path: root/c/build-tools (unfollow)
1998-05-18Added proper reference now that Embedded Systems Programming's WWW siteJoel Sherrill2-2/+14
is available and has the code available.
1998-03-03Switched from "extern int errno" to "#include <errno.h>".Joel Sherrill6-6/+6
1998-02-07Should not install build-tools using target variant options.Joel Sherrill1-1/+1
1998-01-30Big patch form Ralf Corsepius described in this email:Joel Sherrill5-20/+10
Here is the result of my nightly work to get RTEMS_ROOT=$srcdir working with different shells and relative/absolute paths. What I did is relatively simple in principle: Instead of setting RTEMS_ROOT in configure.in and then let configure substitute @RTEMS_ROOT@ inside the Makefiles, I now let each Makefile set RTEMS_ROOT from each Makefile's @top_srcdir@ value. The difference is subtile, but with enormous side effects: - If RTEMS_ROOT is set in configure, then the same single value will be propagated to all Makefiles. This breaks using relative paths, as the relative path to the root of the source tree is used inside of all subdirectory Makefiles. - Now each Makefile.in sets RTEMS_ROOT = @top_srcdir@. top_srcdir is computed individually by configure for each single Makefile.in, hereby receiving the correct value, no matter if relative or absolute paths are used. To get this working, I needed to remove setting RTEMS_ROOT from target.cfg.in, because this overrides the value of RTEMS_ROOT from each individual Makefile. Furthermore, I removed RTEMS_CUSTOM from the Makefiles and replaced all "include $(RTEMS_CUSTOM)" directives with"include $(RTEMS_ROOT)/make/custom/$(RTEMS_BSP)". Perhaps you don't like this, but I think, to have one variable less is clearer and easier to understand than having several variables refering to the next one. I enclose a small patch to this mail, which - fixes the config.h problem (to finally clearify misunderstands) - removes assignment/subsitution of RTEMS_ROOT from configure.in - contains a workaround for the application Makefile's RTEMS_ROOT problem (reported by Eric) - removes some unused lines from the toplevel Makefile.in - removes assignment of RTEMS_ROOT from make/target.cfg.in
1998-01-26new fileJoel Sherrill1-0/+9
1998-01-23Solaris port updates from Chris JohnsJoel Sherrill4-4/+4
1998-01-21Added autoconf support for strerror/sys_errlist per Ralf Corsepius'Joel Sherrill9-53/+161
direction. This fixes a problem reported by Steve Evans of Radstone since he is using glibc2.
1998-01-21Corrected prototypes for main per Ralf Corsepius' report of warningsJoel Sherrill6-10/+24
generated when egcs is used with "-Wall -pedantic".
1998-01-20Removed CONFIG_DIR and PROJECT_HOME directories.Joel Sherrill1-1/+1
1998-01-16Ralf Corsepius reported a number of missing CVS Id's:Joel Sherrill3-1/+32
> RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose.
1997-12-10Modified a lot of files to take a first cut at supporting building fromJoel Sherrill5-8/+20
any directory in the build tree. The only variable which must be set before the command "gmake" is invoked is RTEMS_BSP (e.g. RTEMS_BSP=erc32).
1997-08-28Removed hackspecs.awk in move from -mrtems to -qrtems.Joel Sherrill1-2/+1
1997-04-01This set of changes is the build of what was required to convert toJoel Sherrill7-6/+166
1996-06-03added ifdef for sunos 4.x since it does not have strtoul.Joel Sherrill2-4/+12
1996-01-15updates from Tony Bennett for PA and UNIX portsJoel Sherrill6-64/+12
1995-12-19changes remerged after disk crash -- history lostJoel Sherrill4-0/+12
1995-10-06fixed missing CVS IDsJoel Sherrill5-0/+13
1995-10-06SPARC merged and successfully tested w/o interrupt supportJoel Sherrill4-0/+16
1995-10-06moved to new development machine and went to gcc 2.7.0Joel Sherrill4-0/+12
1995-09-29all targets compile .. tony's patches in placeJoel Sherrill2-2/+2
1995-09-27new programs addedJoel Sherrill3-1/+276
1995-09-11AddedJoel Sherrill1-0/+283
1995-07-26updates for msdos/go32 from Bryce CogswellJoel Sherrill3-0/+498
1995-05-31fixing revisionJoel Sherrill4-0/+12
