These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
for details.
* aclocal/bsp-bootcard-options.m4: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
now use the same macros.
* aclocal/bsp-bspcleanup-options.m4: New file.
* aclocal/bsp-bootcard-options.m4: Generalize and correct comment.
* aclocal/bsp-bootcard-options.m4: Fix quoting.
* aclocal/bsp-bootcard-options.m4: New file.
* aclocal/bsp-bootcards-handles-ram-allocation.m4: Removed.
