* | bsps/x86_64: Add paging support with 1GiB super pages | Amaan Cheval | 2018-08-13 | 4 | -0/+247 |
| | | | | Updates #2898. | ||||
* | bsps/x86_64: Reduce default RamSize to 1GiB | Amaan Cheval | 2018-08-13 | 1 | -3/+3 |
| | | | | | | | Simulators may not always be able to allocate 4GiB easily, and using an artificially lower RAM may cause a broken heap. Updates #2898. | ||||
* | bsps/x86_64: Reorganize header files and compile-options | Amaan Cheval | 2018-08-13 | 1 | -0/+3 |
* | x86_64/console: Add NS16550 polled console driver | Amaan Cheval | 2018-07-11 | 1 | -93/+30 |
| | | | | | | This addition allows us to successfully run the sample hello.exe test. Updates #2898. | ||||
* | bsp/x86_64: Minimal bootable BSP | Amaan Cheval | 2018-07-11 | 10 | -0/+612 |
Current state: - Basic context initialization and switching code. - Stubbed console (empty functions). - Mostly functional linker script (may need tweaks if we ever want to move away from the large code model (see: CPU_CFLAGS). - Fully functional boot, by using FreeBSD's bootloader to load RTEMS's ELF for UEFI-awareness. In short, the current state with this commit lets us boot, go through the system initialization functions, and then call user application's Init task too. Updates #2898. |
