path: root/c/build-tools (follow)
* Should not install build-tools using target variant options.Joel Sherrill1998-02-071-1/+1
* Big patch form Ralf Corsepius described in this email:Joel Sherrill1998-01-305-20/+10
* new fileJoel Sherrill1998-01-261-0/+9
* Solaris port updates from Chris JohnsJoel Sherrill1998-01-234-4/+4
* Added autoconf support for strerror/sys_errlist per Ralf Corsepius'Joel Sherrill1998-01-219-53/+161
| | | | | direction. This fixes a problem reported by Steve Evans of Radstone since he is using glibc2.
* Corrected prototypes for main per Ralf Corsepius' report of warningsJoel Sherrill1998-01-216-10/+24
| | | | generated when egcs is used with "-Wall -pedantic".
* Removed CONFIG_DIR and PROJECT_HOME directories.Joel Sherrill1998-01-201-1/+1
* Ralf Corsepius reported a number of missing CVS Id's:Joel Sherrill1998-01-163-1/+32
| | | | | | | | | | > RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose.
* Modified a lot of files to take a first cut at supporting building fromJoel Sherrill1997-12-105-8/+20
* Removed hackspecs.awk in move from -mrtems to -qrtems.Joel Sherrill1997-08-281-2/+1
* This set of changes is the build of what was required to convert toJoel Sherrill1997-04-017-6/+166
| | | | | | | | | | | | | | | | | | | | GNU autoconf. This is the first large step in allowing an RTEMS user to perform a one-tree build (per crossgcc FAQ) including RTEMS in the build process. With this change RTEMS is configured in built in the same style as the GNU tools, yet retains the basic structure of its traditional Makefiles (ala Tony Bennett). Jiri Gaisler (jgais@wd.estec.esa.nl) deserves (and received) a big thank you for doing this. There are still issues to be resolved but as of this commit, all target which can be built on a linux host have been using a modified version of the source Jiri submitted. This source was merged and most targets built in the tree before this commit. There are some issues which remain to be resolved but they are primarily related to host OS dependencies, script issues, the use of gawk for hack_specs, and the dependence on gcc snapshots. These will be resolved.
* added ifdef for sunos 4.x since it does not have strtoul.Joel Sherrill1996-06-032-4/+12
* updates from Tony Bennett for PA and UNIX portsJoel Sherrill1996-01-156-64/+12
* changes remerged after disk crash -- history lostJoel Sherrill1995-12-194-0/+12
* fixed missing CVS IDsJoel Sherrill1995-10-065-0/+13
* SPARC merged and successfully tested w/o interrupt supportJoel Sherrill1995-10-064-0/+16
* moved to new development machine and went to gcc 2.7.0Joel Sherrill1995-10-064-0/+12
* all targets compile .. tony's patches in placeJoel Sherrill1995-09-292-2/+2
* new programs addedJoel Sherrill1995-09-273-1/+276
* AddedJoel Sherrill1995-09-111-0/+283
* updates for msdos/go32 from Bryce CogswellJoel Sherrill1995-07-263-0/+498
* fixing revisionJoel Sherrill1995-05-314-0/+12
* Initial revisionJoel Sherrill1995-05-1110-0/+3958
