path: root/c/Makefile.in (follow)
* Part of the automake VI patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-02-181-4/+4
* Part of the automake VI patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-02-181-1/+14
| | | | | | | | | | | | | | | | | | > 3) rtems-rc-19990131-2.diff > > This patch removes generating bsp_specs from leaf.cfg and generates > bsp_specs from inside of c/Makefile instead. > > The motivation behind this patch is to avoid "polluting" Makefiles by > unneccessary rules from included Makefile-fragments (*.cfg-files) and > try to handle files by explicit rules in Makefiles instead (FYI: > automake-1.4 physically includes Makefile fragments at the time > automake is run, not at the time make is run as RTEMS Makefile.ins do > now) > > Nevertheless, this patch is rather uncritical, almost cosmetical - If > you don't like it, then dump it ;-, however I doubt that subsequent > patches will apply then ;-.
* Part of the targopts.h change in generation patch from Ralf CorsepiusJoel Sherrill1999-02-181-2/+6
| | | | <corsepiu@faw.uni-ulm.de>.
* Patch from Emmanuel Raguet <raguet@crf.canon.fr> to add remote debug serverJoel Sherrill1998-12-031-0/+10
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | and RPC support to RTEMS. Thanks. :) Email follows: Hello, For Xmas, here is the Remote Debugger on RTEMS ! Here are 2 patches for the Remote Debugger on RTEMS for pc386 from Linux host : - one for RTEMS it self, - one for GDB-4.17. 1/ RTEMS patch -------------- This patch adds 2 libraries : - a simplified SUN RPC library - the Remote Debugger library The configuration command is the following : ../rtems4/configure --target=i386-rtemself --enable-rtemsbsp=pc386 --enable-rdbg The SUN RPC library is built only if networking is set. The RDBG library is built if networking and enable-rdbg are set. The function used to initialize the debugger is : rtems_rdbg_initialize (); A special function has been created to force a task to be in a "debug" state : enterRdbg(). The use of this function is not mandatory. 2/ GDB-4.17 patch ----------------- This patch create a new RTEMS target for GDB-4.17. The configuration command is the following : ./configure --enable-shared --target=i386RTEMS To connect to a target, use : target rtems [your_site_address] Then, attach the target using : attach 1 And... Debug ;) You can obtain the original GDB-4.17 on ftp://ftp.debian.org/debian/dists/stable/main/source/devel/gdb_4.17.orig.tar.gz This has been tested from a Debian 2.0.1 linux host.
* Merged Vista SCORE603e, Radstone PPCn_60x, and DY-4 DMV177 BSPs alongJoel Sherrill1998-10-281-0/+1
| | | | with libchip.
* Added pre_install_src as a dependency to debug and profile per Ralf Corsepius'Joel Sherrill1998-10-151-2/+2
| | | | recommendation.
* Patches from Eric NorumJoel Sherrill1998-08-201-7/+2
* FreeBSD stack compiles for the first time (except libc/strsep.c)Joel Sherrill1998-08-201-0/+9
* Patches from Ralf Corsepius <corsepiu@faw.uni-ulm.de> and myself toJoel Sherrill1998-08-191-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | make solaris target buildable. > 1. The ipc check fails since solaris does not define union semun. > The unix port code actually defines this type itself on solaris. Doing > the same thing lets it get configured. Then... > 2. It looks like BSDINSTALL is not defined properly. BSDINSTALL is defined in make/host.cfg.in as BSDINSTALL=@INSTALL@ @INSTALL@ is generated by autoconf's standard macro AC_PROG_INSTALL, which is widely used in almost any autoconf/automake configured package. In case there is really something wrong with it, then it must be considered a bug in autoconf. I can see a doubious fragment in AC_PROG_INSTALL, which is used when no appropriate bsd-install is found. Finally Ralf saw a problem with the find on solaris which I also saw and fixed.
* Added print of the order in which the directories are preinstalled.Joel Sherrill1998-08-051-1/+9
* Patch from Eric VALETTE <valette@crf.canon.fr>:Joel Sherrill1998-07-231-1/+13
| | | | | | | | | | | | | Here is a enhanced version of my previous patch. This patch enables to potentially share the new interrupt management code for all Intel targets (pc386, go32 and force386) bsp. Note : this patch is complete only for pc386. It still needs to be completed for go32 and force386. I carrefully checked that anything needed is in for force386 (only some function name changes for IDT manipulation and GDT segment manipulation). But anyway I will not be able to test any of theses targets...
* Added stanzas for debug_tests and profile_tests.Joel Sherrill1998-04-061-0/+6
* Changed to remove warning.Joel Sherrill1998-03-031-5/+3
* Fix from Eric Norum:Joel Sherrill1998-01-271-1/+1
| | | | | There's an explicit invocation of `make' in c/Makefile.in. This breaks for those of us with different `gmake' and `make' programs.
* Removed CONFIG_DIR and PROJECT_HOME directories.Joel Sherrill1998-01-201-15/+11
* Modified a lot of files to take a first cut at supporting building fromJoel Sherrill1997-12-101-10/+21
* Reworked mkdir line to invoke smaller lines.Joel Sherrill1997-12-041-1/+4
* Do not generate make/os at install point.Joel Sherrill1997-11-301-2/+1
* Moved rtems directory up one directory in the install point. It wasJoel Sherrill1997-10-211-9/+9
| | | | formerly under $(target) and is now at the same level.
* Redid the installation of the "make" directory at the install point.Joel Sherrill1997-10-071-21/+11
| | | | It is no longer a link. It is a copy.
* Fixed bug where include not actually created.Joel Sherrill1997-10-061-2/+5
* Added rule so TARGET_VARIANTS are dependent on the environment stuff.Joel Sherrill1997-08-271-1/+4
* Added include/motorola and include/zilog directories to theJoel Sherrill1997-08-041-8/+10
| | | | install tree and cleaned up spacing.
* Merged very large and much appreciated patch from Chris JohnsJoel Sherrill1997-07-311-1/+5
| | | | | <cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test.
* added ka9q stackJoel Sherrill1997-05-271-0/+5
* KA9Q stack removed prior to testing for 4.0.0 public release.Joel Sherrill1997-05-231-5/+0
* Added support for HW API packageJoel Sherrill1997-04-221-10/+2
* Added directories to place test output screens into as part of fixingJoel Sherrill1997-04-151-3/+4
| | | | difftest.
* Added ka9q tcpip stack and network driver for the gen68360. This effortJoel Sherrill1997-04-091-1/+6
| | | | | | | | | | | | | was done based on the 3.6.0 release and had to be autoconf'ed locally. It is turned on is the bsp enables it and it is not explicitly disabled via the configure option --disable-tcpip. As many warnings as possible were removed locally after the code was merged. Only the gen68360 and mvme136 bsps were compiled this way. The ka9q port and network driver were submitted by Eric Norum (eric@skatter.USask.Ca). The network demo programs are not included in the tree at this point.
* This set of changes is the build of what was required to convert toJoel Sherrill1997-04-011-0/+98
