path: root/c/src/ChangeLog (follow)
* 2001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-171-0/+6
| | | | | | * Makefile.am: Use SUBDIRS = @subdirs@, require automake-1.5. * configure.ac: Replace hst_subdirs with AC_CONFIG_SUBDIRS to make autoconf-2.52 happy.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-111-0/+6
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-051-0/+4
| | | | * Makefile.am: install to $(exec_prefix)/@RTEMS_BSP@.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-091-0/+4
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-021-0/+4
* 2000-10-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-311-0/+6
| | | | | | * configure.in: Switch to GNU-canonicalization. * Makefile.am: Reflect changes to configure.in. * acinclude.m4: Remove.
* 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-271-2/+9
| | | | | | | * configure.in: add lib/libbsp to the GNU canonicalized subdirectories, remove cfg_subdirs, cfg_subdirs1, hst_subdirs1. * Makefile.am: remove cfg_subdirs, cfg_subdirs1, hst_subdirs1. * ChangeLog: Fix typos.
* 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-271-0/+4
| | | | * configure.in: add tests to the GNU canonicalized subdirectories,
* 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-261-0/+4
| | | | * configure.in: add lib/libcpu to the GNU canonicalized subdirectories,
* 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-261-0/+5
| | | | | * configure.in: add lib to the GNU canonicalized subdirectories, make the lib directory before configuring lib/.
* 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-251-0/+5
| | | | | * configure.in, Makefile.am: add exec to the GNU canonicalized subdirectories.
* 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-251-0/+4
| | | | * configure.in: add librtems++ to the GNU canonicalized subdirectories.
| | | | | * configure.in: add libnetworking, librpc and librdb to the GNU canonicalized subdirectories.
| | | | | * configure.in: add libmisc and libchip to the GNU canonicalized subdirectories.
* 2000-10-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-241-0/+9
| | | | | | | | | * Makefile.am, acinclude.m4, configure.in: Introduce GNU canonicalization to libfs/. The approach is currently a bit of a hack as GNU canonicalization does not support the per-BSP build some of the other directories require. As more of the tree is converted, this will become less of an issue.
* 2000-10-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-181-0/+4
| | | | * wrapup/Makefile.am: Added libfs.
* 2000-10-18 Chris Johns <ccj@acm.org>Joel Sherrill2000-10-181-0/+5
| | | | | * libfs created. * configure.in: Added libfs subdirectory.
* 2000-09-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-121-0/+5
| | | | | * configure.in: Add RTEMS_PROG_CC_FOR_TARGET, RTEMS_CANONICALIZE_TOOLS.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-1/+5
| | | | * wrapup/Makefile.am: Include compile.am.
* 2000-08-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-08-301-0/+4
| | | | * configure.in: Add lib/libcpu and lib/libbsp to cfg_subdirs
