* configure.ac: Remove check for libbsp/${RTEMS_CPU}.
Add dependency tracking for *.cfgs.
* Makefile.am: Add dependency tracking for *.cfg.
* librdbg/Makefile.am: Merge-in librdbg/include/Makefile.am,
librdbg/src/Makefile.am.
* librdbg/include/Makefile.am, librdbg/src/Makefile.am: Remove.
Unconditionally apply RTEMS_CHECK_MULTIPROCESSING.
* Makefile.am: Add DIST_SUBDIRS = @BSP_SUBDIRS@.
* Makefile.am: DISTCLEANFILES += @CUSTOM_CFG_FILES.
* Makefile.am: include local.am.
* Makefile.am: Don't include host.am.
* automake/compile.am: Further cleanups.
* Makefile.am: Cosmetics.
* automake/lib.am: Add project_libdir.
Add preinstallation dirstamp support.
lib/Makefile.am: Reflect having moved automake.
support/Makefile.am: Reflect having moved automake.
* Makefile.am: Add bsp.pc.in
* bsp.pc.in: New (pkgconfig support).
* Makefile.am: Use "'"-quotes to pass args to bsp.mak.
* configure.ac: Use "'"-quotes for args to RTEMS_CONFIG_SUBDIRS.
Fix braino in comment on "exec".
Extend --enable-ada handling.
* Makefile.am: Add preinstall-stamp.
Posix-BSP-Hacks:
* configure.ac: Add AM_CONDITIONAL(LIBCHIP).
Pass RTEMS_HOST to make/bsp.mak
* Makefile.am: Pass RTEMS_HOST to make/bsp.mak.
* wrapup/Makefile.am: Apply AM_CONDITIONAL(LIBCHIP).
* configure.ac: Add BSP_SUBDIRS.
* Makefile.am: Use BSP_SUBDIRS to setup SUBDIRS.
* Makefile.am: Add rtems_makedir.
* configure.ac: Merge wrapup/configure.ac.
Cosmetic cleanups.
* Makefile.am: Add wrapup-SUBDIR.
* wrapup/ChangeLog: Remove.
* wrapup/configure.ac: Remove.
* Makefile.am: Append BARE_CPU_MODEL tp make/@RTEMS_BSP@.cache
creation (Make the bare BSP happy).
* configure.ac: Ditto.
* Makefile.am: Create make/@RTEMS_BSP@.cache.
Handle make/custom/*.cfgs.
Create make/custom/default.cfg.
* configure.ac: Add creation of make/custon/*.cfg.
Create make/${RTEMS_BSP}.cache.
Read make/${RTEMS_BSP}.cache
* Makefile.am: Clean $(PROJECT_RELEASE).
* acinclude.m4: New.
* Makefile.am: Remove tar-installation.
Prepend @exec@ to SUBDIRS.
* configure.ac: Switch to AC_CONFIG_SRCDIR([optman]).
Add RTEMS_ENABLE_MULTIPROCESSING.
Add RTEMS_CONFIG_SUBDIR([exec]...).
* Makefile.am: Use SUBDIRS = @subdirs@, require automake-1.5.
* configure.ac: Replace hst_subdirs with AC_CONFIG_SUBDIRS to make
autoconf-2.52 happy.
* Makefile.am: install to $(exec_prefix)/@RTEMS_BSP@.
* configure.in: Switch to GNU-canonicalization.
* acinclude.m4: Remove.
* configure.in: add lib/libbsp to the GNU canonicalized
subdirectories, remove cfg_subdirs, cfg_subdirs1, hst_subdirs1.
* Makefile.am: remove cfg_subdirs, cfg_subdirs1, hst_subdirs1.
* ChangeLog: Fix typos.
* configure.in, Makefile.am: add exec to the GNU canonicalized
subdirectories.
* configure.in: add librtems++, libnetworking, librpc, librdb, libmisc,
and libchip to the GNU canonicalized subdirectories.
NOTE: Missed committing as each subdirectory was added (joel).
* Makefile.am, acinclude.m4, configure.in: Introduce GNU
canonicalization to libfs/.
The approach is currently a bit of a hack as GNU canonicalization
does not support the per-BSP build some of the other directories
require. As more of the tree is converted, this will become less
of an issue.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
fixes a minor configuration bug.
c/src/lib/librtems++ and c/src/lib/include/rtems++ to
their own package librtems++ at the top of the tree.
mkdir c/src/librtems++
cp c/src/lib/librtems++/README c/src/librtems++
mkdir c/src/librtems++/src
cp c/src/lib/librtems++/*.cc c/src/librtems++/src
cp c/src/lib/librtems++/Makefile.in c/src/librtems++/src
mkdir c/src/librtems++/include
mkdir c/src/librtems++/include/rtems++
cp c/src/lib/include/rtems++/*.h c/src/librtems++/include/rtems++
patch -p1 <rtems-rc-19990802-5.diff
rm -rf c/src/lib/librtems++
rm -rf c/src/lib/include/rtems++
Attention:
* The procedure above copies the files first, then patches them
and finally removes the old files afterwards. This has been done
to enable you to copy the files in CVS to preserve their history.
