Update #3732.
Add rtems_scheduler_get_processor() as a replacement for
rtems_get_current_processor(). The rtems_get_current_processor() is a
bit orphaned. Adopt it by the Scheduler Manager. This is in line with
the glibc sched_getcpu() function.
Deprecate rtems_get_current_processor().
Update #3731.
Update #3706.
Update #3706.
replace.
searching and sorting.
Update #3706.
Update #3678.
Update #3678.
Update #3678.
This avoids a dependency to errno in device driver code.
In order to simplify the use of CPU counter values it is beneficial to
have monotonic increasing values within the range of the CPU counter
ticks data type, e.g. 32-bit unsigned integer. This eases the use of
CPU counter timestamps in external tools which do not know the details
of the CPU counter hardware. The CPU counter is the fastest way to get
a time on an RTEMS system.
Such a CPU counter may be also used as the timecounter. Use it on SPARC
for this purpose to simplify the clock drivers.
Update #3456.
Avoid assert() in console_inbyte_nonblocking().
Do not poll forever in bsp_in_char(). This allows the caller to decide
what to do if no character is available.
This entangles some dependencies and fixes a spconfig02 test failure.
Reduce copy and paste.
Rename
* _Configuration_Interrupt_stack_area_begin in _ISR_Stack_area_begin,
* _Configuration_Interrupt_stack_area_end in _ISR_Stack_area_end, and
* _Configuration_Interrupt_stack_size in _ISR_Stack_size.
Move definitions to <rtems/score/isr.h>. The new names are considerable
shorter and in the right namespace.
Update #3459.
Clang do not support -mfix-gr712rc, -mfix-ut700 and -mfix-ut699.
Therefore we adjust the CPU_CFLAGS to remove these when compiling with
Clang. Instead use
GR712RC: -mcpu=gr712rc
GR740: -mcpu=gr740
UT699/UT700: Not currently supported by clang, use LEON3 BSP.
Update #3530.
Update #3533.
When the CCSDS/CCITT CRC-16 and 16-bit ISO-checksum logic is available in
GRSPW2, the DCRCT field is used to determine how to generate the CRC/checksum
code. grspw_hw_sup has been extended with the field ccsds_crc
This is a workaround for a L2CACHE scrubber corner case described in GR740
User's Manual, Version 1.10, section 43.2.30.
The issue affects some version of the L2CACHE. However, since the performance
impact of the workaround is marginal, special device probing logic has been
avoided. In addition, this update does not affect users who enable the L2CACHE
and scrubber before RTEMS is started.
Update #3456.
Add and use <machine/rtems-bsd-kernel-space.h> and
<machine/rtems-bsd-user-space.h> similar to the libbsd to avoid command
line defines and defines scattered throught the code base.
Simplify cpukit/libnetworking/Makefile.am.
Update #3375.
To clarify, SMP with GRSWP_PKT driver API has been extended to
take advantage of multi-core, is now SMP-safe, and has been tested
on GR740.
ince some time RTEMS started to use the termios c_ispeed and
c_ospeed variables in the termios struct to hold the UART baudrate.
However the APBUART driver still uses the old c_cflag sometimes
causing other UART parameters to get overwritten, for example the
partiy setting no mapped to the same bits as the old CBAUD mask.
At the same time the RTEMS primitievs for setting/reading
c_{i,o}speed is now used.
It enabled promiscous mode or sets the multicast filter according
to the configuration and parameters to ioctl(SIOCSIFFLAGS),
ioctl(SIOCADDMULTI) and ioctl(SIOCDELMULTI).
On SIOCADDMULTI/SIOCDELMULTI requests the greth ioctl calls the
Ethernet helper functions ether_addmulti()/ether_delmulti() which
tells the greth driver when its required to update the MAC multicast
filtering.
The interface notifies support for multicast by setting IFF_MULTICAST.
The GRETH has two registers which contains a bit-mask of allowed MAC
addresses. The incomming MAC address is CRC:ed and the CRC is used as
an index into the bit-mask to determine to allow or drop the frame.
Missed to enable interrupt per TX descriptor. Could lead to TX buffer
starvation.
