This fixes an issue with the latest tool chain which adds the default
linker script in the endfile specification.
Update #3250.
Update #4171.
Update #4171.
Update #4171.
This avoids a cast in DEV_TO_COMMON().
Provide RTEMS_NO_RETURN also in case RTEMS_DEBUG is defined to prevent errors
like this:
error: no return statement in function returning non-void [-Werror=return-type]
Use C11 and C++11 standard means to declare a no-return function.
Close #4122.
Replace leon3_irqmp_has_timestamp() with irqmp_has_timestamp() and move
it to grlib.h.
Close #4128.
The inter-processor interrupt (IPI) may be used to process per-CPU jobs.
See for example the blocked handler in T_interrupt_test().
Update #3199.
Updates #2962
Add a simplified path evaluation function IMFS_eval_path_devfs() for a
device only IMFS configuration.
The code size can be further reduced by the application if it disables
the support for legacy IO drivers via:
#define CONFIGURE_IMFS_DISABLE_MKNOD
#define CONFIGURE_IMFS_DISABLE_MKNOD_DEVICE
Obsolete CONFIGURE_MAXIMUM_DEVICES. Remove BSP_MAXIMUM_DEVICES.
Update #3894.
Update #3898.
Use RTEMS_SYSINIT_ORDER_LAST_BUT_5 instead of RTEMS_SYSINIT_ORDER_LAST
to allow applications and support functions to place system
initialization handlers behind the standard handlers.
Update #3838.
The work area initialization was done by the BSP through
bsp_work_area_initialize(). This approach predated the system
initialization through the system initialization linker set. The
workspace and C program heap were unconditionally initialized. The aim
is to support RTEMS application configurations which do not need the
workspace and C program heap. In these configurations, the workspace
and C prgram heap should not get initialized.
Change all bsp_work_area_initialize() to implement _Memory_Get()
instead. Move the dirty memory, sbrk(), per-CPU data, workspace, and
malloc() heap initialization into separate system initialization steps.
This makes it also easier to test the individual initialization steps.
This change adds a dependency to _Heap_Extend() to all BSPs. This
dependency will be removed in a follow up change.
Update #3838.
The code covered by BSP_GET_WORK_AREA_DEBUG was basically dead code
since there was no normal way to activate it (e.g. via a BSP
configuration option). A follow up patch will bring back this feature
through a CONFIGURE_VERBOSE_SYSTEM_INITIALIZATION configuration option.
Update #3838.
Add support for _SMP_Send_message() to the own processor. This is
required by the smpmulticast01 test program.
Update #3732.
Add rtems_scheduler_get_processor() as a replacement for
rtems_get_current_processor(). The rtems_get_current_processor() is a
bit orphaned. Adopt it by the Scheduler Manager. This is in line with
the glibc sched_getcpu() function.
Deprecate rtems_get_current_processor().
Update #3731.
Update #3706.
Update #3706.
replace.
searching and sorting.
Update #3706.
Update #3678.
Update #3678.
Update #3678.
This avoids a dependency to errno in device driver code.
In order to simplify the use of CPU counter values it is beneficial to
have monotonic increasing values within the range of the CPU counter
ticks data type, e.g. 32-bit unsigned integer. This eases the use of
CPU counter timestamps in external tools which do not know the details
of the CPU counter hardware. The CPU counter is the fastest way to get
a time on an RTEMS system.
Such a CPU counter may be also used as the timecounter. Use it on SPARC
for this purpose to simplify the clock drivers.
Update #3456.
Avoid assert() in console_inbyte_nonblocking().
Do not poll forever in bsp_in_char(). This allows the caller to decide
what to do if no character is available.
This entangles some dependencies and fixes a spconfig02 test failure.
Reduce copy and paste.
Rename
* _Configuration_Interrupt_stack_area_begin in _ISR_Stack_area_begin,
* _Configuration_Interrupt_stack_area_end in _ISR_Stack_area_end, and
* _Configuration_Interrupt_stack_size in _ISR_Stack_size.
Move definitions to <rtems/score/isr.h>. The new names are considerable
shorter and in the right namespace.
Update #3459.
Clang do not support -mfix-gr712rc, -mfix-ut700 and -mfix-ut699.
Therefore we adjust the CPU_CFLAGS to remove these when compiling with
Clang. Instead use
GR712RC: -mcpu=gr712rc
GR740: -mcpu=gr740
UT699/UT700: Not currently supported by clang, use LEON3 BSP.
Update #3530.
Update #3533.
When the CCSDS/CCITT CRC-16 and 16-bit ISO-checksum logic is available in
GRSPW2, the DCRCT field is used to determine how to generate the CRC/checksum
code. grspw_hw_sup has been extended with the field ccsds_crc
This is a workaround for a L2CACHE scrubber corner case described in GR740
User's Manual, Version 1.10, section 43.2.30.
The issue affects some version of the L2CACHE. However, since the performance
impact of the workaround is marginal, special device probing logic has been
avoided. In addition, this update does not affect users who enable the L2CACHE
and scrubber before RTEMS is started.
Update #3456.
Add and use <machine/rtems-bsd-kernel-space.h> and
<machine/rtems-bsd-user-space.h> similar to the libbsd to avoid command
line defines and defines scattered throught the code base.
Simplify cpukit/libnetworking/Makefile.am.
Update #3375.
To clarify, SMP with GRSWP_PKT driver API has been extended to
take advantage of multi-core, is now SMP-safe, and has been tested
on GR740.
ince some time RTEMS started to use the termios c_ispeed and
c_ospeed variables in the termios struct to hold the UART baudrate.
However the APBUART driver still uses the old c_cflag sometimes
causing other UART parameters to get overwritten, for example the
partiy setting no mapped to the same bits as the old CBAUD mask.
At the same time the RTEMS primitievs for setting/reading
c_{i,o}speed is now used.
It enabled promiscous mode or sets the multicast filter according
to the configuration and parameters to ioctl(SIOCSIFFLAGS),
ioctl(SIOCADDMULTI) and ioctl(SIOCDELMULTI).
On SIOCADDMULTI/SIOCDELMULTI requests the greth ioctl calls the
Ethernet helper functions ether_addmulti()/ether_delmulti() which
tells the greth driver when its required to update the MAC multicast
filtering.
The interface notifies support for multicast by setting IFF_MULTICAST.
The GRETH has two registers which contains a bit-mask of allowed MAC
addresses. The incomming MAC address is CRC:ed and the CRC is used as
an index into the bit-mask to determine to allow or drop the frame.
Missed to enable interrupt per TX descriptor. Could lead to TX buffer
starvation.
Does not affect the GBit code.
