path: root/c/TOOL_TARGETS (unfollow)
2002-11-072002-11-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* TOOL_TARGETS: Updated. * PROBLEMS, README, REQUIRES, TESTED, UPDATE_HELP: Removed since they were obsolete.
2001-05-252001-05-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+10
* TESTED: Updated the list of BSPs. * TOOLS_TARGETS: Updated the list of tools and object formats.
1999-10-05Removed targets and configurations that are no longer functionalJoel Sherrill1-1/+1
and not likely to become so. Comments on each configuration are below. + Force CPU386 - This BSP was developed as part of the initial port of RTEMS to the i386. This board has been unavailable for a long time now. + GO32 - This BSP and some CPU code supported djgpp v1.x. This version is now quite old. No one has stepped forward to update the code to v2.x which may be technically impossible anyway. More importantly, go32 has been superceded by the pc386 BSP.
1999-07-03New file.Joel Sherrill1-0/+56
