PR 1792/bsps
* src/lib/libbsp/i386/pc386/Makefile.am,
src/lib/libbsp/sparc/erc32/Makefile.am,
src/lib/libbsp/sparc/leon2/Makefile.am,
src/lib/libbsp/sparc/leon3/Makefile.am: Added a generic smp wait
method to sparc and i386 bsps.
* src/lib/libbsp/shared/smp/bspsmp_wait_for.c: New file.
PR 1777/cpukit
* src/lib/libbsp/powerpc/shared/startup/panic.c,
src/lib/libcpu/sh/sh7032/score/cpu_asm.c,
src/lib/libcpu/sh/sh7045/score/cpu_asm.c,
src/lib/libcpu/sh/sh7750/score/cpu_asm.c,
src/lib/libcpu/sh/shgdb/score/cpu_asm.c: Consolidated access to
_Thread_Dispatch_disable_level.
* src/libchip/network/dec21140.c, src/libchip/network/elnk.c,
src/libchip/network/greth.c, src/libchip/network/greth.h,
src/libchip/network/open_eth.c: Fix typo where license said
found in found in.
* configure.ac: Remove reference to bare BSP.
Simplify RTEMS_BSP_LIST setup.
* TOOL_TARGETS: Add Lattice Mico32 support.
* src/aclocal/rtems-cpu-subdirs.m4: Add new M32R port. It is just a
beginning but the BSP is functional enough to initialize and shutdown
RTEMS.
PR 1237/rtems
* src/lib/libbsp/shared/bsplibc.c: Add logic to prevent stack creep
when interrupts occur at a sufficient rate that the interrupted
thread never gets to clean its stack. This patch ensures that an
interrupted thread will not nest ISR dispatches on its stack.
* configure.ac: Use MKDIR_P instead of mkdir_p.
* TOOL_TARGETS: New port to Altera NIOS II.
* Makefile.am: Remove depend-am.
* configure.ac: Rework checking for BSPs.
* acinclude.m4: Remove RTEMS_CHECK_CPU.
* configure.ac: Remove RTEMS_CHECK_CPU, RTEMS_ENABLE_BARE.
* configure.ac: Add --with-project-root, --with-project-top to
rtems_bsp_configure.
* Makefile.am: Cosmetics.
* configure.ac: Add support for --disable-rtemsbsp. Cosmetics.
* ACKNOWLEDGEMENTS: Remove efi68k and efi332 references as they are no
longer in the tree.
* release_support: Removed -- accidentally added to wrong directory.
* release_support: New file -- assistant to new cut_release script.
* Makefile.am: Remove RTEMS_BSP-subdir rule.
* configure.ac: Let AC_CONFIG_FILES(Makefile..) append explictit
rules for RTEMS_BSP-subdirs.
* Makefile.am: Use mkdir_p instead of mkinstalldirs.
* configure.ac: Cosmetics.
* acinclude.m4: Fix underquoting to silence automake-1.8.
* acinclude.m4: Merge-in former ../aclocal/config-subdirs.m4.
* configure.ac: remove RTEMS_CANONICAL_HOST.
* Makefile.am: Don't explictly invoke $MAKE preinstall.
* acinclude.m4: New.
Add RTEMS_CHECK_CPU.
* ACKNOWLEDGEMENTS: Obsoleting HP PA-RISC port and removing all
references.
* TOOL_TARGETS: Updated.
* PROBLEMS, README, REQUIRES, TESTED, UPDATE_HELP: Removed
since they were obsolete.
* Makefile.am: Use mkinstalldirs instead of mkdir.
* configure.ac: Fix --enable-rtemsbsp= handling.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* configure.ac: Apply RTEMS_CONFIGURE_ARGS_QUOTE.
* Makefile.am: Remove make from SUBDIRS.
* configure.ac: Remove make from CONFIG_SUBDIRS, cosmetics.
* configure.in: Remove.
* TESTED: Corrected the name of the MRM332 BSP.
* TESTED: Updated the list of BSPs.
* TOOLS_TARGETS: Updated the list of tools and object formats.
* configure.in: Use ${MAKE} in message at the end of the
configure.in.
* configure.in: Apply _RTEMS_ADJUST_SRCDIR.
* TESTED: Added comment on 68en302 now that there is a network driver.
* TESTED: Added jmr3904 entry.
