2022-11-14 | bsps/sparc: Change license to BSD-2 for files with Gaisler copyright | Daniel Cederman | 1 | -5/+26 | |
This patch changes the license to BSD-2 for all source files where the copyright is held by Aeroflex Gaisler, Cobham Gaisler, or Gaisler Research. Some files also includes copyright right statements from OAR and/or embedded Brains in addition to Gaisler. Updates #3053. | |||||
2021-03-05 | gr_leon4_n2x.c: Fix Unchecked return value from library (CID #1399767) | Ryan Long | 1 | -1/+3 | |
CID 1399767: Unchecked return value error from library in gr_cpci_leon4_n2x_init1(). Closes #4285 | |||||
2019-01-22 | grlib: Move header files | Sebastian Huber | 1 | -6/+6 | |
Update #3678. | |||||
2018-12-21 | bsps/sparc: Fix warnings | Sebastian Huber | 1 | -3/+5 | |
2018-11-27 | bsps/sparc: Add and use <grlib_impl.h> | Sebastian Huber | 1 | -10/+1 | |
Reduce copy and paste. | |||||
2018-09-20 | leon: substitute printf with printk in driver init | Daniel Hellstrom | 1 | -6/+6 | |
2018-04-20 | bsps/sparc: Move shared files to bsps | Sebastian Huber | 1 | -0/+0 | |
This patch is a part of the BSP source reorganization. Update #3285. | |||||
2017-05-14 | leon, pci-peripherals: SMP support by spin-locks and updated genirq | Daniel Hellstrom | 1 | -16/+50 | |
2017-03-06 | leon, gr-cpci-leon4-n2x: small comment fix | Javier Jalle | 1 | -1/+1 | |
2015-04-17 | DRVMGR: KEY_TYPE now a enum drvmgr_kt | Daniel Hellstrom | 1 | -3/+3 | |
2015-04-17 | sparc bsps: updated license to rtems.org | Daniel Hellstrom | 1 | -1/+1 | |
2015-04-17 | LEON: converted LEON4-N2X to BSD header | Daniel Hellstrom | 1 | -4/+4 | |
2015-04-17 | LEON: move driver headers to bsp/ directory | Daniel Hellstrom | 1 | -2/+2 | |
2015-04-17 | GR-LEON4-N2X: fix build warnings | Daniel Hellstrom | 1 | -10/+9 | |
2015-04-17 | NGMP PCI: added support for NGMP prototype boards | Daniel Hellstrom | 1 | -5/+8 | |
2015-04-17 | GR-CPCI-LEON4-N2X: added PCI peripheral driver for PCI device | Daniel Hellstrom | 1 | -0/+759 | |
Interrupts have not been test yet |
