* config-ml.in: Take out arm and sh variants RTEMS does not support.
* DOS filesystem including FAT12, FAT16, and FAT32 support submitted.
* configure.ac: Modified to reflect addition.
* configure.ac: Add AC_CONFIG_SUBDIRS(optman). Remove
AC_CONFIG_COMMANDS.
* config-ml.in: New file. Imported from gcc and modified for RTEMS.
* Makefile.am: Use SUBDIRS = @subdirs@, require automake-1.5.
* configure.ac: Replace hst_subdirs with AC_CONFIG_SUBDIRS to make
autoconf-2.52 happy.
* configure.in: Remove.
* Makefile.am: install to $(exec_prefix)/@RTEMS_BSP@.
* configure.in: Switch to GNU-canonicalization.
* acinclude.m4: Remove.
* configure.in: add lib/libbsp to the GNU canonicalized
subdirectories, remove cfg_subdirs, cfg_subdirs1, hst_subdirs1.
* Makefile.am: remove cfg_subdirs, cfg_subdirs1, hst_subdirs1.
* ChangeLog: Fix typos.
* configure.in: add tests to the GNU canonicalized subdirectories,
* configure.in: add lib/libcpu to the GNU canonicalized subdirectories,
* configure.in: add lib to the GNU canonicalized subdirectories,
make the lib directory before configuring lib/.
* configure.in, Makefile.am: add exec to the GNU canonicalized
subdirectories.
* configure.in: add librtems++ to the GNU canonicalized subdirectories.
* configure.in: add libnetworking, librpc and librdb to the GNU
* configure.in: add libmisc and libchip to the GNU canonicalized
subdirectories.
* Makefile.am, acinclude.m4, configure.in: Introduce GNU
canonicalization to libfs/.
The approach is currently a bit of a hack as GNU canonicalization
does not support the per-BSP build some of the other directories
require. As more of the tree is converted, this will become less
of an issue.
* wrapup/Makefile.am: Added libfs.
* libfs created.
* configure.in: Added libfs subdirectory.
* configure.in: Add RTEMS_PROG_CC_FOR_TARGET,
RTEMS_CANONICALIZE_TOOLS.
* wrapup/Makefile.am: Include compile.am.
* configure.in: Add lib/libcpu and lib/libbsp to cfg_subdirs
