* | 2001-03-08 Ralf Corsepiu <corsepius@faw.uni-ulm.de> | Joel Sherrill | 2001-03-14 | 1 | -0/+5 |
| | | | | | * configure.in: Use ${MAKE} in message at the end of the configure.in. | ||||
* | 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-02-05 | 1 | -0/+4 |
| | | | | * configure.in: Apply _RTEMS_ADJUST_SRCDIR. | ||||
* | 2000-12-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-12-14 | 1 | -0/+4 |
| | | | | * TESTED: Added comment on 68en302 now that there is a network driver. | ||||
* | 2000-11-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-11-25 | 1 | -0/+4 |
| | | | | * TESTED: Added jmr3904 entry. | ||||
* | 2000-11-20 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-11-21 | 1 | -0/+4 |
| | | | | * TESTED: Added new sparc variations (erc32, leon, and Tharsys). | ||||
* | 2000-11-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-10 | 1 | -0/+5 |
| | | | | | * configure.in: catch -enable-rtemsbsp (Allowed by autoconf). Autoconf allows one to pass -enable-*, but this file expected --enable*. | ||||
* | 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-09 | 1 | -0/+4 |
| | | | | * Makefile.am: Use ... instead of RTEMS_TOPdir in ACLOCAL_AMFLAGS. | ||||
* | 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-02 | 1 | -0/+4 |
| | | | | * Makefile.am: Switch to ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/aclocal. | ||||
* | 2000-10-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-10-31 | 1 | -0/+4 |
| | | | | * Makefile.am: Switch to macros/, reflect new configure.in, | ||||
* | 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-10-27 | 1 | -0/+5 |
| | | | | | * Makefile.am: Make sure $SHELL inside of Makefiles does not get propagated to the BSP-subdirectories if a user specified CONFIG_SHELL. | ||||
* | Adding ChangeLogs. | Joel Sherrill | 2000-08-10 | 1 | -0/+3 |
