path: root/c/src/ChangeLog (follow)
* Avoid NULL dereference in printk() before libchip console initializedJennifer Averett2012-02-231-0/+10
| | | | | | | | With the addition of dynamically registered libchip serial devices, there is the need to be able to use printk() before the console driver has initialized the indirect pointer table. This lets printk() support routines call pass a control structure directly without a lookup through the uninitialized indirect one.
* 2011-12-13 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-131-0/+7
| | | | | | | * libchip/i2c/spi-memdrv.c: Make spi_memdrv_minor2param_ptr, spi_memdrv_wait_ms static. * libchip/i2c/spi-sd-card.c: Make sd_card_compute_crc7, sd_card_compute_crc16 static.
* 2011-12-10 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-101-0/+4
| | | | * configure.ac (CFLAGS): Add -Wmissing-prototypes.
* 2011-12-09 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-091-0/+1
| | | | * libchip/network/sonic.c: Activate SONIC_STATIC.
* 2011-12-09 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-091-0/+4
| | | | * libchip/network/if_fxp.c: Add missing initializer.
* 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-081-0/+5
| | | | | PR 1589/build * configure.ac: Remove obsolete optional manager capability.
* 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-081-0/+11
| | | | | | | | | | | PR 1589/build * optman/.cvsignore, optman/Makefile.am, optman/preinstall.am, optman/rtems/no-barrier.c, optman/rtems/no-dpmem.c, optman/rtems/no-event.c, optman/rtems/no-mp.c, optman/rtems/no-msg.c, optman/rtems/no-part.c, optman/rtems/no-region.c, optman/rtems/no-rtmon.c, optman/rtems/no-sem.c, optman/rtems/no-signal.c, optman/rtems/no-timer.c, optman/sapi/no-ext.c, optman/sapi/no-io.c: Removed.
* 2011-12-08 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-081-0/+6
| | | | | | * libchip/network/sonic.c: Make sonic_enable_interrupts, sonic_disable_interrupts, sonic_clear_interrupts, sonic_command static.
* 2011-12-06 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-061-0/+5
| | | | | * libchip/ide/ata.c: Make ata_interrupt_on, ata_interrupt_off, ata_interrupt_isOn static.
| | | | | * libchip/serial/mc68681.c (mc68681_open): Var "status" needs to be signed.
* 2011-12-05 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-12-051-0/+5
| | | | | PR 1975/misc * libchip/ide/ata.c, libchip/ide/ata_util.c: Fixed warnings.
* 2011-12-03 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-031-0/+2
| | | | | * libchip/ide/ata.c: Make ata_interrupt_handler static. * libchip/ide/ide_controller.c: Include libchip/ide_ctrl.h.
* 2011-12-03 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-031-0/+4
| | | | * libchip/display/disp_hcms29xx.c: Add missing initializer.
* 2011-11-09 Jennifer Averett <jennifer.averett@oarcorp.com>Joel Sherrill2011-11-091-0/+5
| | | | | PR 1934/bsps * libchip/serial/ns16550.c: Change to unsigned variable.
* 2011-11-07 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-11-071-0/+4
| | | | * libchip/serial/serial.h: Declare Console_Port_Minor.
* 2011-11-06 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-11-061-0/+5
| | | | | PR 1945/cpukit * libchip/i2c/spi-memdrv.c: Replace rtems_off64_t with off_t.
* 2011-10-28 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-10-281-0/+5
| | | | | PR 1944/misc * libchip/serial/mc68681.c: Remove #if 0.
* 2011-10-26 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-261-0/+5
| | | | | * libchip/serial/ns16550.c (ns16550_init): Remove unused var "ucTrash".
* 2011-10-23 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-231-0/+5
| | | | | * libchip/network/smc91111.c (lan91cxx_recv): Define var "lp" conditionally (Avoid warning).
* 2011-10-22 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-221-0/+2
| | | | | * libchip/network/dec21140.c (dec21140_rxDaemon): Remove unused var "tbase".
