path: root/c/ChangeLog (follow)
* 2004-10-18 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-10-181-0/+4
| | | | * configure.ac: Rework checking for BSPs.
* 2004-10-18 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-10-181-0/+5
| | | | | * acinclude.m4: Remove RTEMS_CHECK_CPU. * configure.ac: Remove RTEMS_CHECK_CPU, RTEMS_ENABLE_BARE.
* 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-09-241-0/+4
| | | | * configure.ac: Require automake > 1.9.
* 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-311-0/+5
| | | | | * configure.ac: Add --with-project-root, --with-project-top to rtems_bsp_configure.
* 2004-02-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-171-0/+5
| | | | | * Makefile.am: Cosmetics. * configure.ac: Add support for --disable-rtemsbsp. Cosmetics.
* 2004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-071-0/+5
| | | | | * ACKNOWLEDGEMENTS: Remove efi68k and efi332 references as they are no longer in the tree.
* 2003-12-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-12-171-0/+4
| | | | * release_support: Removed -- accidentally added to wrong directory.
| | | | * release_support: New file -- assistant to new cut_release script.
* 2003-12-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-141-0/+6
| | | | | | * Makefile.am: Remove RTEMS_BSP-subdir rule. * configure.ac: Let AC_CONFIG_FILES(Makefile..) append explictit rules for RTEMS_BSP-subdirs.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-121-0/+4
| | | | * Makefile.am: Use mkdir_p instead of mkinstalldirs.
| | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59.
* 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-111-0/+5
| | | | | * configure.ac: Cosmetics. * Makefile.am: Cosmetics.
* 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-261-0/+4
| | | | * acinclude.m4: Fix underquoting to silence automake-1.8.
* 2003-10-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-231-0/+5
| | | | | * acinclude.m4: Merge-in former ../aclocal/config-subdirs.m4. * configure.ac: remove RTEMS_CANONICAL_HOST.
* 2003-10-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-231-0/+4
| | | | * Makefile.am: Don't explictly invoke $MAKE preinstall.
* 2003-10-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-021-0/+5
| | | | | * acinclude.m4: New. Add RTEMS_CHECK_CPU.
* 2003-09-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-261-0/+5
| | | | | * ACKNOWLEDGEMENTS: Obsoleting HP PA-RISC port and removing all references.
* 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-111-0/+4
| | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address.
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-251-0/+4
* Merger from rtems-4-6-branchRalf Corsepius2003-02-151-0/+6
* 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-111-0/+4
| | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]).
| | | | * configure.ac: AC_PREREQ(2.57).
* 2002-11-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-071-0/+6
| | | | | | * TOOL_TARGETS: Updated. * PROBLEMS, README, REQUIRES, TESTED, UPDATE_HELP: Removed since they were obsolete.
* 2002-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-021-0/+4
| | | | * Makefile.am: Use mkinstalldirs instead of mkdir.
* 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-211-0/+4
| | | | * configure.ac: Fix --enable-rtemsbsp= handling.
* 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-211-0/+6
| | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache.
* 2002-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-111-0/+4
| | | | * configure.ac: Apply RTEMS_CONFIGURE_ARGS_QUOTE.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-281-0/+7
* 2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-061-0/+5
| | | | | * Makefile.am: Remove make from SUBDIRS. * configure.ac: Remove make from CONFIG_SUBDIRS, cosmetics.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-111-0/+6
* 2001-05-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-05-251-0/+4
| | | | * TESTED: Corrected the name of the MRM332 BSP.
* 2001-05-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-05-251-0/+5
| | | | | * TESTED: Updated the list of BSPs. * TOOLS_TARGETS: Updated the list of tools and object formats.
* 2001-03-08 Ralf Corsepiu <corsepius@faw.uni-ulm.de>Joel Sherrill2001-03-141-0/+5
| | | | | * configure.in: Use ${MAKE} in message at the end of the configure.in.
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-051-0/+4
| | | | * configure.in: Apply _RTEMS_ADJUST_SRCDIR.
* 2000-12-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-141-0/+4
| | | | * TESTED: Added comment on 68en302 now that there is a network driver.
* 2000-11-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-251-0/+4
| | | | * TESTED: Added jmr3904 entry.
* 2000-11-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-211-0/+4
| | | | * TESTED: Added new sparc variations (erc32, leon, and Tharsys).
* 2000-11-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-101-0/+5
| | | | | * configure.in: catch -enable-rtemsbsp (Allowed by autoconf). Autoconf allows one to pass -enable-*, but this file expected --enable*.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-091-0/+4
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-021-0/+4
* 2000-10-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-311-0/+4
| | | | * Makefile.am: Switch to macros/, reflect new configure.in,
* 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-271-0/+5
| | | | | * Makefile.am: Make sure $SHELL inside of Makefiles does not get propagated to the BSP-subdirectories if a user specified CONFIG_SHELL.
