PR 607/networking
* libchip/network/dec21140.c: Made PCI configuration minimum sane
instead of fully specifying unused PCI features.
* aclocal/rtems-cpu-subdirs.m4: Add avr.
* aclocal/gcc-weak.m4: New (Extracted from cpukit/configure.ac).
* configure.ac: Add RTEMS_CHECK_GCC_WEAK.
* aclocal/ppc.m4 (RTEMS_PPC_EXCEPTIONS): Quote ac_popdir uses.
* aclocal/target.m4 (_RTEMS_POP_BUILDDIR): Ditto.
* acinclude.m4 (_RTEMS_CONFIG_SUBDIR): Quote ac_popdir uses.
* aclocal/version.m4: Updated to rtems-4.6.99.1.
* libchip/network/if_fxp.c: Add include of <sys/errno.h>.
* PR/625/networking
* libchip/network/dec21140.c, ... : Prevent name clashes by making
'ld_le32()' etc. static inlines. Let dec21140 attach routine return
an error rather than panic if no chip is detected (thus allowing
for probing).
* libchip/network/elnk.c: Let elnk bail out if autoneg never completes
instead of looping forever. Avoid divide by zero (crashed my PC).
* libchip/network/if_fxp.c: Enable more fxp chip variants but warn that
they are UNTESTED.
* aclocal/check-cxx.m4: Remove CPLUS_LD_LIBS.
* libchip/network/dec21140.c, libchip/network/elnk.c:
#include <errno.h>.
* libchip/network/if_media.h: Update from FreeBSD.
* libchip/network/open_eth.c, libchip/network/cs8900.c,
libchip/network/i82586.c: #include <errno.h>.
* aclocal/rtems-top.4: Remove RTEMS_ROOT (Obsolete).
* aclocal/rtems-top.m4: Add project_top/with_project_top processing.
* optman/Makefile.am: Set EXEEXT = <empty> (Work around to a bug in
automake).
PR 599/pppd
* libnetworking/pppd/chat.c: Fre memory that is allocated to fix leak.
* optman/rtems/no-region.c: Reflect having changed
rtems_region_get_segment_size.
* librdbg/src/i386/rdbg_cpu_asm.S: Include <rtems/asm.h> instead of <asm.h>.
* librdbg/src/m68k/rdbg_cpu_asm.S: Include <rtems/asm.h> instead of <asm.h>.
* librdbg/src/powerpc/rdbg_cpu_asm.S: Include <rtems/asm.h> instead of <asm.h>.
* libchip/ide/ata.c: Include <rtems/chain.h> instead of <chain.h>.
* libchip/ide/ide_controller.c: Include <rtems/chain.h> instead of <chain.h>.
* libchip/shmdr/shm_driver.h: Include <rtems/clockdrv.h> instead of <clockdrv.h>.
* libchip/serial/ns16550.c: Include <rtems/ringbuf.h> instead of <ringbuf.h>.
* libchip/ide/ata.c, libchip/network/dec21140.c,
libchip/network/elnk.c, libchip/network/i82586.c,
libchip/network/if_fxp.c, libchip/network/if_fxpvar.h,
libchip/network/open_eth.c, libchip/network/sonic.c,
libchip/rtc/icm7170.c, libchip/serial/ns16550.c,
libchip/serial/z85c30.c, libchip/shmdr/cnvpkt.c,
libchip/shmdr/init.c, libchip/shmdr/intr.c,
libchip/shmdr/shm_driver.h: Cosmetics.
* optman/rtems/no-dpmem.c, optman/rtems/no-mp.c,
optman/rtems/no-msg.c, optman/rtems/no-part.c,
optman/rtems/no-region.c, optman/rtems/no-rtmon.c,
optman/rtems/no-sem.c, optman/rtems/no-timer.c,
optman/sapi/no-ext.c, optman/sapi/no-io.c: Convert to using c99
fixed size types.
* configure.ac: Explicitly pass --includedir and --libdir to
cpukit/configure.
* librdbg/Makefile.am: Fix rpcgen rules.
* librdbg/src/i386/any/remdeb_xdr.c,
librdbg/src/m68k/any/remdeb_xdr.c,
librdbg/src/powerpc/new_exception_processing/remdeb_xdr.c:
Reflect changes to librdbg/Makefile.am.
* configure.ac: Reflect changes testsuites/configure.ac and
cpukit/configure.ac.
* aclocal/rtems-top.m4: Add 2nd arg to RTEMS_TOP.
Rework with_project_root/PROJECT_ROOT and with_project_top/PROJECT_TOPdir.
* configure.ac: Reflect changes to testsuites's configuration.
PR/589 rtems
* libchip/network/pci.h: Remove (Moved to cpukit).
