* aclocal/enable-networking.m4: New (Copied from ../../aclocal).
* aclocal/enable-posix.m4: New (Copied from ../../aclocal).
* aclocal/enable-rdbg.m4: New (Copied from ../../aclocal).
* aclocal/enable-rtemsbsp.m4: New (Copied from ../../aclocal).
* aclocal/env-rtemsbsp.m4: New (Copied from ../../aclocal).
* aclocal/gcc-isystem.m4: New (Copied from ../../aclocal).
* aclocal/gcc-pipe.m4: New (Copied from ../../aclocal).
* aclocal/gcc-specs.m4: New (Copied from ../../aclocal).
* aclocal/i386-gas-code16.m4: New (Copied from ../../aclocal).
* aclocal/multilib.m4: New (Copied from ../../aclocal).
* aclocal/path-ksh.m4: New (Copied from ../../aclocal).
* aclocal/path-perl.m4: New (Copied from ../../aclocal).
* aclocal/ppc.m4: New (Copied from ../../aclocal).
* aclocal/prog-ccas.m4: New (Copied from ../../aclocal).
* aclocal/prog-cc.m4: New (Copied from ../../aclocal).
* aclocal/prog-cxx.m4: New (Copied from ../../aclocal).
* aclocal/project-root.m4: New (Copied from ../../aclocal).
* aclocal/quoting.m4: New (Copied from ../../aclocal).
* aclocal/rtems-cpu-subdirs.m4: New (Copied from ../../aclocal).
* aclocal/rtems-flags.m4: New (Copied from ../../aclocal).
* aclocal/rtems-top.m4: New (Copied from ../../aclocal).
* aclocal/target.m4: New (Copied from ../../aclocal).
* aclocal/tool-paths.m4: New (Copied from ../../aclocal).
* aclocal/version.m4: New (Copied from ../../aclocal).
