path: root/c/ChangeLog (follow)
* 2001-05-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-05-251-0/+4
| | | | * TESTED: Corrected the name of the MRM332 BSP.
* 2001-05-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-05-251-0/+5
| | | | | * TESTED: Updated the list of BSPs. * TOOLS_TARGETS: Updated the list of tools and object formats.
* 2001-03-08 Ralf Corsepiu <corsepius@faw.uni-ulm.de>Joel Sherrill2001-03-141-0/+5
| | | | | * configure.in: Use ${MAKE} in message at the end of the configure.in.
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-051-0/+4
| | | | * configure.in: Apply _RTEMS_ADJUST_SRCDIR.
* 2000-12-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-141-0/+4
| | | | * TESTED: Added comment on 68en302 now that there is a network driver.
* 2000-11-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-251-0/+4
| | | | * TESTED: Added jmr3904 entry.
* 2000-11-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-211-0/+4
| | | | * TESTED: Added new sparc variations (erc32, leon, and Tharsys).
* 2000-11-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-101-0/+5
| | | | | * configure.in: catch -enable-rtemsbsp (Allowed by autoconf). Autoconf allows one to pass -enable-*, but this file expected --enable*.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-091-0/+4
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-021-0/+4
* 2000-10-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-311-0/+4
| | | | * Makefile.am: Switch to macros/, reflect new configure.in,
* 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-271-0/+5
| | | | | * Makefile.am: Make sure $SHELL inside of Makefiles does not get propagated to the BSP-subdirectories if a user specified CONFIG_SHELL.
