path: root/c/build-tools/src/eolstrip.c (unfollow)
1999-04-19Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to reorganizeJoel Sherrill1-366/+0
the build-tools layout to simplify it. This script reorganizes and simpilfies the build-tools subdirectories. It moves all source-files and scripts to c/build-tools/. This will enable use to use this directory directly to refer to the build-tools instead of copying them around in a "preinstall" step in future. However, RTEMS's autoconf Makefile.ins and *.cfg files are not yet prepared to apply this approach and therefore require additional work.
1998-03-03Switched from "extern int errno" to "#include <errno.h>".Joel Sherrill1-1/+1
1998-01-23Solaris port updates from Chris JohnsJoel Sherrill1-1/+1
1998-01-21Added autoconf support for strerror/sys_errlist per Ralf Corsepius'Joel Sherrill1-7/+20
direction. This fixes a problem reported by Steve Evans of Radstone since he is using glibc2.
1998-01-21Corrected prototypes for main per Ralf Corsepius' report of warningsJoel Sherrill1-2/+4
generated when egcs is used with "-Wall -pedantic".
1996-01-15updates from Tony Bennett for PA and UNIX portsJoel Sherrill1-15/+2
1995-12-19changes remerged after disk crash -- history lostJoel Sherrill1-0/+3
1995-10-06SPARC merged and successfully tested w/o interrupt supportJoel Sherrill1-0/+4
1995-10-06moved to new development machine and went to gcc 2.7.0Joel Sherrill1-0/+3
1995-05-31fixing revisionJoel Sherrill1-0/+3
