* | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-02 | 1 | -2/+2 |
| | | | | * configure.ac: Require autoconf-2.68, automake-1.11.1. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-28 | 1 | -2/+2 |
* | 2009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-21 | 1 | -7/+1 |
| | | | | | * configure.ac: Remove reference to bare BSP. Simplify RTEMS_BSP_LIST setup. | ||||
* | 2007-03-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-03-27 | 1 | -1/+1 |
| | | | | * configure.ac: Use MKDIR_P instead of mkdir_p. | ||||
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 1 | -1/+1 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 1 | -2/+2 |
| | | | | * configure.ac: Require autoconf-2.60. Require automake-1.10. | ||||
* | 2004-10-18 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-10-18 | 1 | -24/+26 |
| | | | | * configure.ac: Rework checking for BSPs. | ||||
* | 2004-10-18 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-10-18 | 1 | -3/+0 |
| | | | | | * acinclude.m4: Remove RTEMS_CHECK_CPU. * configure.ac: Remove RTEMS_CHECK_CPU, RTEMS_ENABLE_BARE. | ||||
* | Fix typo in previous change. | Ralf Corsepius | 2004-09-24 | 1 | -1/+1 |
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 1 | -1/+1 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
* | 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-31 | 1 | -0/+2 |
| | | | | | * configure.ac: Add --with-project-root, --with-project-top to rtems_bsp_configure. | ||||
* | 2004-02-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-17 | 1 | -5/+10 |
| | | | | | * Makefile.am: Cosmetics. * configure.ac: Add support for --disable-rtemsbsp. Cosmetics. | ||||
* | 2003-12-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-14 | 1 | -1/+14 |
| | | | | | | * Makefile.am: Remove RTEMS_BSP-subdir rule. * configure.ac: Let AC_CONFIG_FILES(Makefile..) append explictit rules for RTEMS_BSP-subdirs. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 1 | -2/+2 |
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | ||||
* | 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-11 | 1 | -1/+1 |
| | | | | | * configure.ac: Cosmetics. * Makefile.am: Cosmetics. | ||||
* | 2003-10-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-23 | 1 | -1/+0 |
| | | | | | * acinclude.m4: Merge-in former ../aclocal/config-subdirs.m4. * configure.ac: remove RTEMS_CANONICAL_HOST. | ||||
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 1 | -1/+1 |
| | | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-25 | 1 | -1/+0 |
* | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-02-11 | 1 | -1/+1 |
| | | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | ||||
| | | | | * configure.ac: AC_PREREQ(2.57). | ||||
* | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-21 | 1 | -1/+1 |
| | | | | * configure.ac: Fix --enable-rtemsbsp= handling. | ||||
* | 2002-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-11 | 1 | -26/+2 |
| | | | | * configure.ac: Apply RTEMS_CONFIGURE_ARGS_QUOTE. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -2/+2 |
| | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-01-06 | 1 | -7/+3 |
| | | | | | * Makefile.am: Remove make from SUBDIRS. * configure.ac: Remove make from CONFIG_SUBDIRS, cosmetics. | ||||
* | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-11 | 1 | -0/+106 |
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. |
