Pass the parameter of the clock interrupt handler to
Clock_driver_support_at_tick() and Clock_driver_timecounter_tick(). This makes
it possible to use the interrupt handler argument in clock drivers.
Use the interrupt handler provided by Clock_driver_support_install_isr() to
avoid local delarations of Clock_isr().
Update #4862.
Update #3707.
Sort the .noinit* input sections by name first, then by alignment if two
sections have the same name. This allows the placement of begin/end symbols to
initialize some areas with a special value.
Update #4678.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3937.
Close #3250.
Close #4081.
Update #3866.
This fixes an issue with the latest tool chain which adds the default
linker script in the endfile specification.
Update #3250.
Closes #3936.
Update #3838.
Update #3269.
controller support.
Update #3269.
Update #3706.
Update #3706.
replace.
searching and sorting.
Update #3706.
Update #3459.
Use a dedicated memory region or place it between the BSS and workspace.
Update #3459.
The aim of this clock driver hook was to stop clock tick interrupts at
some late point in the exit() procedure.
The use of atexit() pulls in malloc() which pulls in errno. It is
incompatible with the intention of the
CONFIGURE_DISABLE_NEWLIB_REENTRANCY configuration option.
The exit() function must be called from thread context, so accompanied
clock tick interrupts should cause no harm. On the contrary, someone
may assume a normal operating system operation, e.g. working timeouts.
Remove the Clock_driver_support_shutdown_hardware() clock driver hook.
Close #3436.
Updates #3425.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
The boot/stack.h header contains duplicated macros that are
redundant to arch/stack.h. Delete the boot/stack.h and replace
its one use by the arch/stack.h.
Closes #3341.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