* 2011-10-22 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-221-0/+7
| | | | | | | * libchip/rtc/mc146818a.c (mc146818a_initialize): Remove unused var "getReg". * libchip/rtc/mc146818a.c (mc146818a_set_time): Remove unused var "getReg".
* 2011-10-20 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-201-0/+4
| | | | * libchip/display/disp_hcms29xx.c: Remove ARRAY_COUNT (unused).
* 2011-10-20 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-201-0/+5
| | | | | PR 1940/misc: * libchip/serial/ns16550.c: Reflect changes to console-driver.
* 2011-10-19 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-191-0/+4
| | | | * libchip/network/smc91111.c: Use PRIxPTR to print pointers.
* 2011-10-18 Jennifer Averett <Jennifer.Averett@OARcorp.com>Jennifer Averett2011-10-181-0/+7
| | | | | | | PR 1917/bsps * libchip/serial/mc68681.c, libchip/serial/ns16550.c, libchip/serial/serial.h, libchip/serial/z85c30.c: Modifications to add dynamic tables for libchip serial drivers.
* 2011-10-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-171-0/+5
| | | | | * libchip/rtc/icm7170.c (icm7170_get_time): Remove unused var setReg. * libchip/rtc/icm7170.c (icm7170_set_time): Remove unused var getReg.
* 2011-10-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-111-0/+1
| | | | * libchip/network/smc91111.c: Eliminate unused var "success".
* Fix changelog entry.Ralf Corsepius2011-10-111-1/+1
* 2011-10-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-111-0/+4
| | | | * libchip/serial/mc68681.c: Eliminate unused var "success".
* 2011-10-10 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-101-0/+1
| | | | * libchip/serial/z85c30.c: Eliminate unused var "dummy".
* 2011-10-10 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-101-0/+4
| | | | * libchip/network/sonic.c: Don't cast pointers to uint32_t.
* 2011-10-09 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-091-0/+7
| | | | | | | * libchip/network/greth.c, libchip/network/open_eth.c libchip/network/sonic.c: Eliminate evil typecasts. * libchip/network/greth.h, libchip/network/open_eth.h, libchip/network/sonic.h: Use void* for addresses.
* 2011-08-30 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-08-301-0/+5
| | | | | * libchip/network/smc91111exp.h, libchip/network/smc91111.c: Use BSP_FEATURE_IRQ_EXTENSION define.
* 2011-08-30 Peter Dufault <dufault@hda.com>Sebastian Huber2011-08-301-0/+13
| | | | | | | | | | | | | * libchip/network/smc91111.c: Modify to support the MPC5554 using new exceptions. Fix where the networking status is being dumped to a single thousand-character line. Add support for when the chip loaded it's MAC address from a serial chip at reset (the SMC91111_ENADDR_IS_SETUP option). Call lan91cxx_start() every time the the device is initialized. Without this change the chip can not be "upped" once it has been downed. * c/src/libchip/network/smc91111.h: Change the "#ifdef expression" to "#if expression". * c/src/libchip/network/smc91111exp.h: Add support for new exceptions.
* 2011-07-11 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-07-111-0/+5
| | | | | * libchip/serial/ns16550_p.h, libchip/serial/ns16550.c: Remove interrupt handler during last close.
* 2011-07-07 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-07-071-0/+8
| | | | | | | | * libchip/display/disp_hcms29xx.c, libchip/flash/am29lv160.c, libchip/i2c/i2c-2b-eeprom.c, libchip/i2c/i2c-ds1621.c, libchip/i2c/spi-flash-m25p40.c, libchip/i2c/spi-fram-fm25l256.c, libchip/i2c/spi-memdrv.c, libchip/rtc/ds1375.c: Eliminate use of GNU old-style field designator extension as recommended by clang.
* 2011-07-07 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-07-071-0/+4
| | | | * libchip/i2c/spi-memdrv.h: Add missing semi-colon.
* 2011-06-07 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-06-071-0/+8
| | | | | | | | * aclocal/bspopts.m4: Added macros for cache options RTEMS_BSPOPTS_SET_DATA_CACHE_ENABLED, RTEMS_BSPOPTS_HELP_DATA_CACHE_ENABLED, RTEMS_BSPOPTS_SET_INSTRUCTION_CACHE_ENABLED, and RTEMS_BSPOPTS_HELP_INSTRUCTION_CACHE_ENABLED.
