* configure.ac: Cosmetics.
* Makefile.am: Cosmetics.
* acinclude.m4: Merge-in former ../aclocal/config-subdirs.m4.
* configure.ac: remove RTEMS_CANONICAL_HOST.
* configure.ac: Fix --enable-rtemsbsp= handling.
* configure.ac: Apply RTEMS_CONFIGURE_ARGS_QUOTE.
* Makefile.am: Remove make from SUBDIRS.
* configure.ac: Remove make from CONFIG_SUBDIRS, cosmetics.
* configure.in: Remove.
* configure.in: Use ${MAKE} in message at the end of the
configure.in.
* configure.in: Apply _RTEMS_ADJUST_SRCDIR.
* configure.in: catch -enable-rtemsbsp (Allowed by autoconf).
Autoconf allows one to pass -enable-*, but this file expected --enable*.
<corsepiu@faw.uni-ulm.de> to fix the following:
* lib/configure.in actually is libc's configure.in, so let it depend
on libc not on lib [In my Cygnus/GNU configuration scheme, lib/include
and lib/libc are treated as one unit, while libcpu and libbsp are
treated as separate units.]
* Allow empty --enable-bare* flags for the bare bsp. The formerly
used scheme is too strict for our multilib experiments.
that contains:
* Removes MKLIB
handling)
1. SH-Port:
* Many files renamed.
applying VPATH.
2. SH1-Port
3. SH2-Port
* Merged
you don't mind).
<corsepiu@faw.uni-ulm.de> which does the following:
This is the configuration cleanup patch:
Main changes:
* TARGET_ARCH removed
* target.cfg.in moved to c/make/target.cfg.in (Only configured once for
all BSPs of a target)
* BARE_XXX variables appended to bsp.cfg.in
* autogen renamed to bootstrap
* removed stray variables from make/custom/*.cfg
rm c/src/make/target.cfg.in
cp autogen bootstrap
mkdir c/make
cp make/target.cfg.in c/make/target.cfg.in
rm make/target.cfg.in
rm autogen
patch -p1 < rtems-rc-19991105-1.diff
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
This patch addresses a few configuration issues and removes some
duplicate configuration files.
Background:
* some files used in AC_INIT were not unique enough and can lead to
problems if a user plays with configure scripts.
* the Makefile templates are independent of the target/cpu and bsp, so
the bsp dependent versions (c/src/make/Templates) are removed.
patch -p1 < rtems-rc-19990820-3.diff
rm -f c/src/make/Templates
ATTENTION: This patch removes several files and one directory :)
