path: root/bsps/sparc64/niagara (follow)
* sparc64 niagara, usiii: Remove -D options from cfg file and move to bspopts.hJoel Sherrill2018-05-091-1/+1
| | | | Updates #3425.
* bsps: Move documentation, etc. files to bspsSebastian Huber2018-04-261-0/+65
| | | | | | This patch is a part of the BSP source reorganization. Update #3285.
* bsps: Move make/custom/* files to bspsSebastian Huber2018-04-231-0/+16
| | | | | | | | | Adjust various build files. Remove automatic generation of the c/src/lib/libbsp/*/acinclude.m4 files from bootstrap script. This patch is a part of the BSP source reorganization. Update #3285.
* bsps: Move startup files to bspsSebastian Huber2018-04-205-0/+357
| | | | | | | | Adjust build support files to new directory layout. This patch is a part of the BSP source reorganization. Update #3285.
* bsps: Move start files to bspsSebastian Huber2018-04-201-0/+35
* Remove make preinstallChris Johns2018-01-253-0/+48