* 2011-03-16 Jennifer Averett <jennifer.averett@OARcorp.com>Joel Sherrill2011-03-161-0/+5
| | | | | PR 1729/cpukit * aclocal/check-smp.m4, aclocal/enable-smp.m4: New files.
* 2011-03-07 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-03-071-0/+1
| | | | * aclocal/rtems-top.m4: Add pkgdatadir.
* 2011-03-07 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-03-071-0/+4
| | | | * configure.ac: Remove dead code.
* 2011-03-04 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-03-041-0/+5
| | | | | * aclocal/rtems-top.m4, aclocal/version.m4: Rename RTEMS_API into _RTEMS_API.
* 2011-02-25 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-251-0/+7
| | | | | | | * aclocal/canonical-target-name.m4: Stop pretending no_cpu* was buildable. Derive RTEMS_CPU from "$host_cpu". Error out if "$host" doesn't match "*-*-rtems*".
* 2011-02-22 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-221-0/+4
| | | | * configure.ac: Remove AM_CONDITIONAL(HAS_POSIX) (Unused).
* 2011-02-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-02-161-0/+142
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ada-tests/mptests/mp01/mp01.adb, ada-tests/mptests/mp01/mptest.adb, ada-tests/mptests/mp01/mptest.ads, ada-tests/mptests/mp01/node1/mp01_node1.adb, ada-tests/mptests/mp01/node2/mp01_node2.adb, ada-tests/mptests/mp02/mptest.adb, ada-tests/mptests/mp02/mptest.ads, ada-tests/mptests/mp02/node1/mp02_node1.adb, ada-tests/mptests/mp02/node2/mp02_node2.adb, ada-tests/mptests/mp03/mptest.adb, ada-tests/mptests/mp03/mptest.ads, ada-tests/mptests/mp03/node1/mp03_node1.adb, ada-tests/mptests/mp03/node2/mp03_node2.adb, ada-tests/mptests/mp04/mptest.adb, ada-tests/mptests/mp04/mptest.ads, ada-tests/mptests/mp04/node1/mp04_node1.adb, ada-tests/mptests/mp04/node2/mp04_node2.adb, ada-tests/mptests/mp05/mptest.adb, ada-tests/mptests/mp05/mptest.ads, ada-tests/mptests/mp05/node1/mp05_node1.adb, ada-tests/mptests/mp05/node2/mp05_node2.adb, ada-tests/mptests/mp06/mptest.adb, ada-tests/mptests/mp06/mptest.ads, ada-tests/mptests/mp06/node1/mp06_node1.adb, ada-tests/mptests/mp06/node2/mp06_node2.adb, ada-tests/mptests/mp07/mptest.adb, ada-tests/mptests/mp07/mptest.ads, ada-tests/mptests/mp07/node1/mp07_node1.adb, ada-tests/mptests/mp07/node2/mp07_node2.adb, ada-tests/mptests/mp08/mptest.adb, ada-tests/mptests/mp08/mptest.ads, ada-tests/mptests/mp08/node1/mp08_node1.adb, ada-tests/mptests/mp08/node2/mp08_node2.adb, ada-tests/mptests/mp09/mptest.adb, ada-tests/mptests/mp09/mptest.ads, ada-tests/mptests/mp09/node1/mp09_node1.adb, ada-tests/mptests/mp09/node2/mp09_node2.adb, ada-tests/mptests/mp10/mptest.adb, ada-tests/mptests/mp10/mptest.ads, ada-tests/mptests/mp10/node1/mp10_node1.adb, ada-tests/mptests/mp10/node2/mp10_node2.adb, ada-tests/mptests/mp11/mptest.adb, ada-tests