* configure.ac: Remove stray comments.
* automake/local.am, automake/host.am: Remove "debug".
lib/Makefile.am: Reflect having moved automake.
support/Makefile.am: Reflect having moved automake.
* automake/compile.am, automake/force-preinstall.am,
automake/host.am, automake/lib.am, automake/local.am,
automake/subdirs.am: New (copied from ../../automake).
* Makefile.am: Add bsp.pc.in
* bsp.pc.in: New (pkgconfig support).
* lib/Makefile.am: New (Required by 'make dist').
* lib/ChangeLog: Remove.
* lib/.cvsignore: Cleanup.
* configure.ac: Reflect having added lib/Makefile.am.
* configure.ac: Merge-in lib/libcpu/configure.ac.
Merge-in lib/libbsp/configure.ac.
* configure.ac: Use relative dir to make/${RTEMS_BSP}.cache.
* configure.ac: Merge-in librdbg/configure.ac.
* configure.ac: Merge-in libnetworking/configure.ac.
Merge-in parts of librdbg/configure.ac.
* configure.ac: Merge-in libchip/configure.ac.
Merge-in optman/configure.ac.
* support/version.c: Reflect having remove "rtems-" from
RTEMS_VERSION.
* configure.ac: Remove support for profile-variant.
* wrapup/Makefile.am: Use install-data-local to install librtemsbsp.a.
Let all-local: depend on $(LIB).
* wrapup/Makefile.am: Remove libmisc.
* configure.ac: Remove libmisc.
* configure.ac: Append RTEMS_CPU_MODEL to ac_configure_args.
Resort cache-checking.
* configure.ac: Expand RTEMS_CHECK_BSP_CACHE.
* configure.ac: Append CPU_CFLAGS, CFLAGS_OPTIMIZE_V,
CFLAGS_DEBUG_V, CFLAGS_PROFILE_V, RTEMS_BSP_FAMILY to
ac_configure_args.
* configure.ac: Use test "$RTEMS_BSP_FAMILY" != "bare" to setup
HAS_LIBBSP conditional (Solaris/bash incompatibility fix).
* Makefile.am: Use "'"-quotes to pass args to bsp.mak.
* configure.ac: Use "'"-quotes for args to RTEMS_CONFIG_SUBDIRS.
Fix braino in comment on "exec".
Extend --enable-ada handling.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* wrapup/.cvsignore: Remove autom4te.cache.
* acinclude.m4: Apply RTEMS_CONFIGURE_ARGS_QUOTE.
* configure.ac: Add ada-tests.
* Makefile.am: Add preinstall-stamp.
Posix-BSP-Hacks:
* configure.ac: Add AM_CONDITIONAL(LIBCHIP).
Pass RTEMS_HOST to make/bsp.mak
* Makefile.am: Pass RTEMS_HOST to make/bsp.mak.
* wrapup/Makefile.am: Apply AM_CONDITIONAL(LIBCHIP).
* configure.ac: Add BSP_SUBDIRS.
* Makefile.am: Use BSP_SUBDIRS to setup SUBDIRS.
* configure.ac: Remove AC_CONFIG_SUBDIR(wrapup).
Cosmetic cleanups.
* wrapup/Makefile.am: Pick up ../libchip/rtc/$(ARCH)/librtcio.a and
../libchip/serial/$(ARCH)/libserialio.a.
* Makefile.am: Add rtems_makedir.
* configure.ac: Merge wrapup/configure.ac.
Cosmetic cleanups.
* Makefile.am: Add wrapup-SUBDIR.
* wrapup/ChangeLog: Remove.
* wrapup/configure.ac: Remove.
* Makefile.am: Append BARE_CPU_MODEL tp make/@RTEMS_BSP@.cache
creation (Make the bare BSP happy).
* configure.ac: Ditto.
* Makefile.am: Create make/@RTEMS_BSP@.cache.
Handle make/custom/*.cfgs.
Create make/custom/default.cfg.
* configure.ac: Add creation of make/custon/*.cfg.
Create make/${RTEMS_BSP}.cache.
Read make/${RTEMS_BSP}.cache
* Makefile.am: Clean $(PROJECT_RELEASE).
* acinclude.m4: Add test "$multilib" != "yes".
* config-ml.in: Remove.
* acinclude.m4: Cleanups.
* configure.ac: Build ${srcdir}/../../cpukit/ as ./exec/ instead of
${srcdir}/exec/.
Further adaptations to autoconf >= 2.50.
* acinclude.m4: New.
* Makefile.am: Remove tar-installation.
Prepend @exec@ to SUBDIRS.
* configure.ac: Switch to AC_CONFIG_SRCDIR([optman]).
Add RTEMS_ENABLE_MULTIPROCESSING.
Add RTEMS_CONFIG_SUBDIR([exec]...).
* ChangeLog: Fix bogus changelog entries.
* wrapup/Makefile.am: Remove libxdr.a.
* configure.ac: Remove librpc.
* Per PR233, moved librpc to exec. Ralf will patch after move.
The patches associated with this PR are out of date.
* configure.ac, wrapup/Makefile.am: Modified.
* librpc, librpc/ChangeLog: Removed.
* configure.ac: Remove CONFIG_SUBIDIRS libblock, libfs.
* configure.ac: Remove lib.
* config-ml.in: Take out arm and sh variants RTEMS does not support.
