The <leon.h> header file contains a lot of implementation details. Hide them
from <bsp.h>.
Remove superfluous include. Fix comment formatting.
This fix relates to a Coverity issue (NESTING_INDENT_MISMATCH).
Update #3732.
Add rtems_scheduler_get_processor() as a replacement for
rtems_get_current_processor(). The rtems_get_current_processor() is a
bit orphaned. Adopt it by the Scheduler Manager. This is in line with
the glibc sched_getcpu() function.
Deprecate rtems_get_current_processor().
Update #3731.
Update #3285.