/mptests/mp11/mptest.ads, ada-tests/mptests/mp11/node1/mp11_node1.adb, ada-tests/mptests/mp11/node2/mp11_node2.adb, ada-tests/mptests/mp12/mptest.adb, ada-tests/mptests/mp12/mptest.ads, ada-tests/mptests/mp12/node1/mp12_node1.adb, ada-tests/mptests/mp12/node2/mp12_node2.adb, ada-tests/mptests/mp13/mptest.adb, ada-tests/mptests/mp13/mptest.ads, ada-tests/mptests/mp13/node1/mp13_node1.adb, ada-tests/mptests/mp13/node2/mp13_node2.adb, ada-tests/mptests/mp14/mptest.adb, ada-tests/mptests/mp14/mptest.ads, ada-tests/mptests/mp14/node1/mp14_node1.adb, ada-tests/mptests/mp14/node2/mp14_node2.adb, ada-tests/samples/base_mp/mptest.adb, ada-tests/samples/base_mp/mptest.ads, ada-tests/samples/base_sp/base_sp.adb, ada-tests/samples/base_sp/sptest.adb, ada-tests/samples/base_sp/sptest.ads, ada-tests/samples/hello/hello.adb, ada-tests/samples/hello/sptest.adb, ada-tests/samples/hello/sptest.ads, ada-tests/samples/nsecs/nsecs.adb, ada-tests/samples/nsecs/sptest.adb, ada-tests/samples/nsecs/sptest.ads, ada-tests/samples/ticker/sptest.adb, ada-tests/samples/ticker/sptest.ads, ada-tests/samples/ticker/ticker.adb, ada-tests/sptests/sp01/sp01.adb, ada-tests/sptests/sp01/sptest.adb, ada-tests/sptests/sp01/sptest.ads, ada-tests/sptests/sp02/sp02.adb, ada-tests/sptests/sp02/sptest.adb, ada-tests/sptests/sp02/sptest.ads, ada-tests/sptests/sp03/sp03.adb, ada-tests/sptests/sp03/sptest.adb, ada-tests/sptests/sp03/sptest.ads, ada-tests/sptests/sp04/sp04.adb, ada-tests/sptests/sp04/sptest.adb, ada-tests/sptests/sp04/sptest.ads, ada-tests/sptests/sp05/sp05.adb, ada-tests/sptests/sp05/sptest.adb, ada-tests/sptests/sp05/sptest.ads, ada-tests/sptests/sp06/sp06.adb, ada-tests/sptests/sp06/sptest.adb, ada-tests/sptests/sp06/sptest.ads, ada-tests/sptests/sp07/sp07.adb, ada-tests/sptests/sp07/sptest.adb, ada-tests/sptests/sp07/sptest.ads, ada-tests/sptests/sp08/sp08.adb, ada-tests/sptests/sp08/sptest.adb, ada-tests/sptests/sp08/sptest.ads, ada-tests/sptests/sp09/sp09.adb, ada-tests/sptests/sp09/sptest.adb, ada-tests/sptests/sp09/sptest.ads, ada-tests/sptests/sp11/sp11.adb, ada-tests/sptests/sp11/sptest.adb, ada-tests/sptests/sp11/sptest.ads, ada-tests/sptests/sp12/sp12.adb, ada-tests/sptests/sp12/sptest.adb, ada-tests/sptests/sp12/sptest.ads, ada-tests/sptests/sp13/sp13.adb, ada-tests/sptests/sp13/sptest.adb, ada-tests/sptests/sp13/sptest.ads, ada-tests/sptests/sp14/sp14.adb, ada-tests/sptests/sp14/sptest.adb, ada-tests/sptests/sp14/sptest.ads, ada-tests/sptests/sp15/sp15.adb, ada-tests/sptests/sp15/sptest.adb, ada-tests/sptests/sp15/sptest.ads, ada-tests/sptests/sp16/sp16.adb, ada-tests/sptests/sp16/sptest.adb, ada-tests/sptests/sp16/sptest.ads, ada-tests/sptests/sp17/sp17.adb, ada-tests/sptests/sp17/sptest.adb, ada-tests/sptests/sp17/sptest.ads, ada-tests/sptests/sp19/sp19.adb, ada-tests/sptests/sp19/sptest.adp, ada-tests/sptests/sp19/sptest.ads, ada-tests/sptests/sp20/sp20.adb, ada-tests/sptests/sp20/sptest.adb, ada-tests/sptests/sp20/sptest.ads, ada-tests/sptests/sp22/sp22.adb, ada-tests/sptests/sp22/sptest.adb, ada-tests/sptests/sp22/sptest.ads, ada-tests/sptests/sp23/sp23.adb, ada-tests/sptests/sp23/sptest.adb, ada-tests/sptests/sp23/sptest.ads, ada-tests/sptests/sp24/sp24.adb, ada-tests/sptests/sp24/sptest.adb, ada-tests/sptests/sp24/sptest.ads, ada-tests/sptests/sp25/sp25.adb, ada-tests/sptests/sp25/sptest.adb, ada-tests/sptests/sp25/sptest.ads, ada-tests/support/test_support.adb, ada-tests/tmtests/tm01/tm01.adb, ada-tests/tmtests/tm01/tmtest.adb, ada-tests/tmtests/tm01/tmtest.ads, ada-tests/tmtests/tm02/tm02.adb, ada-tests/tmtests/tm02/tmtest.adb, ada-tests/tmtests/tm02/tmtest.ads, ada-tests/tmtests/tm03/tm03.adb, ada-tests/tmtests/tm03/tmtest.adb, ada-tests/tmtests/tm03/tmtest.ads, ada-tests/tmtests/tm04/tm04.adb, ada-tests/tmtests/tm04/tmtest.adb, ada-tests/tmtests/tm04/tmtest.ads, ada-tests/tmtests/tm05/tm05.adb, ada-tests/tmtests/tm05/tmtest.adb, ada-tests/tmtests/tm05/tmtest.ads, ada-tests/tmtests/tm06/tm06.adb, ada-tests/tmtests/tm06/tmtest.adb, ada-tests/tmtests/tm06/tmtest.ads, ada-tests/tmtests/tm07/tm07.adb, ada-tests/tmtests/tm07/tmtest.adb, ada-tests/tmtests/tm07/tmtest.ads, ada-tests/tmtests/tm08/tm08.adb, ada-tests/tmtests/tm08/tmtest.adb, ada-tests/tmtests/tm08/tmtest.ads, ada-tests/tmtests/tm09/tm09.adb, ada-tests/tmtests/tm09/tmtest.adb, ada-tests/tmtests/tm09/tmtest.ads, ada-tests/tmtests/tm10/tm10.adb, ada-tests/tmtests/tm10/tmtest.adb, ada-tests/tmtests/tm10/tmtest.ads, ada-tests/tmtests/tm11/tm11.adb, ada-tests/tmtests/tm11/tmtest.adb, ada-tests/tmtests/tm11/tmtest.ads, ada-tests/tmtests/tm12/tm12.adb, ada-tests/tmtests/tm12/tmtest.adb, ada-tests/tmtests/tm12/tmtest.ads, ada-tests/tmtests/tm13/tm13.adb, ada-tests/tmtests/tm13/tmtest.adb, ada-tests/tmtests/tm13/tmtest.ads, ada-tests/tmtests/tm14/tm14.adb, ada-tests/tmtests/tm14/tmtest.adb, ada-tests/tmtests/tm14/tmtest.ads, ada-tests/tmtests/tm15/tm15.adb, ada-tests/tmtests/tm15/tmtest.adb, ada-tests/tmtests/tm15/tmtest.ads, ada-tests/tmtests/tm16/tm16.adb, ada-tests/tmtests/tm16/tmtest.adb, ada-tests/tmtests/tm16/tmtest.ads, ada-tests/tmtests/tm17/tm17.adb, ada-tests/tmtests/tm17/tmtest.adb, ada-tests/tmtests/tm17/tmtest.ads, ada-tests/tmtests/tm18/tm18.adb, ada-tests/tmtests/tm18/tmtest.adb, ada-tests/tmtests/tm18/tmtest.ads, ada-tests/tmtests/tm19/tm19.adb, ada-tests/tmtests/tm19/tmtest.adb, ada-tests/tmtests/tm19/tmtest.ads, ada-tests/tmtests/tm20/tm20.adb, ada-tests/tmtests/tm20/tmtest.adb, ada-tests/tmtests/tm20/tmtest.ads, ada-tests/tmtests/tm21/tm21.adb, ada-tests/tmtests/tm21/tmtest.adb, ada-tests/tmtests/tm21/tmtest