path: root/c/build-tools/cklength.c (unfollow)
1998-03-03Switched from "extern int errno" to "#include <errno.h>".Joel Sherrill1-1/+1
1998-01-21Added autoconf support for strerror/sys_errlist per Ralf Corsepius'Joel Sherrill1-8/+19
direction. This fixes a problem reported by Steve Evans of Radstone since he is using glibc2.
1998-01-21Corrected prototypes for main per Ralf Corsepius' report of warningsJoel Sherrill1-2/+4
generated when egcs is used with "-Wall -pedantic".
1996-01-15updates from Tony Bennett for PA and UNIX portsJoel Sherrill1-15/+2
1995-12-19changes remerged after disk crash -- history lostJoel Sherrill1-0/+3
1995-10-06SPARC merged and successfully tested w/o interrupt supportJoel Sherrill1-0/+4
1995-10-06moved to new development machine and went to gcc 2.7.0Joel Sherrill1-0/+3
1995-05-31fixing revisionJoel Sherrill1-0/+3
