subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
There's an explicit invocation of `make' in c/Makefile.in. This
breaks for those of us with different `gmake' and `make' programs.
formerly under $(target) and is now at the same level.
It is no longer a link. It is a copy.
install tree and cleaned up spacing.
difftest.
was done based on the 3.6.0 release and had to be autoconf'ed locally.
It is turned on is the bsp enables it and it is not explicitly disabled
via the configure option --disable-tcpip. As many warnings as possible
were removed locally after the code was merged. Only the gen68360
and mvme136 bsps were compiled this way.
The ka9q port and network driver were submitted by Eric Norum
(eric@skatter.USask.Ca).
The network demo programs are not included in the tree at this point.
be resolved.