Does not affect the GBit code.
This reduces the link-time dependencies and avoids copy-and-paste.
Fix typo in start.S introduced by
4678d1a8b0e74a12809122ef071324c99e78d7ff.
Pass current processor control as first parameter to make dependency
more explicit.
Pass current processor control as first parameter in
bsp_start_on_secondary_processor() and qoriq_start_thread() to make
dependency more explicit.
Pass current processor control via parameter since it may be already
available at the caller side.
Statically initialize the interrupt stack area
(_Configuration_Interrupt_stack_area_begin,
_Configuration_Interrupt_stack_area_end, and
_Configuration_Interrupt_stack_size) via <rtems/confdefs.h>. Place the
interrupt stack area in a special section ".rtemsstack.interrupt". Let
BSPs define the optimal placement of this section in their linker
command files (e.g. in a fast on-chip memory).
This change makes makes the CPU_HAS_SOFTWARE_INTERRUPT_STACK and
CPU_HAS_HARDWARE_INTERRUPT_STACK CPU port defines superfluous, since the
low level initialization code has all information available via global
symbols.
This change makes the CPU_ALLOCATE_INTERRUPT_STACK CPU port define
superfluous, since the interrupt stacks are allocated by confdefs.h for
all architectures. There is no need for BSP-specific linker command
file magic (except the section placement), see previous ARM linker
command file as a bad example.
Remove _CPU_Install_interrupt_stack(). Initialize the hardware
interrupt stack in _CPU_Initialize() if necessary (e.g.
m68k_install_interrupt_stack()).
The optional _CPU_Interrupt_stack_setup() is still useful to customize
the registration of the interrupt stack area in the per-CPU information.
The initialization stack can reuse the interrupt stack, since
* interrupts are disabled during the sequential system initialization,
and
* the boot_card() function does not return.
This stack resuse saves memory.
Changes per architecture:
arm:
* Mostly replace the linker symbol based configuration of stacks with
the standard <rtems/confdefs.h> configuration via
CONFIGURE_INTERRUPT_STACK_SIZE. The size of the FIQ, ABT and UND
mode stack is still defined via linker symbols. These modes are
rarely used in applications and the default values provided by the
BSP should be sufficient in most cases.
* Remove the bsp_processor_count linker symbol hack used for the SMP
support. This is possible since the interrupt stack area is now
allocated by the linker and not allocated from the heap. This makes
some configure.ac stuff obsolete. Remove the now superfluous BSP
variants altcycv_devkit_smp and realview_pbx_a9_qemu_smp.
bfin:
* Remove unused magic linker command file allocation of initialization
stack. Maybe a previous linker command file copy and paste problem?
In the start.S the initialization stack is set to a hard coded value.
lm32, m32c, mips, nios2, riscv, sh, v850:
* Remove magic linker command file allocation of initialization stack.
Reuse interrupt stack for initialization stack.
m68k:
powerpc:
* Used dedicated memory region (REGION_RTEMSSTACK) for the interrupt
stack on BSPs using the shared linkcmds.base (replacement for
REGION_RWEXTRA).
sparc:
* Remove the hard coded initialization stack. Use the interrupt stack
for the initialization stack on the boot processor. This saves
16KiB of RAM.
Update #3459.
Use a dedicated memory region or place it between the BSS and workspace.
Update #3459.
The aim of this clock driver hook was to stop clock tick interrupts at
some late point in the exit() procedure.
The use of atexit() pulls in malloc() which pulls in errno. It is
incompatible with the intention of the
CONFIGURE_DISABLE_NEWLIB_REENTRANCY configuration option.
The exit() function must be called from thread context, so accompanied
clock tick interrupts should cause no harm. On the contrary, someone
may assume a normal operating system operation, e.g. working timeouts.
Remove the Clock_driver_support_shutdown_hardware() clock driver hook.
Close #3436.
Add rtems_counter_frequency() API function. Use it to initialize the
counter value converter via the new system initialization step
(RTEMS_SYSINIT_CPU_COUNTER). This decouples the counter implementation
and the counter converter. It avoids an unnecessary pull in of the
64-bit integer division from libgcc.
Update #3456.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
