* | 2004-01-07 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-01-07 | 1 | -0/+5 |
| | | | | | * ACKNOWLEDGEMENTS: Remove efi68k and efi332 references as they are no longer in the tree. | ||||
* | 2003-12-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-12-17 | 1 | -0/+4 |
| | | | | * release_support: Removed -- accidentally added to wrong directory. | ||||
| | | | | * release_support: New file -- assistant to new cut_release script. | ||||
* | 2003-12-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-14 | 1 | -0/+6 |
| | | | | | | * Makefile.am: Remove RTEMS_BSP-subdir rule. * configure.ac: Let AC_CONFIG_FILES(Makefile..) append explictit rules for RTEMS_BSP-subdirs. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 1 | -0/+4 |
| | | | | * Makefile.am: Use mkdir_p instead of mkinstalldirs. | ||||
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | ||||
* | 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-11 | 1 | -0/+5 |
| | | | | | * configure.ac: Cosmetics. * Makefile.am: Cosmetics. | ||||
* | 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-26 | 1 | -0/+4 |
| | | | | * acinclude.m4: Fix underquoting to silence automake-1.8. | ||||
* | 2003-10-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-23 | 1 | -0/+5 |
| | | | | | * acinclude.m4: Merge-in former ../aclocal/config-subdirs.m4. * configure.ac: remove RTEMS_CANONICAL_HOST. | ||||
* | 2003-10-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-23 | 1 | -0/+4 |
| | | | | * Makefile.am: Don't explictly invoke $MAKE preinstall. | ||||
* | 2003-10-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-02 | 1 | -0/+5 |
| | | | | | * acinclude.m4: New. Add RTEMS_CHECK_CPU. | ||||
* | 2003-09-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-26 | 1 | -0/+5 |
| | | | | | * ACKNOWLEDGEMENTS: Obsoleting HP PA-RISC port and removing all references. | ||||
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 1 | -0/+4 |
| | | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-25 | 1 | -0/+4 |
* | Merger from rtems-4-6-branch | Ralf Corsepius | 2003-02-15 | 1 | -0/+6 |
* | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-02-11 | 1 | -0/+4 |
| | | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | ||||
| | | | | * configure.ac: AC_PREREQ(2.57). | ||||
* | 2002-11-07 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-07 | 1 | -0/+6 |
| | | | | | | * TOOL_TARGETS: Updated. * PROBLEMS, README, REQUIRES, TESTED, UPDATE_HELP: Removed since they were obsolete. | ||||
* | 2002-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-11-02 | 1 | -0/+4 |
| | | | | * Makefile.am: Use mkinstalldirs instead of mkdir. | ||||
* | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-21 | 1 | -0/+4 |
| | | | | * configure.ac: Fix --enable-rtemsbsp= handling. | ||||
* | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-21 | 1 | -0/+6 |
| | | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | ||||
* | 2002-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-11 | 1 | -0/+4 |
| | | | | * configure.ac: Apply RTEMS_CONFIGURE_ARGS_QUOTE. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -0/+7 |
| | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-01-06 | 1 | -0/+5 |
| | | | | | * Makefile.am: Remove make from SUBDIRS. * configure.ac: Remove make from CONFIG_SUBDIRS, cosmetics. | ||||
* | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-11 | 1 | -0/+6 |
| | | | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. | ||||
* | 2001-05-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-05-25 | 1 | -0/+4 |
| | | | | * TESTED: Corrected the name of the MRM332 BSP. | ||||
* | 2001-05-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-05-25 | 1 | -0/+5 |
| | | | | | * TESTED: Updated the list of BSPs. * TOOLS_TARGETS: Updated the list of tools and object formats. | ||||
* | 2001-03-08 Ralf Corsepiu <corsepius@faw.uni-ulm.de> | Joel Sherrill | 2001-03-14 | 1 | -0/+5 |
| | | | | | * configure.in: Use ${MAKE} in message at the end of the configure.in. | ||||
* | 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-02-05 | 1 | -0/+4 |
| | | | | * configure.in: Apply _RTEMS_ADJUST_SRCDIR. | ||||
* | 2000-12-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-12-14 | 1 | -0/+4 |
| | | | | * TESTED: Added comment on 68en302 now that there is a network driver. | ||||
* | 2000-11-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-11-25 | 1 | -0/+4 |
| | | | | * TESTED: Added jmr3904 entry. | ||||
* | 2000-11-20 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-11-21 | 1 | -0/+4 |
| | | | | * TESTED: Added new sparc variations (erc32, leon, and Tharsys). | ||||
* | 2000-11-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-10 | 1 | -0/+5 |
| | | | | | * configure.in: catch -enable-rtemsbsp (Allowed by autoconf). Autoconf allows one to pass -enable-*, but this file expected --enable*. | ||||
* | 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-09 | 1 | -0/+4 |
| | | | | * Makefile.am: Use ... instead of RTEMS_TOPdir in ACLOCAL_AMFLAGS. | ||||
* | 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-02 | 1 | -0/+4 |
| | | | | * Makefile.am: Switch to ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/aclocal. | ||||
* | 2000-10-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-10-31 | 1 | -0/+4 |
| | | | | * Makefile.am: Switch to macros/, reflect new configure.in, | ||||
* | 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-10-27 | 1 | -0/+5 |
| | | | | | * Makefile.am: Make sure $SHELL inside of Makefiles does not get propagated to the BSP-subdirectories if a user specified CONFIG_SHELL. | ||||
* | Adding ChangeLogs. | Joel Sherrill | 2000-08-10 | 1 | -0/+3 |
