path: root/bsps/x86_64 (follow)
* build: Remove old build systemSebastian Huber2021-09-212-19/+0
| | | | | Close #3250. Close #4081.
* bsps/irq: bsp_interrupt_facility_initialize()Sebastian Huber2021-07-271-3/+1
| | | | | | Do not return a status code in bsp_interrupt_facility_initialize() since this leads to unreachable code in bsp_interrupt_initialize(). Use RTEMS_DEBUG assertions in bsp_interrupt_facility_initialize() if necessary.
* bsps/irq: bsp_interrupt_vector_disable()Sebastian Huber2021-07-261-1/+2
| | | | | | Return a status code for bsp_interrupt_vector_disable(). Update #3269.
* bsps/irq: bsp_interrupt_vector_enable()Sebastian Huber2021-07-261-1/+2
| | | | | | Return a status code for bsp_interrupt_vector_enable(). Update #3269.
* bsps/irq: Add rtems_interrupt_is_pending()Sebastian Huber2021-07-261-0/+11
| | | | | | Add a default implementation which just returns RTEMS_UNSATISFIED. Update #3269.
* bsps/irq: Add rtems_interrupt_get_attributes()Sebastian Huber2021-07-261-0/+9
| | | | | | | Add a default implementation which clears the attributes to zero and just returns RTEMS_SUCCESSFUL for valid parameters. Update #3269.
* bsps/irq: Add rtems_interrupt_raise()Sebastian Huber2021-07-261-0/+12
| | | | | | | | | Add rtems_interrupt_raise_on() and rtems_interrupt_clear(). Add a default implementation which just returns RTEMS_UNSATISFIED for valid parameters. Update #3269.
* bsps/irq: Add rtems_interrupt_vector_is_enabled()Sebastian Huber2021-07-261-0/+11
* bsps/irq: Remove BSP_INTERRUPT_VECTOR_MAXSebastian Huber2021-06-241-1/+0
| | | | | | This define is no longer used. Update #3269.
* bsps/irq: Add BSP_INTERRUPT_VECTOR_COUNTSebastian Huber2021-06-241-0/+1
| | | | | | | | | | | | | Assert BSP_INTERRUPT_VECTOR_MAX + 1 == BSP_INTERRUPT_VECTOR_COUNT. After building all BSPs with this patch, BSP_INTERRUPT_VECTOR_MAX can be removed and replaced by BSP_INTERRUPT_VECTOR_COUNT. The BSP_INTERRUPT_VECTOR_COUNT allows a default implementation which supports no interrupt vector at all. Using COUNT instead of MAX may avoid some interpretation issues, for example is the maximum value a valid vector number or not. Update #3269.
* bsps/irq: Remove BSP_INTERRUPT_VECTOR_MINSebastian Huber2021-06-241-1/+0
| | | | | | | | | | Remove BSP_INTERRUPT_VECTOR_MIN and unconditionally let interrupt vector numbers start with zero. The BSP_INTERRUPT_VECTOR_MIN == 0 invariant was tested by the previous commit and building all BSPs. Update #3269.
* bsps: Support RTEMS_NOINIT in linkcmdsSebastian Huber2021-05-021-0/+5
| | | | Update #3866.
* bsps: Replace bsp_specs with an empty fileSebastian Huber2021-01-281-9/+0
| | | | | | | This fixes an issue with the latest tool chain which adds the default linker script in the endfile specification. Update #3250.
* bsps: Add RamEnd to linker command filesSebastian Huber2020-02-041-0/+1
| | | | Update #3838.
* bsps: Adjust bsp.h Doxygen groupsSebastian Huber2019-03-082-1/+17
| | | | Update #3706.
* bsps: Adjust architecture Doxygen groupsSebastian Huber2019-03-041-0/+7
| | | | | | | | | | - Use CamelCase as it is not used in our C code. Enables simple search and replace. - Prefix with "RTEMS" to aid deployment and integration. It aids searching and sorting. Update #3706.
* Changed slightly awkward sentence structurezehata2018-11-221-5/+4
* bsps/x86_64: Use interrupt stack for init stackSebastian Huber2018-11-193-36/+42
| | | | Update #3459.
* bsps/x86_64: Add APIC timer based clock driverAmaan Cheval2018-08-136-0/+614
| | | | | | | | | The APIC timer is calibrated by running the i8254 PIT for a fraction of a second (determined by PIT_CALIBRATE_DIVIDER) and counting how many times the APIC counter has ticked. The calibration can be run multiple times (determined by APIC_TIMER_NUM_CALIBRATIONS) and averaged out. Updates #2898.
* bsps/x86_64: Add support for RTEMS interruptsAmaan Cheval2018-08-135-0/+394
| | | | Updates #2898.
* bsps/x86_64: Add paging support with 1GiB super pagesAmaan Cheval2018-08-134-0/+247
| | | | Updates #2898.
* bsps/x86_64: Reduce default RamSize to 1GiBAmaan Cheval2018-08-131-3/+3
| | | | | | | Simulators may not always be able to allocate 4GiB easily, and using an artificially lower RAM may cause a broken heap. Updates #2898.
* bsps/x86_64: Reorganize header files and compile-optionsAmaan Cheval2018-08-131-0/+3
| | | | Updates #2898.
* x86_64/console: Add NS16550 polled console driverAmaan Cheval2018-07-111-93/+30
| | | | | | This addition allows us to successfully run the sample hello.exe test. Updates #2898.
* bsp/x86_64: Minimal bootable BSPAmaan Cheval2018-07-1110-0/+612
Current state: - Basic context initialization and switching code. - Stubbed console (empty functions). - Mostly functional linker script (may need tweaks if we ever want to move away from the large code model (see: CPU_CFLAGS). - Fully functional boot, by using FreeBSD's bootloader to load RTEMS's ELF for UEFI-awareness. In short, the current state with this commit lets us boot, go through the system initialization functions, and then call user application's Init task too. Updates #2898.
