* Makefile.am: Use mkinstalldirs instead of mkdir.
* configure.ac: Fix --enable-rtemsbsp= handling.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* configure.ac: Apply RTEMS_CONFIGURE_ARGS_QUOTE.
* Makefile.am: Remove make from SUBDIRS.
* configure.ac: Remove make from CONFIG_SUBDIRS, cosmetics.
* configure.in: Remove.
* TESTED: Corrected the name of the MRM332 BSP.
* TESTED: Updated the list of BSPs.
* TOOLS_TARGETS: Updated the list of tools and object formats.
* configure.in: Use ${MAKE} in message at the end of the
configure.in.
* configure.in: Apply _RTEMS_ADJUST_SRCDIR.
* TESTED: Added comment on 68en302 now that there is a network driver.
* TESTED: Added jmr3904 entry.
* TESTED: Added new sparc variations (erc32, leon, and Tharsys).
* configure.in: catch -enable-rtemsbsp (Allowed by autoconf).
Autoconf allows one to pass -enable-*, but this file expected --enable*.
* Makefile.am: Switch to macros/, reflect new configure.in,
* Makefile.am: Make sure $SHELL inside of Makefiles does not get
propagated to the BSP-subdirectories if a user specified CONFIG_SHELL.