* libchip/ide/ata.c, libchip/ide/ata_internal.h,
libchip/ide/ide_controller.c, libchip/ide/ide_ctrl_cfg.h,
libchip/ide/ide_ctrl_io.h, libchip/network/cs8900.c,
libchip/network/dec21140.c, libchip/network/elnk.c,
libchip/network/if_fxp.c, libchip/network/open_eth.c,
libchip/network/open_eth.h, libchip/network/sonic.c,
libchip/network/sonic.h, libchip/rtc/icm7170.c, libchip/rtc/icm7170.h,
libchip/rtc/icm7170_reg.c, libchip/rtc/icm7170_reg2.c,
libchip/rtc/icm7170_reg4.c, libchip/rtc/icm7170_reg8.c,
libchip/rtc/m48t08.c, libchip/rtc/m48t08.h, libchip/rtc/m48t08_reg.c,
libchip/rtc/m48t08_reg2.c, libchip/rtc/m48t08_reg4.c,
libchip/rtc/m48t08_reg8.c, libchip/rtc/rtc.h, libchip/serial/mc68681.c,
libchip/serial/mc68681.h, libchip/serial/mc68681_reg.c,
libchip/serial/mc68681_reg2.c, libchip/serial/mc68681_reg4.c,
libchip/serial/mc68681_reg8.c, libchip/serial/ns16550.c,
libchip/serial/ns16550_p.h, libchip/serial/serial.h,
libchip/serial/z85c30.c, libchip/serial/z85c30.h,
libchip/serial/z85c30_p.h, libchip/serial/z85c30_reg.c,
libchip/shmdr/addlq.c, libchip/shmdr/cnvpkt.c, libchip/shmdr/dump.c,
libchip/shmdr/fatal.c, libchip/shmdr/getlq.c, libchip/shmdr/init.c,
libchip/shmdr/initlq.c, libchip/shmdr/intr.c, libchip/shmdr/poll.c,
libchip/shmdr/send.c, libchip/shmdr/shm_driver.h: Convert to using c99
fixed-size types.
* libchip/network/dec21140.c: Use __PPC__ instead of __PPC.
Cosmetics.
* aclocal/canonicalize-tools.m4: Revert Joel's 2004-03-04's patch.
There are no application level Makefiles in here.
* aclocal/canonicalize-tools.m4: Add SIZE, NM, and OBJCOPY so
they can be used in application level makefiles.
* libnetworking/rtems_webserver/ejparse.c,
libnetworking/rtems_webserver/emfdb.c,
libnetworking/rtems_webserver/sock.c,
libnetworking/rtems_webserver/socket.c,
libnetworking/rtems_webserver/sym.c,
libnetworking/rtems_webserver/webs.c,
libnetworking/rtems_webserver/websuemf.c: Remove warnings.
* libchipnetwork/open_eth.c: Remove warnings by conditionally
compiling this file only only those CPU families with supported
exception models.
* acinclude.m4: Fix loosing arguments when configuring cpukit and
testsuites (Was exposed with --enable-multilib, only).
Remove RTEMS_SUBCONFIGURE_ARGS_QUOTE. RTEMS_CONFIG_SUBDIR.
Add RTEMS_BSP_CONFIG_SUBDIR.
* configure.ac: Reflect changes to acinclude.m4. Reflect new args to
testsuites's configure.
* aclocal/rtems-top.m4: Remove ENDIF hack.
Rework and fix setting up PROJECT_TOPdir (PACKHEX wasn't found).
* libchip/Makefile.am, librdbg/Makefile.am, optman/Makefile.am,
wrapup/Makefile.am: Fix automake problems having been introduced
in previous patch.
* libchip/Makefile.am, librdbg/Makefile.am, optman/Makefile.am:
Preinstall dirs.
* wrapup/Makefile.am: Preinstall dirs. Cosmetics.
* aclocal/check-multiprocessing.m4: Cosmetics.
* aclocal/env-rtemsbsp.m4: Remove RTEMS_ROOT.
* aclocal/project-root.m4: Remove obsolete comments. Remove PACKHEX.
* librdbg/Makefile.am: Merge-in librdbg/include/Makefile.am,
librdbg/src/Makefile.am.
* librdbg/include/Makefile.am, librdbg/src/Makefile.am: Remove.
Unconditionally apply RTEMS_CHECK_MULTIPROCESSING.
* Makefile.am: Add DIST_SUBDIRS = @BSP_SUBDIRS@.
* aclocal/check-rdbg.m4: Don't AC_SUBST(HAS_RDBG).
* Makefile.am: DISTCLEANFILES += @CUSTOM_CFG_FILES.
* wrapup/Makefile.am: Reflect new location of librdbg.a.
* librdbg/src/i386/Makefile.am, librdbg/src/m68k/Makefile.am,
librdbg/src/powerpc/Makefile.am:
Remove.
* librdbg/src/Makefile.am: Merge-in librdbg/src/i386/Makefile.am,
librdbg/src/m68k/Makefile.am, librdbg/src/powerpc/Makefile.am.
* aclocal/canonicalize-tools.m4: Don't check for NM, OBJCOPY, SIZE,
STRIP.
* librdbg/include/Makefile.am: Merge-in
librdbg/include/rdbg/i386/Makefile.am,
librdbg/include/rdbg/m68k/Makefile.am, librdbg/include/rdbg/Makefile.am,
librdbg/include/rdbg/powerpc/Makefile.am.
* librdbg/include/rdbg/i386/Makefile.am,
librdbg/include/rdbg/powerpc/Makefile.am: Remove.
* configure.ac: Use AS_HELP_STRING(ada).
* aclocal/bspopts.m4: Use AS_HELP_STRING.
* aclocal/bsp-configure.m4: Require autoconf-2.59.
Use AC_CONFIG_HEADERS.
* aclocal/check-custom-bsp.m4: Add bspkit-support.
* aclocal/enable-rtemsbsp.m4: Use AS_HELP_STRING.
