path: root/c/src/acinclude.m4 (follow)
* 2004-08-17 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-08-181-1/+1
| | | | * acinclude.m4 (_RTEMS_CONFIG_SUBDIR): Quote ac_popdir uses.
* 2004-02-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-201-6/+9
| | | | | | | | | | | * acinclude.m4: Fix loosing arguments when configuring cpukit and testsuites (Was exposed with --enable-multilib, only). Remove RTEMS_SUBCONFIGURE_ARGS_QUOTE. RTEMS_CONFIG_SUBDIR. Add RTEMS_BSP_CONFIG_SUBDIR. * configure.ac: Reflect changes to acinclude.m4. Reflect new args to testsuites's configure. * aclocal/rtems-top.m4: Remove ENDIF hack. Rework and fix setting up PROJECT_TOPdir (PACKHEX wasn't found).
* 2003-12-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-141-13/+9
| | | | | | | * automake/compile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g. * wrapup/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g. * acinclude.m4: Rework RTEMS_CONFIG_SUBDIR. * Makefile.am: Reflect changes to RTEMS_CONFIG_SUBDIR.
* 2002-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-111-26/+1
| | | | * acinclude.m4: Apply RTEMS_CONFIGURE_ARGS_QUOTE.
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-221-0/+2
| | | | | * acinclude.m4: Add test "$multilib" != "yes". * config-ml.in: Remove.
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-221-8/+1
| | | | | | | * acinclude.m4: Cleanups. * configure.ac: Build ${srcdir}/../../cpukit/ as ./exec/ instead of ${srcdir}/exec/. Further adaptations to autoconf >= 2.50.
* 2002-07-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-051-0/+117
| | | | | | | | | * acinclude.m4: New. * Makefile.am: Remove tar-installation. Prepend @exec@ to SUBDIRS. * configure.ac: Switch to AC_CONFIG_SRCDIR([optman]). Add RTEMS_ENABLE_MULTIPROCESSING. Add RTEMS_CONFIG_SUBDIR([exec]...).
* 2000-10-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-311-121/+0
| | | | | | * configure.in: Switch to GNU-canonicalization. * Makefile.am: Reflect changes to configure.in. * acinclude.m4: Remove.
* 2000-10-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-241-0/+121
* Makefile.am, acinclude.m4, configure.in: Introduce GNU canonicalization to libfs/. The approach is currently a bit of a hack as GNU canonicalization does not support the per-BSP build some of the other directories require. As more of the tree is converted, this will become less of an issue.
