many different versions of new exception handling code to shared sources.
* optman/Makefile.am, optman/preinstall.am: Add stubs for file system,
console, and libio. This shrinks the memory requirements but Joel has
not figured out how best to present this to application space.
* optman/no-console.c, optman/no-filesystem.c, optman/no-libio.c:
New files.
* optman/sapi/no-io.c: Split IO Manager into one function per file so
now we only need required initialization methods.
* optman/sapi/no-io.c: Eliminate maximum_drivers configuration
parameter since it was used to configure a no longer used feature.
Device names are now part of the filesystem not in a table.
* optman/Makefile.am, optman/preinstall.am, optman/rtems/no-dpmem.c,
optman/rtems/no-event.c, optman/rtems/no-mp.c, optman/rtems/no-msg.c,
optman/rtems/no-part.c, optman/rtems/no-region.c,
optman/rtems/no-rtmon.c, optman/rtems/no-sem.c,
optman/rtems/no-signal.c, optman/rtems/no-timer.c,
optman/sapi/no-ext.c: Add optional manager stub for Barrier. Simplify
other optional managers so using them reduces application size
instead of increasing it.
* optman/rtems/no-barrier.c: New file.
* libchip/network/dec21140.c, libchip/network/elnk.c: i386-specific
adjustments to pci-API changes.
* libchip/network/dec21140.c, libchip/network/elnk.c,
libchip/network/if_dc.c: powerpc-specific adjustments to pci-API
changes.
* libchip/network/dec21140.c, libchip/network/if_dc.c,
libchip/network/if_fxp.c: Reflect changes to pci-API.
* libchip/network/elnk.c: Use ioctl_command_t as ioctl argument.
* libchip/network/if_dc.c: Use ioctl_command_t as ioctl argument.
* aclocal/target.m4: Strip CFLAGS (Hack to prevent bsp-cflags from
being used to compile "tools").
* libchip/network/sonic.c: Rename Dump_Buffer to rtems_print_buffer.
* libchip/network/cs8900.c, libchip/network/cs8900.h,
libchip/network/greth.c, libchip/network/greth.h: Correct license URL
and/or fix mistake in copyright notice. Both of these mistakes appear
to be from code submitted after these changes were made previously.
* wrapup/Makefile.am: Use MKDIR_P instead of mkdir_p.
* libchip/Makefile.am: Correct path to README.tulipclone.
* libchip/ide/ata.c: Remove superfluous type casts.
* libchip/ide/ata.c, libchip/network/elnk.c, optman/rtems/no-msg.c:
Use size_t for sizes.
fixed synchronization bug between ata.c and bdbuf.c
* libchip/i2c/i2c-2b-eeprom.c, libchip/i2c/i2c-2b-eeprom.h,
* libchip/i2c/i2c-ds1621.c, libchip/i2c/i2c-ds1621.h:
Added SLAC/Stanford Authorship Note / Copyright + Liability Disclaimer.
* libchip/network/dec21140.c, libchip/network/if_fxp.c: Use
* librtems++/include/rtems++/rtemsEvent.h,
librtems++/include/rtems++/rtemsMessageQueue.h,
librtems++/include/rtems++/rtemsSemaphore.h,
librtems++/include/rtems++/rtemsTask.h, librtems++/src/rtemsEvent.cc,
librtems++/src/rtemsMessageQueue.cc,
librtems++/src/rtemsSemaphore.cc, librtems++/src/rtemsTask.cc: Change
rtems_unsigned32 to uint32_t.
PR 1181/bsps
* optman/rtems/no-msg.c: Clean up dead code.
* aclocal/rtems-ampolish.m4: Use am_aux_dir/ampolish3.
* aclocal/rtems-ampolish.m4: Require AM_MAINTAINER_MODE.
* aclocal/rtems-top.m4: Remove RTEMS_AMPOLISH.
* aclocal/project-root.m4: Require RTEMS_AMPOLISH.
* Makefile.am: Remove ampolish3.
* libchip/network/dec21140.c: Fix spacing -- remove long sections of
blank lines.
* configure.ac: Remove RTEMS_AMPOLISH3.
* aclocal/bsp-configure.m4: AC_PREREQ(2.60).
Remove checks for AMPOLISH3.
* aclocal/rtems-ampolish.m4: Pick up ampolish3 from ac_aux_dir.
* aclocal/rtems-top.m4: Add RTEMS_AMPOLISH3.
* ampolish3: Remove.
* aclocal/target.m4: Remove RTEMS_OUTPUT_BUILD_SUBDIRS.
* aclocal/prog-cc.m4: Remove CFLAGS.
* configure.ac: Don't explictly pass CFLAGS_OPTIMIZE_V, CPU_CFLAGS.
Compose CFLAGS. Append CFLAGS to ac_configure_args.
* aclocal/rtems-cpu-subdirs.m4: Add bfin.
* automake/compile.am: Use hard-coded RTEMS_* flags.
* aclocal/rtems-top.m4: Remove RTEMS_API.
* aclocal/version.m4: Add RTEMS_API. Bump RTEMS_API to 4.8.
* aclocal/prog-ccas.m4: Adaptations to automake-1.10.
* aclocal/prog-cxx.m4: Add AC_PROG_CXXCPP.
* aclocal/version.m4: Bump version to 4.7.99.0.
* librdbg/src/_servtgt.c: Convert C++ style comments to C style.
* libchip/network/greth.c, libchip/network/open_eth.c,
libchip/network/smc91111.c, libchip/network/sonic.c: Fix error
introduced by warning removal.
libchip/network/smc91111.c: Remove warnings and correct prototype
added earlier today.
* libchip/network/cs8900.c, libchip/network/greth.c,
libchip/network/i82586.c, libchip/network/open_eth.c,
libchip/network/sonic.c: Remove warnings -- use uintptr_t, properly
sized integers, and inttypes.h printf helpers.
* aclocal/rtems-cpu-subdirs.m4: New port to Altera NIOS II.
* libchip/shmdr/shm_driver.h: Merge sparc shm driver mods from 4.6.
* libchip/Makefile.am, libchip/preinstall.am: Merge SPARC updates from
4.6 branch. Original modifications by Gaisler Enterprises.
* libchip/network/greth.c, libchip/network/greth.h: New files.
* Makefile.am: Add ampolish3.
* ampolish3: New.
* aclocal/rtems-ampolish.m4: Reflect using in-sourcetree ampolish3.
* aclocal/rtems-ampolish.m4: New.
* configure.ac: Use RTEMS_AMPOLISH3.
* aclocal/version.m4: Updated to rtems-4.6.99.3.
