upgrade to that version.
Close #3387.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
for details.
* configure.ac: Remove reference to bare BSP.
Simplify RTEMS_BSP_LIST setup.
* configure.ac: Use MKDIR_P instead of mkdir_p.
* configure.ac: Rework checking for BSPs.
* acinclude.m4: Remove RTEMS_CHECK_CPU.
* configure.ac: Remove RTEMS_CHECK_CPU, RTEMS_ENABLE_BARE.
* configure.ac: Add --with-project-root, --with-project-top to
rtems_bsp_configure.
* Makefile.am: Cosmetics.
* configure.ac: Add support for --disable-rtemsbsp. Cosmetics.
* Makefile.am: Remove RTEMS_BSP-subdir rule.
* configure.ac: Let AC_CONFIG_FILES(Makefile..) append explictit
rules for RTEMS_BSP-subdirs.
* configure.ac: Cosmetics.
* acinclude.m4: Merge-in former ../aclocal/config-subdirs.m4.
* configure.ac: remove RTEMS_CANONICAL_HOST.
* configure.ac: Fix --enable-rtemsbsp= handling.
* configure.ac: Apply RTEMS_CONFIGURE_ARGS_QUOTE.
* Makefile.am: Remove make from SUBDIRS.
* configure.ac: Remove make from CONFIG_SUBDIRS, cosmetics.
* configure.in: Remove.
