* Makefile.am: Use "'"-quotes to pass args to bsp.mak.
* configure.ac: Use "'"-quotes for args to RTEMS_CONFIG_SUBDIRS.
Fix braino in comment on "exec".
Extend --enable-ada handling.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* wrapup/.cvsignore: Remove autom4te.cache.
* acinclude.m4: Apply RTEMS_CONFIGURE_ARGS_QUOTE.
* configure.ac: Add ada-tests.
* Makefile.am: Add preinstall-stamp.
Posix-BSP-Hacks:
* configure.ac: Add AM_CONDITIONAL(LIBCHIP).
Pass RTEMS_HOST to make/bsp.mak
* Makefile.am: Pass RTEMS_HOST to make/bsp.mak.
* wrapup/Makefile.am: Apply AM_CONDITIONAL(LIBCHIP).
* configure.ac: Add BSP_SUBDIRS.
* Makefile.am: Use BSP_SUBDIRS to setup SUBDIRS.
* configure.ac: Remove AC_CONFIG_SUBDIR(wrapup).
Cosmetic cleanups.
* wrapup/Makefile.am: Pick up ../libchip/rtc/$(ARCH)/librtcio.a and
../libchip/serial/$(ARCH)/libserialio.a.
* Makefile.am: Add rtems_makedir.
* configure.ac: Merge wrapup/configure.ac.
Cosmetic cleanups.
* Makefile.am: Add wrapup-SUBDIR.
* wrapup/ChangeLog: Remove.
* wrapup/configure.ac: Remove.
* Makefile.am: Append BARE_CPU_MODEL tp make/@RTEMS_BSP@.cache
creation (Make the bare BSP happy).
* configure.ac: Ditto.
* Makefile.am: Create make/@RTEMS_BSP@.cache.
Handle make/custom/*.cfgs.
Create make/custom/default.cfg.
* configure.ac: Add creation of make/custon/*.cfg.
Create make/${RTEMS_BSP}.cache.
Read make/${RTEMS_BSP}.cache
* Makefile.am: Clean $(PROJECT_RELEASE).
* acinclude.m4: Add test "$multilib" != "yes".
* config-ml.in: Remove.
* acinclude.m4: Cleanups.
* configure.ac: Build ${srcdir}/../../cpukit/ as ./exec/ instead of
${srcdir}/exec/.
Further adaptations to autoconf >= 2.50.
* acinclude.m4: New.
* Makefile.am: Remove tar-installation.
Prepend @exec@ to SUBDIRS.
* configure.ac: Switch to AC_CONFIG_SRCDIR([optman]).
Add RTEMS_ENABLE_MULTIPROCESSING.
Add RTEMS_CONFIG_SUBDIR([exec]...).
* ChangeLog: Fix bogus changelog entries.
* wrapup/Makefile.am: Remove libxdr.a.
* configure.ac: Remove librpc.
* Per PR233, moved librpc to exec. Ralf will patch after move.
The patches associated with this PR are out of date.
* configure.ac, wrapup/Makefile.am: Modified.
* librpc, librpc/ChangeLog: Removed.
* configure.ac: Remove CONFIG_SUBIDIRS libblock, libfs.
* configure.ac: Remove lib.
* config-ml.in: Take out arm and sh variants RTEMS does not support.
* DOS filesystem including FAT12, FAT16, and FAT32 support submitted.
* configure.ac: Modified to reflect addition.
* configure.ac: Add AC_CONFIG_SUBDIRS(optman). Remove
AC_CONFIG_COMMANDS.
* config-ml.in: New file. Imported from gcc and modified for RTEMS.
* Makefile.am: Use SUBDIRS = @subdirs@, require automake-1.5.
* configure.ac: Replace hst_subdirs with AC_CONFIG_SUBDIRS to make
autoconf-2.52 happy.
* configure.in: Remove.
* Makefile.am: install to $(exec_prefix)/@RTEMS_BSP@.
* configure.in: Switch to GNU-canonicalization.
* acinclude.m4: Remove.
* configure.in: add lib/libbsp to the GNU canonicalized
subdirectories, remove cfg_subdirs, cfg_subdirs1, hst_subdirs1.
* Makefile.am: remove cfg_subdirs, cfg_subdirs1, hst_subdirs1.
* ChangeLog: Fix typos.
* configure.in: add tests to the GNU canonicalized subdirectories,
* configure.in: add lib/libcpu to the GNU canonicalized subdirectories,
* configure.in: add lib to the GNU canonicalized subdirectories,
make the lib directory before configuring lib/.
* configure.in, Makefile.am: add exec to the GNU canonicalized
subdirectories.
* configure.in: add librtems++ to the GNU canonicalized subdirectories.
* configure.in: add libnetworking, librpc and librdb to the GNU
* configure.in: add libmisc and libchip to the GNU canonicalized
subdirectories.
* Makefile.am, acinclude.m4, configure.in: Introduce GNU
canonicalization to libfs/.
The approach is currently a bit of a hack as GNU canonicalization
does not support the per-BSP build some of the other directories
require. As more of the tree is converted, this will become less
of an issue.
* wrapup/Makefile.am: Added libfs.
* libfs created.
* configure.in: Added libfs subdirectory.
* configure.in: Add RTEMS_PROG_CC_FOR_TARGET,
RTEMS_CANONICALIZE_TOOLS.
* wrapup/Makefile.am: Include compile.am.
* configure.in: Add lib/libcpu and lib/libbsp to cfg_subdirs
