* librdbg/src/_servtgt.c: Convert C++ style comments to C style.
* libchip/network/greth.c, libchip/network/open_eth.c,
libchip/network/smc91111.c, libchip/network/sonic.c: Fix error
introduced by warning removal.
libchip/network/smc91111.c: Remove warnings and correct prototype
added earlier today.
* libchip/network/cs8900.c, libchip/network/greth.c,
libchip/network/i82586.c, libchip/network/open_eth.c,
libchip/network/sonic.c: Remove warnings -- use uintptr_t, properly
sized integers, and inttypes.h printf helpers.
* aclocal/rtems-cpu-subdirs.m4: New port to Altera NIOS II.
* libchip/shmdr/shm_driver.h: Merge sparc shm driver mods from 4.6.
* libchip/Makefile.am, libchip/preinstall.am: Merge SPARC updates from
4.6 branch. Original modifications by Gaisler Enterprises.
* libchip/network/greth.c, libchip/network/greth.h: New files.
* Makefile.am: Add ampolish3.
* ampolish3: New.
* aclocal/rtems-ampolish.m4: Reflect using in-sourcetree ampolish3.
* aclocal/rtems-ampolish.m4: New.
* configure.ac: Use RTEMS_AMPOLISH3.
* aclocal/version.m4: Updated to rtems-4.6.99.3.
PR 853/filesystem
* libchip/ide/ata.c, libchip/ide/ide_controller.c: The ata driver
should be modified to support the new exception scheme and to use the
handle parameter.
* wrapup/Makefile.am: Add preinstall.am.
* libchip/Makefile.am: Build libchip/network/smc91111.
* libchip/network/smc91111.c, libchip/network/smc91111config.h:
Eliminate cyg_int* crap.
* librdbg/Makefile.am: Add preinstall.am.
* aclocal/bsp-configure.m4: Add ampolish3.
New header guards.
* libchip/network/open_eth.c, libchip/network/open_eth.h:
Merger from rtems-4-6-branch.
libchip/network/smc91111exp.h
libchip/network/smc91111.h: New. Merger from rtems-4-6-branch.
* libchip/Makefile.am: Reflect adding smc91111*.
* optman/sapi/no-io.c: Change rtems_io_register_name to take a const
char *.
* libchip/i2c/i2c-2b-eeprom.c, libchip/i2c/i2c-ds1621.c: Eliminate
warnings.
* aclocal/prog-cc.m4: Remove RTEMS_USE_GCC.
Add RTEMS_RELLDFLAGS.
* automake/compile.am: Remove RTEMS_USE_GCC.
Remove RTEMS_RELLDFLAGS.
* configure.ac: Pass --enable-rtems-root to ada-tests/configure.
* libchip/network/if_media.h, libchip/network/mii.h:
Remove (Moved to cpukit).
* libchip/Makefile.am: Reflect having moved libchip/network/mii.h
and libchip/network/if_media.h.
* libchip/network/elnk.c, libchip/network/if_dc.c: Reflect mii.h and
if_media.h having moved.
* automake/compile.am, automake/host.am, automake/local.am,
automake/subdirs.am: Remove depend.
* configure.ac: Explicitly pass --libdir and --includedir to
testsuites.
* configure.ac: Reflect changes to testsuites.
* automake/compile.am: Remove GCCSPECS.
* aclocal/prog-cc.m4: Add GCCSPECS.
* aclocal/env-rtemsbsp.m4: Remove RTEMS_BSP_SPECS. Remove GCC_SPECS.
* libchip/i2c/i2c-2b-eeprom.c: Eliminate obsolete types.
* libchip/rtc/mc146818a.h: Eliminate obsolete types.
* libchip/network/dec21140.c, libchip/network/elnk.c: Use
libcpu/byteorder.h for i386.
* libchip/i2c/i2c-2b-eeprom.c, libchip/i2c/i2c-2b-eeprom.h,
libchip/i2c/i2c-ds1621.c, libchip/i2c/i2c-ds1621.h: New files.
* libchip/Makefile.am, libchip/preinstall.am, wrapup/Makefile.am:
added a simple API/library
for i2c devices and drivers for i2c 2-byte eeproms and a ds1621
temperature sensor; API is documented in libi2c.h
* configure.ac: Remove libnetworking, libnetworking/pppd.
* wrapup/Makefile.am: Remove libpppd.a,
* libnetworking/pppd/Makefile.am: Install rtemspppd.h and
rtemsdialer.h to $(includedir)/rtems.
* libnetworking/rtems_telnetd/icmds.c,
libnetworking/rtems_telnetd/Makefile.am,
libnetworking/rtems_telnetd/preinstall.am,
libnetworking/rtems_telnetd/pty.c,
libnetworking/rtems_telnetd/pty.h,
libnetworking/rtems_telnetd/README,
libnetworking/rtems_telnetd/telnetd.c,
libnetworking/rtems_telnetd/telnetd.h:
* configure.ac: Remove libnetworking/rtems_telnetd.
* libnetworking/Makefile.am: Remove rtems_telnetd.
* libnetworking/README: Remove (Obsolete).
* wrapup/Makefile.am: Remove libtelnetd.a (Moved to cpukit).
* libnetworking/pppd/Makefile.am: Use preinstall.am.
* librdbg/src/servbkpt.c, librdbg/src/servcon.c,
librdbg/src/servrpc.c, librdbg/src/servtgt.c
librdbg/src/servtsp.c: Include <errno.h> instead of <sys/errno.h>.
* bsp.pc.in: Remove CFLAGS_DEBUG_V, CFLAGS_OPTIMIZE_V.
* configure.ac: Move optman to the end of BSP_SUBDIRS.
* aclocal/bspopts.m4: Add missing m4 quotes.
* aclocal/version.m4: Updated to rtems-4.6.99.2.
* libchip/network/if_fxp.c, libchip/network/if_dc.c,
libchip/network/dec21140.c: Remove initialization of PCI bus.