.ads, ada-tests/tmtests/tm22/tm22.adb, ada-tests/tmtests/tm22/tmtest.adb, ada-tests/tmtests/tm22/tmtest.ads, ada-tests/tmtests/tm23/tm23.adb, ada-tests/tmtests/tm23/tmtest.adb, ada-tests/tmtests/tm23/tmtest.ads, ada-tests/tmtests/tm24/tm24.adb, ada-tests/tmtests/tm24/tmtest.adb, ada-tests/tmtests/tm24/tmtest.ads, ada-tests/tmtests/tm25/tm25.adb, ada-tests/tmtests/tm25/tmtest.adb, ada-tests/tmtests/tm25/tmtest.ads, ada-tests/tmtests/tm28/tm28.adb, ada-tests/tmtests/tm28/tmtest.adb, ada-tests/tmtests/tm28/tmtest.ads, ada-tests/tmtests/tm29/tm29.adb, ada-tests/tmtests/tm29/tmtest.adb, ada-tests/tmtests/tm29/tmtest.ads, ada-tests/tmtests/tmck/tmck.adb, ada-tests/tmtests/tmck/tmtest.adb, ada-tests/tmtests/tmck/tmtest.ads, ada-tests/tmtests/tmoverhd/dummy_rtems.adb, ada-tests/tmtests/tmoverhd/dummy_rtems.ads, ada-tests/tmtests/tmoverhd/tmoverhd.adb, ada-tests/tmtests/tmoverhd/tmtest.adb, ada-tests/tmtests/tmoverhd/tmtest.ads: Account for RTEMS binding child package rework. Eliminate all warnings.
* 2011-02-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-02-161-0/+21
| | | | | | | | | | | | | | | | | | | | | * ada/Makefile.am, ada/preinstall.am, ada/rtems.adb, ada/rtems.ads: Split RTEMS Ada95 binding into a master package and a child package per Manager. This is better Ada style. * ada/rtems-barrier.adb, ada/rtems-barrier.ads, ada/rtems-clock.adb, ada/rtems-clock.ads, ada/rtems-cpu_usage.ads, ada/rtems-debug.adb, ada/rtems-debug.ads, ada/rtems-event.adb, ada/rtems-event.ads, ada/rtems-extension.adb, ada/rtems-extension.ads, ada/rtems-fatal.adb, ada/rtems-fatal.ads, ada/rtems-interrupt.ads, ada/rtems-io.adb, ada/rtems-io.ads, ada/rtems-message_queue.adb, ada/rtems-message_queue.ads, ada/rtems-object.adb, ada/rtems-object.ads, ada/rtems-partition.adb, ada/rtems-partition.ads, ada/rtems-port.adb, ada/rtems-port.ads, ada/rtems-rate_monotonic.adb, ada/rtems-rate_monotonic.ads, ada/rtems-region.adb, ada/rtems-region.ads, ada/rtems-semaphore.adb, ada/rtems-semaphore.ads, ada/rtems-signal.adb, ada/rtems-signal.ads, ada/rtems-stack_checker.ads, ada/rtems-tasks.adb, ada/rtems-tasks.ads, ada/rtems-timer.adb, ada/rtems-timer.ads: New files.
* 2011-02-16 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-02-161-0/+5
| | | | | * libchip/serial/ns16550.c: Revert previous commit and extend existing mechanic.
* 2011-02-15 Jennifer AverettJoel Sherrill2011-02-151-0/+5
| | | | | * libchip/serial/ns16550.c, libchip/serial/ns16550_p.h: Support i386 style IRQs.
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-111-0/+5
| | | | | * libchip/network/smc91111config.h: Use "__asm__" instead of "asm" for improved c99-compliance.
* 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-021-0/+4
| | | | * configure.ac: Require autoconf-2.68, automake-1.11.1.
