* target.cfg.in: Comment out RTEMS_HOST, RTEMS_CROSS_TARGET.
* Makefile.am: Switch to GNU canonicalization.
* target.cfg.in: Comment out DEFS.
that contains:
* Removes MKLIB
handling)
Addtional major bugs:
<corsepiu@faw.uni-ulm.de> which does the following:
This is the configuration cleanup patch:
Main changes:
* TARGET_ARCH removed
* target.cfg.in moved to c/make/target.cfg.in (Only configured once for
all BSPs of a target)
* BARE_XXX variables appended to bsp.cfg.in
* autogen renamed to bootstrap
* removed stray variables from make/custom/*.cfg
rm c/src/make/target.cfg.in
cp autogen bootstrap
mkdir c/make
cp make/target.cfg.in c/make/target.cfg.in
rm make/target.cfg.in
rm autogen
patch -p1 < rtems-rc-19991105-1.diff
